Taxi calculator? (propeller type and speed, aircraft weight, taxi speed)
Old February 5th 11, 01:56 PM posted to rec.aviation.military,rec.aviation.piloting,rec.aviation.homebuilt
Brent[_2_]
Default Taxi calculator? (propeller type and speed, aircraft weight, taxi speed)
Sounds like an airboat hovercraft or some other type of propeller driven
ground effect vehicle
Actually it sounds closer to something like a skateboard with as prop motor
and a user on it. you are missing a huge amount of variables and for props,
pitch, density altitude, motors, and at speeds that slow your in the wrong
group because very few things, If Any, in any of these groups fly at that
speed.
And aircraft move slow taxiing because they are not meant to be ground
vehicles they usually have very narrow stances and high centers of gravity
compared to a ground vehicle as soon as they have any kind of airspeed they
want to fly.
Look up an RC or Aeronautical engineering group on usenet or elsewhere. you
need to find design people not pilots
"Flaps_50!" wrote in message
On Feb 4, 11:55 am, John Doe wrote:
Is there such a calculation/formula? How can you tell what
propeller to use, how fast it should rotate, and how much weight
it can push along the ground?
Specifically... I would like to tell what sort and size of
propeller rotating at what speed, in calm air to push 100 or 200
pounds on smooth and level pavement with zero rolling resistance
to about 20 mph.
20 mph is too fast for taxying. What are you asking about -zero
rolling resistance????
Cheers
Taxi calculator? (propeller type and speed, aircraft weight, taxi speed) John Doe[_4_] General Aviation 0 February 3rd 11 10:55 PM
Taxi speed Hilton Piloting 21 April 10th 07 01:03 AM
Any info on WC Pye Course & Speed Calculator Jack McAdams Owning 2 June 23rd 04 03:55 PM
Any info on WC Pye Course & Speed Calculator Jack McAdams Piloting 2 June 23rd 04 03:55 PM
