On Feb 28, 1:35*pm, Mike the Strike wrote:
On Feb 28, 1:18*pm, mike wrote: On Feb 28, 7:53*am, Walt Connelly Walt.Connelly. wrote: bildan;763822 Wrote: On Feb 27, 7:13*pm, Darryl Ramm wrote: - Because its not a ASEL aircraft. What do you would think would happen if you set loose a typical power pilot in a self launch motorglider?- What would happen if you set him loose in a sea plane, a twin or a jet? *It's at least arguable the skill gap between single engine land and any of those is comparable to that between a pure glider and a self-launcher yet they each require a specific rating. Some motorgliders easily approach the complexity and work load of flying a light twin. I think Walt has a good question. Bill Daniels I think my point was missed. *I am not opposed to the glider pilot having an engine, I was curious as to how one got around the ASEL situation. *In my mind if you put an engine on and glider it becomes an ASEL. * Take the pure motor glider with an engine hanging on the nose. Could an ASEL pilot check out in one and fly it legally? *Perhaps a light sport pilot could do the same? *Sure these things are gonna float like no conventional ASEL would but I'm just asking a question. I need to check the regs on this for myself when I get the chance but I realize this forum contains a plethora of information. I have a commercial rating for both airplanes and gliders so I think I see both sides of the equation. *In my mind, the glider pilot's skill is greater than an equivalent time ASEL type. *I learned things I never knew and developed greater skills in flying than I had when I transitioned from power to gliders., *But when an ASEL type want to fly a multi, he is required to get a multi engine rating and it appears on his license. *Same with seaplane and other different types of ratings. I believe the endorsement is all that is required of a glider pilot for a motor glider, am I right? For the record I have seen a high time, highly experienced power and glider pilot make a major blunder with his motor out. *Scared the crappola out of me and I was standing on the ground at the time. *The bottom line is that proper training and check outs are everything. Walt -- Walt Connelly My $ .02 What makes an aircraft a motor glider is the "span loading", which determines, more than a power source, the flight characteristics of an aircraft. Mike The FAA certified Spaceship One as a glider. * Presumably this is because it didn't have an engine and they didn't know how to certify an aircraft with a rocket motor. I'm not sure that it would meet your "span loading" criterion! Mike It is not "MY" criterion! The FAA made it "THEIR" criterion. Mike |
selflaunch glider | Udo | Soaring | 1 | November 19th 07 08:32 AM |
