This is going to be much more productive if you tell us what make,
model, type (mechanical? Electric? Pellet?) vario you're talking about. John Cochrane Thanks JC appreciate you chiming in. It is mechanical, has two ports on the back, one says static, other capacity. Emblem on front has a A W written on it. I know it's more complicated than just plugging in the static line and the capacity line. Not wanting to use it as a simple vario. I like the netto idea. |
On Feb 15, 10:39*pm, Scott Alexander
wrote: This is going to be much more productive if you tell us what make, model, type (mechanical? Electric? Pellet?) vario you're talking about. John Cochrane Thanks JC appreciate you chiming in. It is mechanical, has two ports on the back, one says static, other capacity. *Emblem on front has a A W written on it. *I know it's more complicated than just plugging in the static line and the capacity line. *Not wanting to use it as a simple vario. *I like the netto idea. It sounds like you have a regular mechanical vario (Winter perhaps?). Netto behavior is obtained by putting a calibrated leak from your capacity to the static line, or a TE netto by leaking to the TE line. Reichmann describes setting up a netto in Cross Country Soaring. I'll try some ascii art: +----------+ | vario | | +----------+--- TE probe | | | | +-----+---X +----------| | | capacity I hope that comes out OK. The X in the line from the capacity bottle to the TE line has to have a capillary tube in it. Start with a longer tube and cut it down until the vario reads 0 in still air. Remember also to greatly separate this vario from others on the same TE line; you will get cross talk between the varios so that none of them read right otherwise. What is simpler is to have one of the modern fancy varios that will give you netto readings if you want. My LX160 (not very modern, really) will display netto during cruise if it's configured properly. The various speed to fly varios (B50, C302, VW1020, LX, etc.) give you readings of what the air is doing compared to your polar. -- Matt |
On Feb 15, 8:58*pm, mattm wrote:
On Feb 15, 10:39*pm, Scott Alexander wrote: This is going to be much more productive if you tell us what make, model, type (mechanical? Electric? Pellet?) vario you're talking about. John Cochrane Thanks JC appreciate you chiming in. It is mechanical, has two ports on the back, one says static, other capacity. *Emblem on front has a A W written on it. *I know it's more complicated than just plugging in the static line and the capacity line. *Not wanting to use it as a simple vario. *I like the netto idea. It sounds like you have a regular mechanical vario (Winter perhaps?). Netto behavior is obtained by putting a calibrated leak from your capacity to the static line, or a TE netto by leaking to the TE line. Reichmann describes setting up a netto in Cross Country Soaring. I'll try some ascii art: +----------+ | *vario * | | * * * * * +----------+--- * TE probe | * * * * * | * * * * * *| | * * * * * +-----+---X +----------| * * *| * * * * * * * * * *| * * * * * * * *capacity I hope that comes out OK. *The X in the line from the capacity bottle to the TE line has to have a capillary tube in it. *Start with a longer tube and cut it down until the vario reads 0 in still air. *Remember also to greatly separate this vario from others on the same TE line; *you will get cross talk between the varios so that none of them read right otherwise. What is simpler is to have one of the modern fancy varios that will give you netto readings if you want. *My LX160 (not very modern, really) will display netto during cruise if it's configured properly. *The various speed to fly varios (B50, C302, VW1020, LX, etc.) give you readings of what the air is doing compared to your polar. -- Matt Dick Ball wrote an article about calibrating varios a number of years ago that has a very nice section on hooking up netto systems. I have a PDF copy if you want to contact me by email. Thanks, Craig |
![]() "Scott Alexander" wrote in message ... It is mechanical, has two ports on the back, one says static, other capacity. Emblem on front has a A W written on it. I know it's more complicated than just plugging in the static line and the capacity line. but it is.....that simple.. the "W" in the face is "Winter" ...if you want to use it as a basic mechanical variometer as it was intended....connect to static or TE (TE is simply a "compensated" Static and connect the other side to the proper size capacity bottle.....keeping in mind that especially these very odd range variometers can and usually do use a .90liter, or even 1.8 liter capacity bottle and not the normal .45 used on almost every other variometer. also remember that if this is a very old variometer just becuase the needle appears to move in the correct direction doesn't mean it's any where close to be accuarte anymore, most of these older instruments really need to be overhauled even when kept in reasonibly good storage after 15-20 years old. I see these all the time that are closer to 40 years old and the needles move..but far from the way they were intended. tim -- Please visit the Wings & Wheels website at www.wingsandwheels.com Not wanting to use it as a simple vario. I like the netto idea. __________ Information from ESET NOD32 Antivirus, version of virus signature database 5880 (20110216) __________ The message was checked by ESET NOD32 Antivirus. http://www.eset.com |
On Feb 16, 1:55*pm, "Tim Mara" wrote:
"Scott Alexander" wrote in message ... It is mechanical, has two ports on the back, one says static, other capacity. *Emblem on front has a A W written on it. *I know it's more complicated than just plugging in the static line and the capacity line. but it is.....that simple.. the "W" in the face is "Winter" ..if you want to use it as a basic mechanical variometer as it was intended....connect to static or TE (TE is simply a "compensated" Static and connect the other side to the proper size capacity bottle.....keeping in mind that especially these very odd range variometers can and usually do use a .90liter, or even 1.8 liter capacity bottle and not the normal .45 used on almost every other variometer. also remember that if this is a very old variometer just becuase the needle appears to move in the correct direction doesn't mean it's any where close to be accuarte anymore, most of these older instruments really need to be overhauled even when kept in reasonibly good storage after 15-20 years old. I see these all the time that are closer to 40 years old and the needles move..but far from the way they were intended. tim -- Please visit the Wings & Wheels website atwww.wingsandwheels.com Not wanting to use it as a simple vario. *I like the netto idea. __________ Information from ESET NOD32 Antivirus, version of virus signature database 5880 (20110216) __________ The message was checked by ESET NOD32 Antivirus. http://www.eset.com Hey, speaking of overhauling mechanical varios, I have a Sage vario that's about 10 years old in my plane. The plane has always lived in its trailer out at the airport (at least since it got this vario). How out-of-whack is my Sage going to be after that amount of time in the plane? I have to admit, I barely ever look at the thing. I've trained myself to avoid looking at the varios -- maybe once per scan to compare the 20s avg with the achieved climb rate displayed on my pda. When my LX vario went haywire on a flight last year I could barely cope. Also, speaking of the LX160, would any of you LX people have the chip on hand to upgrade it to v2.12? The last time I looked the shipping charge from Slovenia was more than the chip cost! -- Matt |
![]() "mattm" wrote in message ... On Feb 16, 1:55 pm, "Tim Mara" wrote: Hey, speaking of overhauling mechanical varios, I have a Sage vario that's about 10 years old in my plane. The plane has always lived in its trailer out at the airport (at least since it got this vario). How out-of-whack is my Sage going to be after that amount of time in the plane? I have to admit, I barely ever look at the thing. I've trained myself to avoid looking at the varios -- maybe once per scan to compare the 20s avg with the achieved climb rate displayed on my pda. When my LX vario went haywire on a flight last year I could barely cope. unless it's leaking it's probably OK .10 years is a relatively short time in instrument life...the Sage has very few moving parts and no jeweled movements or mechanical bearings that can wear...they are sensative to over-adjusting and can have leaks appear but these are things you can check with some soapy water...aside from thsi as long as it doesn't get any hard hits it should perform for years. Also, speaking of the LX160, would any of you LX people have the chip on hand to upgrade it to v2.12? The last time I looked the shipping charge from Slovenia was more than the chip cost! I have shipments coming from there frequently if you want me to place it on my orders just let me know give me a call thanks tim -- Please visit the Wings & Wheels website at www.wingsandwheels.com -- Matt __________ Information from ESET NOD32 Antivirus, version of virus signature database 5881 (20110216) __________ The message was checked by ESET NOD32 Antivirus. http://www.eset.com __________ Information from ESET NOD32 Antivirus, version of virus signature database 5881 (20110216) __________ The message was checked by ESET NOD32 Antivirus. http://www.eset.com |
How to build a Netto | Pat Russell[_2_] | Soaring | 3 | May 14th 10 12:17 PM |
Moore Variometer | EdByars | Soaring | 0 | April 13th 10 04:29 PM |
WTB: Sage Model B Netto Total Energy Box | November Bravo | Soaring | 0 | March 15th 05 03:10 PM |
NETTO Question | Shoulbe | Soaring | 5 | September 16th 03 05:21 PM |
Cambridge 302 and Super netto | Ross Biggar | Soaring | 13 | September 13th 03 08:57 PM |
