How many landings will aircraft tires hold?
Old January 28th 11, 02:50 AM posted to rec.aviation.homebuilt
Brian Whatcott
Default How many landings will aircraft tires hold?
On 1/27/2011 6:28 AM, Oliver Arend wrote:
I know the answer is "it depends", but let's say you are in a regular
light airplane (C152, C172 ...) with "real" aircraft tires and you do
normal landings without excessive load, speed or crosswind. It will
still depend on the surface of the runway, but generally, is the
number more on the order of 10s of landings (change rather often),
100s of landings (maybe get through one busy flying season with one
set) or 1000s of landings (last forever until aging kicks in)?
Oliver
In the South West, an average owner might need to change a tire or two
less often than 5 or 7 years, except the ozone/UV gets to cracking them
and then its time for more retreads.
Brian W
Clearance on hold, hold for release Hap[_2_] Piloting 17 June 28th 09 01:46 AM
Carrier Aircraft Catapault Hold-Back Bar / Mechanism ? Robert11 Naval Aviation 8 June 24th 06 05:40 PM
Slick aircraft tires Paul Lee Home Built 7 September 11th 04 06:01 AM
Changing *BIG* Aircraft Tires [Was Coalition casualties forseptember] Stephen Harding Military Aviation 9 October 5th 03 06:42 PM
Re unusual landings on Aircraft Carriers Jim Atkins Military Aviation 4 July 15th 03 10:54 PM
