Earth shattering news for GNSS, commercial availability of Chip ScaleAtomic Clock (CSAC)
Old January 20th 11, 02:08 AM posted to sci.geo.satellite-nav,rec.aviation.ifr
Ed M.[_2_]
Default Earth shattering news for GNSS, commercial availability of ChipScale Atomic Clock (CSAC)
There's a lot of literature describing how a precise clock can
mitigate the strong correlation between the clock and vertical
position states, hence improve VDOP, improve integrity monitoring,
etc. Pratap Misra has written quite a bit on the topic.
An early paper on clock coasting (there were earlier experiments):
Sturza, Mark A., "GPS Navigation Using Tbree Satellites and a Precise
Clock", NAVIGATION, Vol. 30, No. 2, Summer 1983, pp. 146-156,
http://www.3csysco.com/Pubs/GPS%20Na...se%20Clock.pdf
Can't find an on-line copy of this one:
“The Role of the Clock in a GPS Receiver” by P.N. Misra in GPS World,
Vol. 7, No. 4, April 1996, pp. 60–66.
A dissertation that involved flight testing with a Boeing 767 at the
FAA's Atlantic City test site:
Kline, Paul A., "Atomic Clock Augmentation For Receivers Using the
Global Positioning System," Ph.D. Dissertation, Virginia Polytechnic
University, 1997, http://scholar.lib.vt.edu/theses/ava...2516142975720/
A thesis sponsored by Misra:
Sean G. Bednarz, "Adaptive Modeling of GPS Receiver Clock for
Integrity Monitoring During Precision Approaches," M.S. Thesis,
Massachusetts Institute of Technology, 2004, http://dspace.mit.edu/handle/1721.1/17756
A GPS World Innovations column from 2007:
http://tf.boulder.nist.gov/general/pdf/2267.pdf
Old January 20th 11, 06:46 AM posted to sci.geo.satellite-nav,rec.aviation.ifr
Mxsmanic
Default Earth shattering news for GNSS, commercial availability of Chip Scale Atomic Clock (CSAC)
How sensitive are these CSACs to other environmental variables? What about
shock, or position? Are they robust enough to be used in wris****ches and
portable timepieces (disregarding cost)?
Which reminds me: why are there no wris****ches that use GPS just for a time
reference, without the geolocation functions? Or are there? Seems like there'd
be a market for such watches to replace "radio-controlled" watches depending
on WWVB and the like, if the price isn't too high. They wouldn't need a CSAC,
although that would be a nice bonus.
Old January 20th 11, 07:37 AM posted to sci.geo.satellite-nav,rec.aviation.ifr
Terje Mathisen
No GPS unit is low-power enough to be used as a pure wris****ch, where a
single button battery is supposed to last for years.
You might get away with a very good crystal plus a GPS that only wakes
up once (or a few times) per day or so, in which case you have made
yourself a very expensive chronometer. :-)
Instead of spending power on an oven for a TCXO you could use the Garmin
approach of a tiny temperature sensor (_very_ low power) plus an
automatically calibrated temp adjustement table for the XO.
Terje
- Terje.Mathisen at tmsw.no
"almost all programming can be viewed as an exercise in caching"
Old January 20th 11, 09:06 AM posted to sci.geo.satellite-nav,rec.aviation.ifr
macpacheco
On Jan 20, 5:37*am, Terje Mathisen "terje.mathisen at tmsw.no"
Terje
Military CSAC applications include field radios and soldier automation
platforms that require temperature, shock tolerance anyways.
Even if CSACs don't make it to your typical individual GI equipment,
one should expect them to make it to special forces and other elite
units and platoon level systems. In Afghanistan alone, GPS clock
coasting is extremely desirable for accurate targeting in mountain
riddled terrain. Notice that was the trigger behind the last 24+3 GPS
constellation improvement.
Even if this first generation clock isn't fully able to handle
significant shock, you can be sure someone is working on it. You can't
put it on special forces gear unless it can handle a great deal of
shock.
Marcelo
Old January 20th 11, 08:08 AM posted to sci.geo.satellite-nav,rec.aviation.ifr
macpacheco
This first generation chip atomic clocks are still in the US$ 1000+
price scale. That should keep it's use down to where really needed.
Probably another 20 yrs until we have a micro chip scale atomic clock.
No clarification were given in the accuracy of the equipment at its
temperature limits. It's very likely that CSAC measures its own
temperature and compensate its output with measured temperature, so
its entirely possible that its accuracy stay within specs for its
entire operating temperature envelope.
A wrist watch that can keep time down to one second per year precision
is more than good enough, except for those who want to waste money on
pricey status objects.
Current quartz frequency standards already can keep time down to 30 ms
per year (source wikipedia) ! Though its likely that accuracy is
attained by larger chip sized quartz oscillator instead of the tiny
quartz circuits found in wrist watches. Even smaller last generation
micro quartz oscillators should be able to reach one second per year
accuracy, so why would you want a GPS receiver just to set the
clock ???? Just so you don't need to ever set your watch again ?
Old January 20th 11, 08:57 AM posted to sci.geo.satellite-nav,rec.aviation.ifr
J. J. Lodder
Radio controlled watches do the same thing more cheaply,
and work in most of the inahabited world,
at a much lower power consumption.
There would be at best a small niche market for such a thing,
Jan
Old January 20th 11, 08:50 AM posted to sci.geo.satellite-nav,rec.aviation.ifr
macpacheco
etc. *Pratap Misra has written quite a bit on the topic.
Clock", NAVIGATION, Vol. 30, No. 2, Summer 1983, pp. 146-156,http://www.3csysco.com/Pubs/GPS%20Na...Three%20Satell...
University, 1997,http://scholar.lib.vt.edu/theses/ava...2516142975720/
Massachusetts Institute of Technology, 2004,http://dspace.mit.edu/handle/1721.1/17756
Coasting studies I've read seem to assume usage of a worse CSAC than a
Cs atomic clock, something with at least one order of magnitude less
stability than your typical Cs atomic clock. Taking Symmetricon's
claims at face value here... Top of the line quartz oscillators = 30ms
per year stability, four orders of magnitude better would be roughly 3
micro seconds per year stability, 8 ns per day stability, or 1 ns
every 4 hours. Or 10 cm per hour drift. In an unjammed environment,
today even in the middle of a GPS maintenance event, PDOP spikes don't
last 2 hrs for the same area. And a 20cm error would be acceptable
even for a CAT I autoland (VPL around 10 meters). Expecting the need
to coast for more than 2 hours would be an nuclear war or extreme
military jam requirement, not a civilian need.
The most exciting aspect is this is only the first generation
implementation. There are no competitors yet. 2nd generation should be
here in lets guess 5 yrs. Imagine a CSAC on par with current Rb atomic
clock for short term stability ! This not only helps with GNSS
applications, but also helps every radio transmitter/receiver, 4g/
WiMax cell towers, ultra high speed laser transceivers, the list goes
on and on. CSACs will directly replace current 10 MHz GNSS based
frequency standards, used on any serious data communication/telecom
environment, even small rural ISPs are more and more using WiMax or
high end WiFi towers that require a more accurate frequency standard
than a quartz oscillator. 5g cell systems might use upcoming 100 MHz
atomic clock frequency standard to improve current RF performance by a
mile.
Marcelo Pacheco
CHIP LITE Stuart & Kathryn Fields Rotorcraft 3 March 28th 08 12:30 AM
Chip-Red formation 2 alf blume Aviation Photos 1 December 4th 06 07:06 PM
1 Amp DC/DC Converter Chip? bcjames Soaring 11 September 25th 04 06:32 AM
Garmin 430 data chip PaulaJay1 Instrument Flight Rules 6 December 29th 03 04:43 PM
ADC chip detectors CS_Mike Home Built 2 September 3rd 03 06:26 AM
