On Jan 31, 9:58*pm, Westbender wrote:
It's not an "known issue". It's the design. I have an LS1f and it has a similar if not identical trim control. It just applies friction, so it will let go a little when you apply enough forward or aft movement on the stick. The slipping prevents the spring pressure from fighting against you for larger fore/aft movements while still keeping the stick neutral for the small ones. This friction control especially comes into play each time you transition from thermalling to glide or vice-versa. It will move when you push or pull harder during those transitions instead of trying to resist your stick movement. It still takes a slight adjustment on the trim to neutralize completely after a transition, but it gets the trim going in the right direction by slipping and following the stick somewhat. Locking it down would cause considerable spring tension and will fatigue your arm. I've tried that and it's way nicer to fly if you adjust it correctly so it moves. It's an adjustable friction, not a "lock". Dave I find it hard to believe that a trim system that allows uncommanded changes in the stick force gradient could ever have been certificated. Does anyone else believe the trim system was designed to slip in this way? Are any other gliders designed to have a trim system that slips? Andy |
Am 01.02.2011 13:57, Andy wrote:
I find it hard to believe that a trim system that allows uncommanded changes in the stick force gradient could ever have been certificated. Does anyone else believe the trim system was designed to slip in this way? Are any other gliders designed to have a trim system that slips? Andy My ASW24 also tends to 'readjust' the trim setting when moving the stick fully back or front. Our club LS4 has the same behaviour, I think it is working as designed. In real flight, extreme forward/backward movements don't happen to often. -- Peter Scholz ASW24 JE |
Andy wrote:
Does anyone else believe the trim system was designed to slip in this way? Are any other gliders designed to have a trim system that slips? Of the three LS4s I've flown, only one has had a "self adjusting" trim. I assume it's just worn out. |
On 1 Feb., 13:57, Andy wrote:
I find it hard to believe that a trim system that allows uncommanded changes in the stick force gradient could ever have been certificated. *Does anyone else believe the trim system was designed to slip in this way? *Are any other gliders designed to have a trim system that slips? Andy- Zitierten Text ausblenden - - Zitierten Text anzeigen - When new, the trim does (did) not slip on our clubs LS4s. After a few years, they tend to do so and can be adjusted to a certain extent as someone else described. It can normally be adjusted so it holds with full backward stick, but not so full forward. Luckily or coincidentally that's the safer way round. Marcel |
On 2/1/2011 7:57 AM, Andy wrote:
On Jan 31, 9:58 pm, wrote: It's not an "known issue". It's the design. I have an LS1f and it has a similar if not identical trim control. It just applies friction, so it will let go a little when you apply enough forward or aft movement on the stick. The slipping prevents the spring pressure from fighting against you for larger fore/aft movements while still keeping the stick neutral for the small ones. This friction control especially comes into play each time you transition from thermalling to glide or vice-versa. It will move when you push or pull harder during those transitions instead of trying to resist your stick movement. It still takes a slight adjustment on the trim to neutralize completely after a transition, but it gets the trim going in the right direction by slipping and following the stick somewhat. Locking it down would cause considerable spring tension and will fatigue your arm. I've tried that and it's way nicer to fly if you adjust it correctly so it moves. It's an adjustable friction, not a "lock". Dave I find it hard to believe that a trim system that allows uncommanded changes in the stick force gradient could ever have been certificated. Does anyone else believe the trim system was designed to slip in this way? Are any other gliders designed to have a trim system that slips? Andy The trim on my LS-4 stays put through full for and aft travel of the stick when the trim is centered. When the trim is at it's for or aft limit the trim will move slightly with full deflection in the oposite dirction. However our clubs LS4's trim has significant motion in the trim without full diflection. I find my self holding the trim knob to keep it from moving to keep the glider trimmed. Otherwise, I am constantly retrimming the glider while thermaling. Wayne |
Performance loss versus yaw string deflection | Eric Greenwell | Soaring | 7 | July 20th 09 03:27 AM |
What angle creates MAXIMUM air deflection? | [email protected] | General Aviation | 6 | January 30th 07 01:38 AM |
Full deflection = missed approach ??? | pgbnh | Instrument Flight Rules | 33 | October 21st 05 01:57 PM |
P-47/51 deflection shots into the belly of the German tanks, reality or fiction? | [email protected] | Military Aviation | 55 | September 13th 03 06:39 PM |
P-47/51 deflection shots into the belly of the German tanks,reality | ArtKramr | Military Aviation | 131 | September 7th 03 09:02 PM |
