ASW20 or LS6
Old January 31st 11, 08:32 PM posted to rec.aviation.soaring
Roger Burghall
Default ASW20 or LS6
At 13:41 31 January 2011, Martin Gregorie wrote:
On Sun, 30 Jan 2011 18:19:41 -0800, Mike the Strike wrote:
I think the spin reputation of the ASW-20 is a bit undeserved. Mine
behaved perfectly predictably once I got the CG forward of the aft
limit
where the previous owner had left it! The LS-6 does have a narrower
cockpit, but this should only be a problem if you have really broad
shoulders. I suggest you try both before deciding. There isn't much
difference in performance between the two.
Mine departed twice during roughly 45 degree banked thermalling turns at
around 45 kts in flap #3 (zero flap deflection). There was no buffet or
warning - it just went. I wondered if it was just something my glider
did. I also thought it might be due to micro-turbulence in those two
thermals, so I tried repeating the turn near home at the end of the day
at the same and at even lower airspeeds she just flew smoothly round the
circle.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Mine stalls at 40 knots wings level. At 45 degrees it would therefore
stall at 48 knots, and (even assuming your bank was a bit less than it
looked) you were already stalled.
I have found its handling impeccable (well, so far!) but wouldn't thermal
below 50 with neutral flap. 45 is too slow even with thermalling flap.
Old January 31st 11, 11:27 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
limit
circle.
org |
thermal below 50 with neutral flap. 45 is too slow even with thermalling
flap.
Mine was better at low speed than that - was quite happy at 42 kt in
thermal flap and was generally well-behaved in a thermal between 45 and
50 kts in zero flap (#3) - I generally thermaled in zero flap because it
felt so much more responsive: IIRC it stalled at around 37-38. Certainly
it wouldn't sit down above 34 kts in landing flap.
org |
ELT Mounting for an ASW20-C Papa3 Soaring 11 January 26th 06 06:37 AM
ASW20 liftup panel mod ,do you want one goneill Soaring 2 September 8th 04 09:05 PM
ASW20 owners Andrew Henderson Soaring 0 April 10th 04 12:28 PM
Winglets for ASW20 goneill Soaring 5 February 3rd 04 01:21 AM
3 view drawing of ASW20 Kristoffer Raun Soaring 0 January 3rd 04 01:43 AM
