LK8000 v2.0 released today
Old January 17th 11, 09:12 PM posted to rec.aviation.soaring
Bastoune
Default LK8000 v2.0 released today
On Jan 17, 2:11*pm, Mike wrote:
On Jan 17, 11:25*am, tstock wrote:
You will find additional info about the M400 and various other PNA
tested with LK8000 on the forum atwww.postfrontal.com
For the USB cable to use with Condor, I am using one from IMI that has
an RS232 inline converter. I believe Cumulus Soaring or WingandWheels
will have something similar. It is really handy to have the PNA
connected to Condor to familiarize yourself with the features of
LK8000.
Thanks for the info. I had been looking at the Mio earlier and was
considering buying it just for LK8000. *I did just order one from ebay
after you posted, and then discovered that it only has 128MB internal
storage and no SDCARD slot.
Has this been a problem at all for you? Also, how do you find battery
life?
I am hoping this is better than my Nokia. *The Nokia runs ok but it is
a little slow, and the screen is hard to read in sunlight. The touch
screen is also very inaccurate on the Nokia.
Thanks
Tom
The M400 works fine. No SD card needed, but you will need external
battery power for *flights over 2 hours. If you have purchased a used
one, you will probably need to replace the battery.- Hide quoted text -
- Show quoted text -
I will second that. A new 750ma battery ($12) is a good idea if the
device has been a bit of service.
Old January 17th 11, 09:55 PM posted to rec.aviation.soaring
tstock
battery power for flights over 2 hours. If you have purchased a used
I purchased a new one, but then purchased the cord by Vladimir to run
the MIO from external 12V source, as well as to connect via RS232 to
Flarm (as well as Condor, etc, to get used to it).
I've heard of a few people using a 4AA battery box with a USB charging
plug on it to run these things for many hours. Have you tried this?
That will probably be the easiest solution for a rental glider in
which I will be flying all day. Just replace the AA's before the
flight.
Thanks
Tom
Old January 18th 11, 12:27 AM posted to rec.aviation.soaring
Martin Gregorie[_5_]
That will probably be the easiest solution for a rental glider in which
I will be flying all day. Just replace the AA's before the flight.
Its also worth looking at external USB battery packs. These are
rechargeable 5v packs for anything that can be powered or charged via a
USB connection. One of our instructors uses one to power a Binatone PNA
if he's giving xc instruction in one of the K-21s. Amazon sell a range of
these units with capacities of 3000 - 8000 mAh. Prices start at $US 40.
IIRC a Binatone PNA has an internal 800 mAh battery that should run it
for 3 hours, so a 3000 mAh external battery should extend that to over 14
hours.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
iPAQ-310-LK8000-wind calculation Brad[_2_] Soaring 6 September 7th 10 11:05 PM
The LK8000 copyright issue is solved Max Kellermann Soaring 5 September 7th 10 06:50 PM
LK8000 questions Andy[_1_] Soaring 9 March 15th 10 11:10 AM
New LK8000 glide computer video PCool Soaring 6 October 12th 09 06:19 PM
T-37 PCATD released JD Simulators 0 October 6th 03 08:51 PM
