ASW20 or LS6
Old February 5th 11, 05:54 PM posted to rec.aviation.soaring
T8
Default ASW20 or LS6
On Feb 5, 11:59*am, Andy wrote:
Surely the only way that an eccentric lift pin can be used to adjust
wing incidence is if it it done before the spars are bored for the
main pin bushings.
Sorry, I am both reading comprehension *and* math challenged today it
seems (I have a medical excuse, it's temporary, fortunately!).
Previous answer to this deleted.
The clearance on the main pins I don't know. I'd guess it's around
0.003" judging by feel, but that's a guess, I've never paid too much
attention. The change in clearance due to an incidence offset is easy
to calculate though, and it's about 0.0005" total on the depth of the
center spar stub for a 1mm offset pin. Those are all armchair
numbers, but the conclusion (supported by experience) is "No Problem".
-Evan Ludeman / T8
ELT Mounting for an ASW20-C Papa3 Soaring 11 January 26th 06 06:37 AM
ASW20 liftup panel mod ,do you want one goneill Soaring 2 September 8th 04 09:05 PM
ASW20 owners Andrew Henderson Soaring 0 April 10th 04 12:28 PM
Winglets for ASW20 goneill Soaring 5 February 3rd 04 01:21 AM
3 view drawing of ASW20 Kristoffer Raun Soaring 0 January 3rd 04 01:43 AM
