On 1/30/2011 10:28 PM, KevinFinke wrote:
"The std class version is the Pegasus, built in France." That's not really true Eric. While the Pegasus fuselage is descended from the ASW-20, the wing is very different. Different planform and airfoil. In fact, there has only ever been one true standard class ASW-20, and that is the ship that I own. It's the ASW-24 prototype, SN24000. It was built from ASW-20B molds, but was modified to be a pure standard class ship. I don't have the use of flaps, but I have a very interesting dual aileron setup. The inboard ailerons end about 1.5 meters from the wing root, and they throw differently than the outboard. It's a lovely machine with a very fast roll rate. Next type you voyage to Ephrata you'll have to look me up and I can show it to you. As for it's performance, it will eat a Pegasus for lunch. You are correct, the Pegasus is not an ASW 20 with the flaps glued to the wing. It does have the same wing area, bendiness, and the same planform (at least, it appears to be the same), so I'd call it at least a very close relative of the ASW 20. The one I flew felt just like my ASW 20. On the other hand, the ASW 19 and ASW 20 are very different gliders, and it is a mistake to use the 19 as a stand-in for the handling of the ASW 20. I'd love to look at SN2400 - that's new to me! -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) |
On Mon, 31 Jan 2011 15:14:56 -0800, Eric Greenwell wrote:
On the other hand, the ASW 19 and ASW 20 are very different gliders, and it is a mistake to use the 19 as a stand-in for the handling of the ASW 20. However, if you're thinking of buying a 19, 20 or Pegase and want to try the cockpit for size before making the trip to see the glider, its worth remembering that all three cockpits are near as dammit identical. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
ELT Mounting for an ASW20-C | Papa3 | Soaring | 11 | January 26th 06 06:37 AM |
ASW20 liftup panel mod ,do you want one | goneill | Soaring | 2 | September 8th 04 09:05 PM |
ASW20 owners | Andrew Henderson | Soaring | 0 | April 10th 04 12:28 PM |
Winglets for ASW20 | goneill | Soaring | 5 | February 3rd 04 01:21 AM |
3 view drawing of ASW20 | Kristoffer Raun | Soaring | 0 | January 3rd 04 01:43 AM |
