On Feb 4, 1:33*am, BruceGreeff wrote:
Lesson learned is that it is far better to learn on something a little higher performance - but if you are solo in such a low performance old lady - you will need some transition training. I'm not an instructor but I've taken dozens of friends/relatives on their first glider flight, almost all in either a Janus (original, flying elevator), Grob Twin Astir, or DG1000, and let them try the controls. Pretty much everyone can at least "keep it between 50 and 60" in a straight line right from the start, and often in a 90 degree turn too. It does help in the Janus to put on 1 notch (6 degrees) of flap, which makes it handle similarly to the Grob. Everyone who has learned to fly at our club in the past several years has done it in the DG1000 and only the DG1000. I don't think there have been any problems except persuading them to get out of the DG and into a PW5 for beginning cross country exploring... |
At 03:05 04 February 2011, Bruce Hoult wrote:
On Feb 4, 1:33=A0am, BruceGreeff wrote: Lesson learned is that it is far better to learn on something a little higher performance - but if you are solo in such a low performance old lady - you will need some transition training. I'm not an instructor but I've taken dozens of friends/relatives on their first glider flight, almost all in either a Janus (original, flying elevator), Grob Twin Astir, or DG1000, and let them try the controls. Pretty much everyone can at least "keep it between 50 and 60" in a straight line right from the start, and often in a 90 degree turn too. It does help in the Janus to put on 1 notch (6 degrees) of flap, which makes it handle similarly to the Grob. Everyone who has learned to fly at our club in the past several years has done it in the DG1000 and only the DG1000. I don't think there have been any problems except persuading them to get out of the DG and into a PW5 for beginning cross country exploring... I haven't read all 42 postings so perhaps someone has already said this, but my understanding is that the 20 is very reluctant to spin, except in landing configuration, ie flaps and wheel down. However in 4 years of flying one, nearly always at 16.6 meters, it never once attempted an inadvertant spin entry. Dave |
On 2/4/2011 8:04 AM, David Salmon wrote:
I haven't read all 42 postings so perhaps someone has already said this, but my understanding is that the 20 is very reluctant to spin, except in landing configuration, ie flaps and wheel down. However in 4 years of flying one, nearly always at 16.6 meters, it never once attempted an inadvertant spin entry. My understanding and experience with my ASW 20C is it is very spin resistant in the landing configuration, i.e., LANDING flaps selected and wheel down. That's because the ailerons move up to a negative position, giving the wing a lot of wash-out. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) |
On Fri, 04 Feb 2011 16:04:31 +0000, David Salmon wrote:
I haven't read all 42 postings so perhaps someone has already said this, but my understanding is that the 20 is very reluctant to spin, except in landing configuration, ie flaps and wheel down. Look at what Andras Maurer has to say - he thinks '20 are very sensitive to small changes in wing profile to the extent that almost every '20 has different handling. Mine would sometimes spin without warning while thermalling at 45 kts in a 40-45 degree bank and zero flap (did it twice) but this was probably related to micro-turbulence in the thermal since I was unable to reproduce that departure in still air later in the day, and usually it was perfectly happy to thermal at that airspeed and bank angle. OTOH mine was a perfect lady in zero and thermal flap at speeds where others have said their '20 would certainly have spun. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
On Feb 4, 5:05*pm, Martin Gregorie
wrote: Look at what Andras Maurer has to say - he thinks '20 are very sensitive to small changes in wing profile to the extent that almost every '20 has different handling. Mine would sometimes spin without warning while thermalling at 45 kts in a 40-45 degree bank and zero flap (did it twice) but this was probably related to micro-turbulence in the thermal since I was unable to reproduce that departure in still air later in the day, and usually it was perfectly happy to thermal at that airspeed and bank angle. OTOH mine was a perfect lady in zero and thermal flap at speeds where others have said their '20 would certainly have spun. I've owned a 20B, plus had several flights each in a couple of different 20s and a 20C. The 20B and 20C both had beautiful handling, no tendency to spin unless forced, and were well mannered in all configurations. One 20 (low serial number, IIRC) would spin without much warning in thermal or landing flap and always in the same direction (over the top if I was turning the opposite way), the other would do so only in landing flap, both seemed a bit twitchy at times. I suspect Schleicher was still learning how to build glass gliders in a repeatable fashion during the 20 production run, the 20B/C show the benefits of experience (plus reduced landing flap travel)... Marc |
On Fri, 04 Feb 2011 18:31:23 -0800, Marc wrote:
I've owned a 20B, plus had several flights each in a couple of different 20s and a 20C. The 20B and 20C both had beautiful handling, no tendency to spin unless forced, and were well mannered in all configurations. One 20 (low serial number, IIRC) would spin without much warning in thermal or landing flap and always in the same direction (over the top if I was turning the opposite way), the other would do so only in landing flap, both seemed a bit twitchy at times. I suspect Schleicher was still learning how to build glass gliders in a repeatable fashion during the 20 production run, the 20B/C show the benefits of experience (plus reduced landing flap travel)... Curiosity: have you any idea what the serials were for those 20s? Mine was 20034, so fairly early... -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
On Feb 5, 8:16*am, Martin Gregorie
wrote: On Fri, 04 Feb 2011 18:31:23 -0800, Marc wrote: I've owned a 20B, plus had several flights each in a couple of different 20s and a 20C. *The 20B and 20C both had beautiful handling, no tendency to spin unless forced, and were well mannered in all configurations. One 20 (low serial number, IIRC) would spin without much warning in thermal or landing flap and always in the same direction (over the top if I was turning the opposite way), the other would do so only in landing flap, both seemed a bit twitchy at times. I suspect Schleicher was still learning how to build glass gliders in a repeatable fashion during the 20 production run, the 20B/C show the benefits of experience (plus reduced landing flap travel)... Curiosity: have you any idea what the serials were for those 20s? Mine was 20034, so fairly early... Other significant sources of variability are rigging of flaps & ailerons, type & condition of seals... and of course now more than half the 20 fleet flies with winglets of one sort or another, these make a difference too (especially the odd installation with more toe on one side than the other). You really do need to treat these ships as individuals. My 20B is a pussycat in #4 and L, it's a little sharp in #3. I fly it at 90% aft, with winglets. It flies straight, the spin behavior is symmetric... but it does have a eccentric lift pin that someone installed to get it that way. Question for Dan: when you swapped ships with the 20B pilot, how much different were you two in weight? Your story could be explained rather neatly if you were a bigger guy than your friend. I haven't flown a 6. Tried to buy one, but the owner wasn't ready to sell. I ended up with the 20B a few weeks later, have not regretted this. Cockpit, controls, landing flaps, landing gear and wheel brake are all better or a lot better on the 20B. However it's certainly true that the 20 flies best if you keep the roll rates about 1/2 of maximum. At high aileron deflections, she gets a little draggy. Not sure if I want to fly a 6... I'm pretty happy with my ship, want to stay that way! -Evan Ludeman / T8 |
On Feb 5, 9:29*am, T8 wrote:
On Feb 5, 8:16*am, Martin Gregorie wrote: On Fri, 04 Feb 2011 18:31:23 -0800, Marc wrote: I've owned a 20B, plus had several flights each in a couple of different 20s and a 20C. *The 20B and 20C both had beautiful handling, no tendency to spin unless forced, and were well mannered in all configurations. One 20 (low serial number, IIRC) would spin without much warning in thermal or landing flap and always in the same direction (over the top if I was turning the opposite way), the other would do so only in landing flap, both seemed a bit twitchy at times. I suspect Schleicher was still learning how to build glass gliders in a repeatable fashion during the 20 production run, the 20B/C show the benefits of experience (plus reduced landing flap travel)... Curiosity: have you any idea what the serials were for those 20s? Mine was 20034, so fairly early... Other significant sources of variability are rigging of flaps & ailerons, type & condition of seals... and of course now more than half the 20 fleet flies with winglets of one sort or another, these make a difference too (especially the odd installation with more toe on one side than the other). You really do need to treat these ships as individuals. *My 20B is a pussycat in #4 and L, it's a little sharp in #3. *I fly it at 90% aft, with winglets. *It flies straight, the spin behavior is symmetric... but it does have a eccentric lift pin that someone installed to get it that way. Question for Dan: when you swapped ships with the 20B pilot, how much different were you two in weight? *Your story could be explained rather neatly if you were a bigger guy than your friend. *I haven't flown a 6. *Tried to buy one, but the owner wasn't ready to sell. *I ended up with the 20B a few weeks later, have not regretted this. Cockpit, controls, landing flaps, landing gear and wheel brake are all better or a lot better on the 20B. *However it's certainly true that the 20 flies best if you keep the roll rates about 1/2 of maximum. *At high aileron deflections, she gets a little draggy. *Not sure if I want to fly a 6... I'm pretty happy with my ship, want to stay that way! -Evan Ludeman / T8 I'm curious to know how the eccentric lift pin works. How much offset can introduced (expressed as an angle or linearly). How is it possible to get any significant offset unless there is excessive play in the main spar pins? Surely the only way that an eccentric lift pin can be used to adjust wing incidence is if it it done before the spars are bored for the main pin bushings. Andy |
On Feb 5, 8:16*am, Martin Gregorie wrote: On Fri, 04 Feb 2011 18:31:23 -0800, Marc wrote: I've owned a 20B, plus had several flights each in a couple of different 20s and a 20C. *The 20B and 20C both had beautiful handling, no tendency to spin unless forced, and were well mannered in all configurations. One 20 (low serial number, IIRC) would spin without much warning in thermal or landing flap and always in the same direction (over the top if I was turning the opposite way), the other would do so only in landing flap, both seemed a bit twitchy at times. I suspect Schleicher was still learning how to build glass gliders in a repeatable fashion during the 20 production run, the 20B/C show the benefits of experience (plus reduced landing flap travel)... Curiosity: have you any idea what the serials were for those 20s? Mine was 20034, so fairly early... Other significant sources of variability are rigging of flaps & ailerons, type & condition of seals... and of course now more than half the 20 fleet flies with winglets of one sort or another, these make a difference too (especially the odd installation with more toe on one side than the other). You really do need to treat these ships as individuals. *My 20B is a pussycat in #4 and L, it's a little sharp in #3. *I fly it at 90% aft, with winglets. *It flies straight, the spin behavior is symmetric... but it does have a eccentric lift pin that someone installed to get it that way. Question for Dan: when you swapped ships with the 20B pilot, how much different were you two in weight? *Your story could be explained rather neatly if you were a bigger guy than your friend. *I haven't flown a 6. *Tried to buy one, but the owner wasn't ready to sell. *I ended up with the 20B a few weeks later, have not regretted this. Cockpit, controls, landing flaps, landing gear and wheel brake are all better or a lot better on the 20B. *However it's certainly true that the 20 flies best if you keep the roll rates about 1/2 of maximum. *At high aileron deflections, she gets a little draggy. *Not sure if I want to fly a 6... I'm pretty happy with my ship, want to stay that way! -Evan Ludeman / T8 Evan, I swapped with Tom Serkowski (5Z) and I think it was a 20B (stiff wings rather than floppy). I'm a bit taller than Tom but I think we're about the same weight and we both flew dry. After landing, I asked him what he thought and he held up the index finger of one hand and placed the palm of the other hand down on it indicating balancing on the point of a needle. My reply to his question was that I thought the 20 was on rails, meaning it was difficult to roll. I'm sure that's because of the difference in handling qualities of the two - the LS-6a being extremely light on the controls. Hope that answers your question. |
On Feb 5, 5:16*am, Martin Gregorie
wrote: On Fri, 04 Feb 2011 18:31:23 -0800, Marc wrote: I've owned a 20B, plus had several flights each in a couple of different 20s and a 20C. *The 20B and 20C both had beautiful handling, no tendency to spin unless forced, and were well mannered in all configurations. One 20 (low serial number, IIRC) would spin without much warning in thermal or landing flap and always in the same direction (over the top if I was turning the opposite way), the other would do so only in landing flap, both seemed a bit twitchy at times. I suspect Schleicher was still learning how to build glass gliders in a repeatable fashion during the 20 production run, the 20B/C show the benefits of experience (plus reduced landing flap travel)... Curiosity: have you any idea what the serials were for those 20s? Mine was 20034, so fairly early... The worst of the two was in the single digits, it was destroyed several years later in a fatal stall/spin accident with a low time pilot at the controls. The other one I have no idea about. I'll also mention that the most important reason I had at the time for buying a used 20B instead of a 20 was the automatic elevator hookup, I've had two soaring friends die as a result of disconnected elevators, and both were far more diligent pilots than I... Marc |
ELT Mounting for an ASW20-C | Papa3 | Soaring | 11 | January 26th 06 06:37 AM |
ASW20 liftup panel mod ,do you want one | goneill | Soaring | 2 | September 8th 04 09:05 PM |
ASW20 owners | Andrew Henderson | Soaring | 0 | April 10th 04 12:28 PM |
Winglets for ASW20 | goneill | Soaring | 5 | February 3rd 04 01:21 AM |
3 view drawing of ASW20 | Kristoffer Raun | Soaring | 0 | January 3rd 04 01:43 AM |
