ASW20 or LS6
Old January 31st 11, 02:19 AM posted to rec.aviation.soaring
Mike the Strike
Default ASW20 or LS6
On Jan 30, 6:10*pm, Tim wrote:
On Jan 30, 7:06*pm, binks wrote:
I am looking to purchase my first glider. I have been looking at the
ASW20 and the LS6. Any suggestions on which glider would be the best
all around? I have heard that the LS6 has a narrow cockpit. I am 6'2"
200 lbs. and would be wearing a parachute. Also heard that the ASW20
can be a little unforgiving to the uninitiated in the spin department.
Both seem to have very similar performance data. *All that being said
it is appearing to me it may be Ford vs Chevy
LS6 is the best handling ship I've ever flown. I got in one in the
Southern French Alps and flew in the first World Grand Prix with zero
hours in type and felt like I could do anything I needed with the
ship. Given the random and weak weather, I had to do some pretty
marginal things and it Never bit me :-) Unfortunately, "Z27" met a sad
fate a few years later in the French Alps. :-(
Tim McAllister EY
I think the spin reputation of the ASW-20 is a bit undeserved. Mine
behaved perfectly predictably once I got the CG forward of the aft
limit where the previous owner had left it! The LS-6 does have a
narrower cockpit, but this should only be a problem if you have really
broad shoulders. I suggest you try both before deciding. There isn't
much difference in performance between the two.
Mike
Old January 31st 11, 01:41 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
behaved perfectly predictably once I got the CG forward of the aft limit
where the previous owner had left it! The LS-6 does have a narrower
cockpit, but this should only be a problem if you have really broad
shoulders. I suggest you try both before deciding. There isn't much
Mine departed twice during roughly 45 degree banked thermalling turns at
around 45 kts in flap #3 (zero flap deflection). There was no buffet or
warning - it just went. I wondered if it was just something my glider
did. I also thought it might be due to micro-turbulence in those two
thermals, so I tried repeating the turn near home at the end of the day
at the same and at even lower airspeeds she just flew smoothly round the
circle.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old January 31st 11, 08:32 PM posted to rec.aviation.soaring
Roger Burghall
limit
circle.
org |
Mine stalls at 40 knots wings level. At 45 degrees it would therefore
stall at 48 knots, and (even assuming your bank was a bit less than it
looked) you were already stalled.
I have found its handling impeccable (well, so far!) but wouldn't thermal
below 50 with neutral flap. 45 is too slow even with thermalling flap.
Old January 31st 11, 11:27 PM posted to rec.aviation.soaring
limit
circle.
org |
thermal below 50 with neutral flap. 45 is too slow even with thermalling
flap.
Mine was better at low speed than that - was quite happy at 42 kt in
thermal flap and was generally well-behaved in a thermal between 45 and
50 kts in zero flap (#3) - I generally thermaled in zero flap because it
felt so much more responsive: IIRC it stalled at around 37-38. Certainly
it wouldn't sit down above 34 kts in landing flap.
org |
ELT Mounting for an ASW20-C Papa3 Soaring 11 January 26th 06 06:37 AM
ASW20 liftup panel mod ,do you want one goneill Soaring 2 September 8th 04 09:05 PM
ASW20 owners Andrew Henderson Soaring 0 April 10th 04 12:28 PM
Winglets for ASW20 goneill Soaring 5 February 3rd 04 01:21 AM
3 view drawing of ASW20 Kristoffer Raun Soaring 0 January 3rd 04 01:43 AM
