On Feb 27, 7:13*pm, Darryl Ramm wrote:
Because its not a ASEL aircraft. What do you would think would happen if you set loose a typical power pilot in a self launch motorglider? What would happen if you set him loose in a sea plane, a twin or a jet? It's at least arguable the skill gap between single engine land and any of those is comparable to that between a pure glider and a self-launcher yet they each require a specific rating. Some motorgliders easily approach the complexity and work load of flying a light twin. I think Walt has a good question. Bill Daniels |
On Feb 28, 5:16*pm, bildan wrote:
Some motorgliders easily approach the complexity and work load of flying a light twin. I think Walt has a good question. Is there a demonstrated problem? Are there people killing themselves in motorgliders due to engine handling issues? Is it due to something that experience in a C152 would help with? If people are having any problems specific to motorgliders I imagine it's due to being distracted putting the engine away, or attempting to start and failing and not having a landing field picked out. Time banging around a circuit in a 152 isn't going to do anything for that. |
I recently asked (on a mainly GA Power pilots’) forum what extra
hazards a glider pilot might need to think about, when acquiring a self-sustaining glider. (I am getting a FES, but not the self-launch variety.) Many of the responses related to internal combustion engines, rather than electric. For what it is worth, this was my question and my first thought, followed by is the list I got from various people, edited to avoid duplications; ------------- Normally, flying a pure glider, there are certain hazards that power pilots all too frequently fall victim to, that we don't. One example is pressing on into increasingly bad weather, lowering cloud base, often resulting in CFIT when the plan B of turning back turns out not to work. In a glider, it is almost impossible to be in this position in the first place, because you can't maintain height under a lowering cloud base that is turning to rain or worse. In fact you wouldn't be going cross-country initially in those conditions. By next season, I hope to have a sustainer engine in my glider. This will enable me to cruise for about one hour at 50 knots at level height (e.g., to get home instead of landing out in a farmer’s field). Although it is unlikely that I would be going cross-country in the conditions described above, it is conceivable that I might use thermals to reach a patch of bad weather, and so need to avoid the temptation to fall into the same trap and end up with CFIT. My question is: what other pitfalls, not normally faced by a glider pilot, might I now have to be aware of, when going into sustained powered flight for up to an hour? (I cannot take off with the sustainer motor – still need a conventional glider launch by winch or aerotow.) --------------------- Engine fires - not something a glider pilot normally has to worry about. Effect of icing. Carb ice. Engine failures - you'd have to go through some of the same drills as a powered pilot. The effect on your compass. It will need swinging twice - once with the engine on and working and once in the pure glider mode. The effect of propwash on the handling. if it blows over the elevator and or rudder it will make them much more powerful and also torque and gyroscopic effect will alter the handling. Depending on where the thrust line is it will also affect the pitch, particularly if it is pylon mounted. Added weight of engine and fuel will complicate C of G /Ballast/etc calculations. Fuel contamination will be a 'new' problem. Mag problems, freezing of moisture on ignition. Fuel pump problems - assuming your engine is above the tank.. Noise and vibration will increase fatigue. Vibration will affect fatigue life of glider sealing of hatches etc assuming your engine is a 'pop out'. 'Jamming' of controls from cockpit to engine potential 'heating' of cockpit when engine is running. Extra drag if engine sticks in 'out' position. ---------------------- What do others think? Chris N. |
On 2/28/2011 2:19 AM, Chris Nicholas wrote:
I recently asked (on a mainly GA Power pilots’) forum what extra hazards a glider pilot might need to think about, when acquiring a self-sustaining glider. (I am getting a FES, but not the self-launch variety.) Many of the responses related to internal combustion engines, rather than electric. For what it is worth, this was my question and my first thought, followed by is the list I got from various people, edited to avoid duplications; I address some of the problems in my "A Guide to Self-launching Sailplane Operation Mar/2004" (tinyurl.com/yfs7tnz); however, because it's a sustainer with simple "retraction" and electric, you avoid many/most of the problems. Read my Guide, then after a season with the FES, let me know what _should_ have been in the Guide to prepare you for your glider. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-launching Sailplane Operation Mar/2004" Much of what you need to know tinyurl.com/yfs7tnz |
Eric, thanks. Looks very comprehensive. I will read it over time,
and get back to you if I have anything to add. Regards - Chris. |
![]() Quote:
I have a commercial rating for both airplanes and gliders so I think I see both sides of the equation. In my mind, the glider pilot's skill is greater than an equivalent time ASEL type. I learned things I never knew and developed greater skills in flying than I had when I transitioned from power to gliders., But when an ASEL type want to fly a multi, he is required to get a multi engine rating and it appears on his license. Same with seaplane and other different types of ratings. I believe the endorsement is all that is required of a glider pilot for a motor glider, am I right? For the record I have seen a high time, highly experienced power and glider pilot make a major blunder with his motor out. Scared the crappola out of me and I was standing on the ground at the time. The bottom line is that proper training and check outs are everything. Walt |
Walt
It does not become an ASEL, its type certified (or experimental) as a glider. Now it might be possible if somebody really wanted to have some touring motorglider certified under either - and some may well have been. Asking for them to be ASEL would be the *last* think I would want, but I am concerned that the self launch endorsement training can be problematic - its possible for somebody to sign a pilot off but as Bill says some of these are complex and things like system understanding, pre-flight/simple maintenance and emergency procedures need to be really gone through well. And all this vary widely between types--especially between a typical retracting mast and touring style motorglider. And chance to practice emergency procedures in a complex single seater without the instructor being there is reduced, but this at least better get talked about, and the instructor better make sure you know where to put your fingers when things go pear shaped. I've met motorglider owners who seem oblivious to about simple stuff like the proper oil to use, how the lubrication system and different alarms on the engines work -- scary stuff. Did they ever read the pilot or maintenance manual? I used to have a power license, I did my formal self launch sign off in a Grob 109, not at all relevant to the ASH-26E that I fly, but both the (very experienced) instructor and I knew that and he pushed me on a nasty windy day. In reality it was really a ASEL taildragger sign off, but we talked though some of the nasty stuff with retracting mast motorgliders. Then through the ASH-26E owners community I ended up sitting down with a current very experienced owner and did an informal ground school then talked things over with an instructor/examiner who signed me off in the ASH-26E. I felt like I had pretty good training, but YMMV. There are some good instructors out here who can teach this stuff, but there are just not many of them, and not many two seat motorgliders. Darryl |
On Feb 28, 7:53*am, Walt Connelly Walt.Connelly.
wrote: bildan;763822 Wrote: On Feb 27, 7:13*pm, Darryl Ramm wrote: - Because its not a ASEL aircraft. What do you would think would happen if you set loose a typical power pilot in a self launch motorglider?- What would happen if you set him loose in a sea plane, a twin or a jet? *It's at least arguable the skill gap between single engine land and any of those is comparable to that between a pure glider and a self-launcher yet they each require a specific rating. Some motorgliders easily approach the complexity and work load of flying a light twin. I think Walt has a good question. Bill Daniels I think my point was missed. *I am not opposed to the glider pilot having an engine, I was curious as to how one got around the ASEL situation. *In my mind if you put an engine on and glider it becomes an ASEL. * Take the pure motor glider with an engine hanging on the nose. Could an ASEL pilot check out in one and fly it legally? *Perhaps a light sport pilot could do the same? *Sure these things are gonna float like no conventional ASEL would but I'm just asking a question. I need to check the regs on this for myself when I get the chance but I realize this forum contains a plethora of information. I have a commercial rating for both airplanes and gliders so I think I see both sides of the equation. *In my mind, the glider pilot's skill is greater than an equivalent time ASEL type. *I learned things I never knew and developed greater skills in flying than I had when I transitioned from power to gliders., *But when an ASEL type want to fly a multi, he is required to get a multi engine rating and it appears on his license. *Same with seaplane and other different types of ratings. I believe the endorsement is all that is required of a glider pilot for a motor glider, am I right? For the record I have seen a high time, highly experienced power and glider pilot make a major blunder with his motor out. *Scared the crappola out of me and I was standing on the ground at the time. *The bottom line is that proper training and check outs are everything. Walt -- Walt Connelly My $ .02 What makes an aircraft a motor glider is the "span loading", which determines, more than a power source, the flight characteristics of an aircraft. Mike |
On Feb 28, 1:18*pm, mike wrote:
On Feb 28, 7:53*am, Walt Connelly Walt.Connelly. wrote: bildan;763822 Wrote: On Feb 27, 7:13*pm, Darryl Ramm wrote: - Because its not a ASEL aircraft. What do you would think would happen if you set loose a typical power pilot in a self launch motorglider?- What would happen if you set him loose in a sea plane, a twin or a jet? *It's at least arguable the skill gap between single engine land and any of those is comparable to that between a pure glider and a self-launcher yet they each require a specific rating. Some motorgliders easily approach the complexity and work load of flying a light twin. I think Walt has a good question. Bill Daniels I think my point was missed. *I am not opposed to the glider pilot having an engine, I was curious as to how one got around the ASEL situation. *In my mind if you put an engine on and glider it becomes an ASEL. * Take the pure motor glider with an engine hanging on the nose.. Could an ASEL pilot check out in one and fly it legally? *Perhaps a light sport pilot could do the same? *Sure these things are gonna float like no conventional ASEL would but I'm just asking a question. I need to check the regs on this for myself when I get the chance but I realize this forum contains a plethora of information. I have a commercial rating for both airplanes and gliders so I think I see both sides of the equation. *In my mind, the glider pilot's skill is greater than an equivalent time ASEL type. *I learned things I never knew and developed greater skills in flying than I had when I transitioned from power to gliders., *But when an ASEL type want to fly a multi, he is required to get a multi engine rating and it appears on his license. *Same with seaplane and other different types of ratings.. I believe the endorsement is all that is required of a glider pilot for a motor glider, am I right? For the record I have seen a high time, highly experienced power and glider pilot make a major blunder with his motor out. *Scared the crappola out of me and I was standing on the ground at the time. *The bottom line is that proper training and check outs are everything. Walt -- Walt Connelly My $ .02 What makes an aircraft a motor glider is the "span loading", which determines, more than a power source, the flight characteristics of an aircraft. Mike The FAA certified Spaceship One as a glider. Presumably this is because it didn't have an engine and they didn't know how to certify an aircraft with a rocket motor. I'm not sure that it would meet your "span loading" criterion! Mike |
On Feb 28, 1:35*pm, Mike the Strike wrote:
On Feb 28, 1:18*pm, mike wrote: On Feb 28, 7:53*am, Walt Connelly Walt.Connelly. wrote: bildan;763822 Wrote: On Feb 27, 7:13*pm, Darryl Ramm wrote: - Because its not a ASEL aircraft. What do you would think would happen if you set loose a typical power pilot in a self launch motorglider?- What would happen if you set him loose in a sea plane, a twin or a jet? *It's at least arguable the skill gap between single engine land and any of those is comparable to that between a pure glider and a self-launcher yet they each require a specific rating. Some motorgliders easily approach the complexity and work load of flying a light twin. I think Walt has a good question. Bill Daniels I think my point was missed. *I am not opposed to the glider pilot having an engine, I was curious as to how one got around the ASEL situation. *In my mind if you put an engine on and glider it becomes an ASEL. * Take the pure motor glider with an engine hanging on the nose. Could an ASEL pilot check out in one and fly it legally? *Perhaps a light sport pilot could do the same? *Sure these things are gonna float like no conventional ASEL would but I'm just asking a question. I need to check the regs on this for myself when I get the chance but I realize this forum contains a plethora of information. I have a commercial rating for both airplanes and gliders so I think I see both sides of the equation. *In my mind, the glider pilot's skill is greater than an equivalent time ASEL type. *I learned things I never knew and developed greater skills in flying than I had when I transitioned from power to gliders., *But when an ASEL type want to fly a multi, he is required to get a multi engine rating and it appears on his license. *Same with seaplane and other different types of ratings. I believe the endorsement is all that is required of a glider pilot for a motor glider, am I right? For the record I have seen a high time, highly experienced power and glider pilot make a major blunder with his motor out. *Scared the crappola out of me and I was standing on the ground at the time. *The bottom line is that proper training and check outs are everything. Walt -- Walt Connelly My $ .02 What makes an aircraft a motor glider is the "span loading", which determines, more than a power source, the flight characteristics of an aircraft. Mike The FAA certified Spaceship One as a glider. * Presumably this is because it didn't have an engine and they didn't know how to certify an aircraft with a rocket motor. I'm not sure that it would meet your "span loading" criterion! Mike It is not "MY" criterion! The FAA made it "THEIR" criterion. Mike |
selflaunch glider | Udo | Soaring | 1 | November 19th 07 08:32 AM |
