FA: 75 hp Revmaster VW engine w/accessories
Old November 2nd 03, 06:46 AM
Barnyard BOb --
Sorry, looks like I dropped a digit. That link should be:
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2440221477
My EAA Chapter is selling the VW engine that was destined for the Kolb
Mark
III chapter project before determining it put the CG too far aft. The
engine
comes complete with all the accessories, ready to bolt on, including: dual
ignition, carbeurator, alternator, exhaust, carb heat, tach, oil temp, 2
CHT
sensors, AND propellor, cooling scoops, and fairing for a pusher
configuration. Should just need a different prop and exhuast for tractor
configuation.
Worth three times the Buy It Now price!
Come on Barnyard Bob, I know you want this! =D
Eric
Geez, I'd love too, but Morgans won't let me.
He sez it looks too much like an aircraft engine
and has no "benefits" of a real auto engine. g
Have you tried Jay?
He might spring for a pair of these puppies.....
if they ain't too reliable.
Mind blowing....
Absolutely mind blowing.
Barnyard BOb -- over 50 years of successful flight
Old November 2nd 03, 06:03 PM
Morgans
"Barnyard BOb --" wrote in message
Mark
engine
dual
2
CHT
tractor
configuation.
Eric
Have you tried Jay?
Mind blowing....
All I have to say is.....
75 HP VW, my *ss!
My 72 Beetle, barely can pull it's sorry butt up a hill, here in NC.
Not to talk about reliability.
Jim in NC
Old November 2nd 03, 08:19 PM
Barnyard BOb --
O
Eric
Have you tried Jay?
Mind blowing....
75 HP VW, my *ss!
Watch it, fella.
Sounds like your talking about my Ford V-6 truck...
if you'll throw in sorry gas mileage, to boot. g
Barnyard BOb --
Old November 2nd 03, 09:05 PM
Eric Miller
"Morgans" wrote in message
Jim in NC
Are you sure it's the VW's butt that's the problem? big grin
Eric
Old November 2nd 03, 09:12 PM
Morgans
"Eric Miller" wrote in message
et...
Jim in NC
Eric
OOOOH! THAT HURTS! :-)
Although I am slightly over one standard FAA person, not by much.
I do tend to believe Vwub's articles that peg the VW at around 40 hp as much
more realistic. That is a lot of weight for that amount of power.
Jim in NC
Old November 2nd 03, 09:47 PM
Eric Miller
Eric
much
Jim in NC
Let's put it this way... I don't have any room to talk
As far as the engine is concerned I know it's 2180cc, which everyone calls
75hp, though I'm pretty sure that's takeoff power and not continuous.
Using the standard 2 cubic inches per HP that is common to Lycomings and
Continentals, 2180cc = 133 ci = 66.5 HP, which is probably a more realistic
number.
BTW I hope reliability isn't too bad.. I'm gonna be flying behind a Great
Plains 2180cc VW soon!
Eric
Old November 2nd 03, 10:58 PM
Barnyard BOb --
number.
Eric
You know I would never, never rain on your parade g,
but.... the local KR2 here at 3GV hasn't flown in years.
The VW engine quit so many times, the owner-builder
finally wised up and quit, too. No further details.
For other VW info, you can axe my nephoo, John Stricker.
He has a friend that has agonized with 'em for many years.
The aero conversion news is not what you want to hear.
BTW..
Good luck with your 'GREAT PAINS 2180'. {8-D
Ignorance may be bliss, but in aviation...
what you don't know can quickly do you in.
Old November 3rd 03, 01:30 AM
Peter Dohm
Eric
much
Jim in NC
number.
Eric
This assumes you need to turn a 6 foot diameter propeller, which seems pretty
generous for the power. I calculate nearly 80 HP at about 3200 rpm, which is
similar to the crankshaft speed of the Jabiru engines, so the 75 HP figure
should be acheivable.
Hopefully, any resonance problems have been dealt with by the engine or
crankshaft manufacturer, and you are using the same propeller as they recommend.
Peter
Old November 3rd 03, 04:40 AM
Eric Miller
pretty
is
recommend.
Peter
Peter, the VW I'll be flying is on a Dragonfly, which is pretty low to the
ground, and will only be swinging a 52" prop (one recommended by GPAS). Max
RPM on the engine is 3600 (takeoff power), but you're correct that cruise
RPM is 3200.
Bob, I'll accept both your luck and your warning :-)
Eric
Old November 3rd 03, 06:53 AM
Eric Miller
pretty
is
recommend.
Peter
RPM is 3200.
Eric
Objective Engine Discussion Rick Maddy Home Built 26 October 14th 03 04:46 AM
Ford V-6 engine work Corky Scott Home Built 19 August 21st 03 12:04 PM
1710 allison v-12 engine WWII p 38 engine Holger Stephan Home Built 9 August 21st 03 08:53 AM
Gasflow of VW engine Veeduber Home Built 4 July 14th 03 08:06 AM
