China's stealth jet -J-20
Old January 11th 11, 06:53 PM posted to rec.aviation.military,sci.military.naval,rec.aviation.military.naval
Dan[_12_]
Default China's stealth jet -J-20
On 1/11/2011 12:24 PM, Orval Fairbairn wrote:
In article
On Jan 7, 2:59 pm, "Keith wrote:
On of the problems when dealing with a socity like China
is that its hard to know when they have produced a
prototype. They tend to look less tolerantly on plane
spotters than western natons.
Keith, this ignorant civilian would like to know if it is possible for
the Chinese
to have a good understanding of what is needed to develop this
aircraft fully
as a result of stealing the information (i.e., hacking military
computers)?
Cheers . . . J.
They have some very good engineers who could come up with some real
innovations.
That said, if they depend on stolen information, it would be very easy
to plant deliberate misinformation in places they can hack (with some
effort). That is the flaw in stealind information.
Let them steal a chip design with a built in flaw such that it can be
remotely commanded to cause major system failure. Essentially one could
get the Red Chinese to construct an airplane with a built in bomb.
Dan, U.S. Air Force, retired
Old January 11th 11, 07:57 PM posted to rec.aviation.military,sci.military.naval,rec.aviation.military.naval
Dr. Vincent Quin, Ph.D.
In article
the Chinese
aircraft fully
computers)?
Cheers . . . J.
innovations.
Reverse engineering. Ever heard of it?
Old January 11th 11, 08:29 PM posted to rec.aviation.military,sci.military.naval,rec.aviation.military.naval
Daryl Hunt[_3_]
On 1/11/2011 12:57 PM, Dr. Vincent Quin, Ph.D. wrote:
In article
possible for
the Chinese
aircraft fully
computers)?
Cheers . . . J.
real
innovations.
very easy
(with some
can be remotely commanded to cause major system failure.
Essentially one could get the Red Chinese to construct an
Yah, ask Toyota, Nissan and Honda how well that went when they
stole Chrysler blind on the throttle. It made Chrysler have to
recall a couple of hundred thousand cars just to make sure that
their system was good. It was.
Toyota and other Japanese companies bought the same equipment
from the same suppliers. The problem was, the control unit was
stupid and they had to reverse engineer the coding. They blew
it. In the Chrysler, there is a build in system where if
something goes wrong with the controller it disengages the
throttle. And if you tap the brake, it disengages the throttle.
Guess what, they left out those last two items and them lied to
the public and Congress about it. Yes, let them reverse engineer
that way there is more likelihood that they will screw the pooch.
Old January 12th 11, 01:20 AM posted to rec.aviation.military,sci.military.naval,rec.aviation.military.naval
Schiffner
On Jan 11, 12:57*pm, "Dr. Vincent Quin, Ph.D."
In article
the Chinese
aircraft fully
computers)?
Cheers . . . J.
innovations.
* Let them steal a chip design with a built in flaw such that it can be
Reverse engineering. *Ever heard of it?
You obviously haven't...**** eating trolls like you and the nazi's
around here need to **** off.
Old January 12th 11, 01:22 AM posted to rec.aviation.military,sci.military.naval,rec.aviation.military.naval
Dan[_12_]
On 1/11/2011 1:57 PM, Dr. Vincent Quin, Ph.D. wrote:
In article
the Chinese
aircraft fully
computers)?
Cheers . . . J.
innovations.
could get the Red Chinese to construct an airplane with a built in bomb.
Ever heard of getting a degree from a university that teaches reading
for comprehension?
Old January 12th 11, 01:46 AM posted to rec.aviation.military,sci.military.naval,rec.aviation.military.naval
Jim Wilkins
On Jan 11, 2:57*pm, "Dr. Vincent Quin, Ph.D."
Ever done it?
I have, for training as a semiconductor R&D tech. The good stuff is in
the software.
Old January 11th 11, 10:42 PM posted to rec.aviation.military,sci.military.naval,rec.aviation.military.naval
Andrew Swallow
On 11/01/2011 18:53, Dan wrote:
{snip}
The danger with that one is that our own aeroplanes have the save flaw.
Andrew Swallow
Dan[_12_]
{snip}
Andrew Swallow
Not if done right. Letting the bad guys assume you use it doesn't
mean you have to actually do so. Think of the phantom army Patton ran
prior to Overlord. The Nazis assumed it existed.
Old January 12th 11, 03:27 AM posted to rec.aviation.military,sci.military.naval,rec.aviation.military.naval
Jim Wilkins
{snip}
Andrew Swallow
This is a good example of modern tech:
http://www.xilinx.com/products/virtex6q/index.htm
You draw a schematic or specification, simulate it, then compile it
into a configuration file that (you hope) turns the generic Xilinx
chip into a circuit that implements your design. It's like a computer
program done in hardware. The configuration file is -seriously-
encrypted and loads at power-up, and is lost when the power shuts
off.
The individual elements of the ones I used were composed of 5-input
gates that could duplicate any logic function or Karnaugh map (they
actually used look-up tables) followed by master-slave D-type flip-
flops. If you know how to design computer logic that's all you need to
do anything.
When the first try didn't work because the Air Force radio it
controlled didn't meet its own specs, I needed only 10 minutes to fix
it.
Seriously, if you have the program manager's confidence that's how
fast and easy it can be to fix problems. Had it been deployed I could
have E-mailed the files out, like a Windows Update or BIOS upgrade to
a computer.
Old January 12th 11, 01:31 PM posted to rec.aviation.military,sci.military.naval,rec.aviation.military.naval
Malcolm[_2_]
In article , Andrew Swallow
writes
{snip}
Andrew Swallow
Not necessarily. Remember Concorde and Concordski? There were strong
rumours that the Russians had agents who acquired plans/details for
Concorde. The two aircraft were certainly fairly similar. The UK
and/or French got wind of it and fed in some duff data. Hence the crash
and demise of Concordski.
Not sure how true it is BUT I live about a mile from Filton and in an
area where there were a lot of people who worked on the project. When
new neighbours moved in next door about ten years ago they started
stripping wallpaper and found a thin wire similar to a radio aerial
running round the picture rail of a back bedroom........... One of the
previous owners was an aircraft engineer.
Malcolm
DIA on China's new fighter Mike Naval Aviation 28 November 22nd 09 11:34 PM
Who Is in Control of China's Aircraft Carriers? Sound Home Built 2 March 10th 07 07:48 PM
"Bravo Sierra" check (was "China's Army on Combat Alert") redc1c4 Military Aviation 19 April 3rd 04 09:21 PM
China's Chengdu J-10 Fighter - Big Trouble? Kevin Brooks Military Aviation 0 November 18th 03 02:06 PM
