I've run a few UK Interclub League weekends, which are contest between
4 or 5 local clubs, 15-20 gliders in three classes based on experience (Novice, Intermediate and Pundit). Andy's list is very complete. There are four main areas to be covered: Task setting (and general oversight) - this is your job Then three other areas which I'd recommend farming out to volunteers, properly briefed: Met (who need to liaise with you to help you set tasks) Launch point operations (setting up the grid, running the team to launch the grid, etc) Scorer (downloads logger traces, works out winner(s)) Doing all four is too much, particularly if you want to fly yourself, though combining met and task setting is possible. If your grid is small (20) then I found that abandoning a formal grid and simply saying "launch whenver you're ready, first come first served" worked very well. Normal club operations could carry on, with competition pilots allowed to push into the queue. Admittedly we usually had typically weak English conditions so there was lots of "After you dear boy" rather than races to the launcpoint. On Feb 21, 8:06*pm, Andy wrote: On Feb 21, 9:38*am, vontresc wrote: Hi, I was talking to some of the othe VSA members at the conference in Philly, and more recently at the Chicago Glider Council meeting about having some racing tasks set up during the VSA rally in Lawrenceville this summer. Since sveral folks thought that this was a great idea, I was sort of volunteered into being the CD. I have been checking out the contest info on the SSA website, and there is a lot of good info there but I am looking for something like "CD for dummies". The plan is to call simple tasks and score them using sports class rules. Thanks Peter von Tresckow Ka-6Cr Here is the CD section from the draft 2011 Arizona Soaring Association series rules: "• * * * A Contest Director shall be nominated for each contest day by the Contest Manager. • * * The nominated CD will normally be a volunteer contestant in the contest series. • * * The CD shall be responsible for running the contest day at the site designated by the CM. • * * The CD may fly as a contestant but only if that does not prevent all CD responsibilities being met. • * * CD responsibilities shall be as follows: o * * * *Research the latest soaring forecasts for the task area prior to the pilots meeting o * * * Coordinate with the tow pilots or commercial operation wrt grid and launch time o * * * Select contest task consistent with the weather forecast. The allowable task types are Assigned Task (AT), Modified Assigned Task (MAT), Turn Area Task (TAT). *When selecting the task type, task distance, and task route the CD shall consider the range of glider performance, range of pilot experience, and the nature of the terrain. o * * * Announce/communicate the pilot’s meeting time at least one hour prior to the meeting o * * * “Chair” the pilots meeting in traditional format (previous day winner; *weather briefing; announce task, format, grid and launch time; etc) o * * * Initiate a pilot sign up using a standard form obtained form the contest manager or scorer. o * * * Prepare a task sheet using a standard form obtained from the contest manager or scorer. o * * * Monitor the launch operation and set and announce task open times o * * * The CD is encouraged to provide the task and race format at the pilots meeting but may delay this until grid time if the weather is indeterminate o * * * Ensure that all pilots are accounted for at the end of the contest day. o * * * Provide the scorer with completed sign up sheets and task definition sheets. email me if you want the complete draft rule set. Andy |
1st Contest. Where Should I Go? | Barry[_4_] | Soaring | 14 | December 1st 09 03:57 PM |
KS Duo At R2 Contest | Karl Striedieck | Soaring | 0 | April 22nd 09 01:51 AM |
Name that contest | Bob Johnson | Soaring | 0 | April 12th 05 04:47 AM |
SENIORS CONTEST | Gordon Schubert | Soaring | 62 | March 23rd 05 06:40 AM |
SENIORS CONTEST | Gordon Schubert | Soaring | 1 | March 16th 05 12:03 AM |
