Question about Gelcoat
Old February 15th 11, 07:35 PM posted to rec.aviation.soaring
Tim Mara
Default Question about Gelcoat
read the below direct from Heir Webers (DG) website....Just happens I was
there as this conversation went on..
what I knew then was that Schwabbellack was no longer used and hadn't been
used for many years...it didn't seem to stop Mr. Weber from using this as
sales promo.regardless of how inaccurate it was...
tim
Schwabbellack" or "Vorgelat" - which one is "better"?
- there are differences even in the "standard finish".
At the SSA convention 2004 in Atlanta I had this interesting conversation:
Our new LS agent said to me: "Friedel, I see gliders from all over the
United States in my workshop for re-gelling. Some of the gliders really look
pretty awful with big cracks and yellow patches. I see gliders from
Rolladen-Schneider, .... gliders, lots of ..... gliders, but never a "DG".
Why is that?"
Wilhelm Dirks was also present and gave this simple explanation:
For several years now the other manufacturers have been using "T35-Vorgelat"
for spraying in the moulds. Only DG has always been using the so-called
"Schwabbellack".
The T35 offers significant production advantages to the manufacturer. You
can spray all moulds at once and leave them, and then carry on the next
morning. It is also possible to roll the resin into the dried gelcoat. With
Schwabbellack however you have to work using the wet-in-wet technique, which
is why one has to start working on it at 5am, spraying only one mould at a
time, finishing the complete mould and only two hours later carrying on with
the next one, and the next one, etc. This is of course a far more
complicated manufacturing process and also has cost implications.
HOWEVER: There's no way around it: Schwabbellack is better - both regarding
the look of new gliders as well as its durability. I don't think I'm
boasting when I say that DG is well-known everywhere for a very good finish.
And now you know why!
The staff in our external finish partner company FBS keep telling us that
customers, when having their gliders re-gelled, quite often only want one
specific finish - and that's a finish in "DG quality"!
Everybody knows what that is, and it says it all, doesn't it?
"Herbert kilian" wrote in message
On Feb 11, 3:12 pm, bildan wrote:
On Feb 11, 8:08 am, Walt Connelly Walt.Connelly.
I see planes that are "refinished" in polyurethane. Is this different
from GelCoat? I have looked at ships whose gelcoat is horrible and
understand that it can cost in excess of 20K dollars to refinish
properly. Is PU more durable than Gelcoat? Is one better than the
other? The glass vs aluminum thing has me leaning toward aluminum big
time. I don't ever expect to be competing seriously in cross country
competition so a bird for local fun might be adequate.
Walt
Walt Connelly
Don't be too quick to dismiss glass - it will last as long if not
longer than metal. Take a look at a 1960's Labelle - some of them
still look nearly new. Too bad they don't still use the same gel coat
material.
Factory gelcoat can crack if not well cared for but cracks don't
necessarily mean the underlying structure is damaged in any way.
Clean, wax regularly & don't leave it tied out in the weather. PU is
a well known material which will outlast gelcoat but requires a little
more expertise to patch so it doesn't show.
The best advice is buy the glider with the best trailer.
Bill,
There's a number of German workers dying from cancer or already dead
from handling the Schwabbellack gel-coat that you refer to. The stuff
was toxic and it's good they discontinued it, good riddance.
Regarding trailers, the fiberglass shells are a case study in the very
limited life expectancy of the currently used coatings, they look
horrible after 10-15 years max unless kept indoors.
__________ Information from ESET NOD32 Antivirus, version of virus signature
database 5877 (20110215) __________
The message was checked by ESET NOD32 Antivirus.
http://www.eset.com
__________ Information from ESET NOD32 Antivirus, version of virus signature database 5877 (20110215) __________
http://www.eset.com
Old February 16th 11, 12:31 AM posted to rec.aviation.soaring
Morgans[_2_]
Default Question about Gel coat
"Tim Mara" wrote
Bill,
So what is different about the gel coats used in most pleasure boats and
the non toxic airplane gel coats? I see boats that are kept out in the sun
nearly year round, and with a couple waxings per year and a polish out every
few years, they seem very durable and good looking.
Jim in NC
Old February 16th 11, 02:35 AM posted to rec.aviation.soaring
Andy[_1_]
On Feb 15, 5:31*pm, "Morgans" wrote:
"Tim Mara" wrote
Bill,
from handling the Schwabbellack gel-coat that you refer to. *The stuff
*So what is different about the gel coats used in most pleasure boats and
the non toxic airplane gel coats? *I see boats that are kept out in the sun
Jim in NC
When I asked what the finish was on my Cobra trailer I was told it was
marine gel coat. Those may not have been the exact words, I'd have to
hunt for the email, but no doubt the message was - same as used on
boats.
Andy
Buffing and Waxing Gelcoat question Discus 44 Soaring 1 March 25th 10 09:45 PM
another gelcoat story Brad[_2_] Soaring 29 August 28th 08 01:26 AM
Gelcoat sag? [email protected] Soaring 10 December 17th 07 08:07 PM
First Glider no gelcoat Doug Reeve Soaring 0 February 10th 06 10:05 AM
Fiberglass/gelcoat repair question Kilo Charlie Soaring 9 April 19th 05 03:30 PM
