On Mar 1, 6:09*am, Mike Philpott @ wrote:
At 01:27 01 March 2011, Gregg Leslie wrote: Guys, Been thinking about taking a trip to Bloemfontein, South Africa. Any o you folks been there or have any feedback on the soaring operation? GL I've been there a number of times. It's a very well run operation with some absolutely fantastic flying to be had. The local terrain is mostly plateau at 4,500ft altitude. To the south and east, there are mountainous areas. In the flatlands, there are very many large fields in case an outlanding is required. The soaring conditions range from good to awesome. The only down side is that the area can be prone to thunderstorms. The visibility is generally very good indeed and it is often possible to see a hundred miles. Thermal climbs to 12,000ft or more are commonplace and in my experience, a 300km flight is barely more than local soaring. A typical day at Bloem will be get the gliders out and watered before 10. Briefing at 10:00 sharp. Launch around an hour or two later when the conditions really start to pop. The cut-off at the end of the day can be quite sudden so a shorter, faster task is better than a long one. That said, many flights of over 1000km have been flown from Bloem. Accommodation is either camping on site or in one of the many local guest houses and bed and breakfasts which are all luxurious and excellent. The local restaurants are also very good indeed and will be well suited to the American palate. You will need to rent a car and for the yanks, may have difficulties with coping with driving on the left and with traffic circles etc. I'm British so it isn't a problem. Car hire is expensive although the cost of living otherwise is pretty reasonable. You only get one life and this is one of those things that definitely must be done before you pop your clogs. Go for it!! Hope this helps. Mike - What are the best months for flying? Thanks for sharing. |
Soaring Safaris operates October to February inclusive.
South African soaring does get tamer in winter - however, I did my 5 hour for silver in June thermals. The last hour was pretty marginal - I could barely manage to remain above 4000" AGL. ;-) That said this summer has been very wet - so the soaring in December and January was impacted by rain. |
Thanks Mike!
At 13:37 01 March 2011, GK wrote: On Mar 1, 6:09=A0am, Mike Philpott wrote: At 01:27 01 March 2011, Gregg Leslie wrote: Guys, Been thinking about taking a trip to Bloemfontein, South Africa. Any o you folks been there or have any feedback on the soaring operation? GL I've been there a number of times. It's a very well run operation with some absolutely fantastic flying to be had. The local terrain is mostly plateau at 4,500ft altitude. To the south and east, there are mountainous areas. In the flatlands, there are very many large fields in case an outlanding is required. The soaring conditions range from good to awesome. The only down side is that the area can be prone to thunderstorms. The visibility is generally very good indeed and it is often possible to see a hundred miles. Thermal climbs to 12,000ft or more are commonplace and in my experience, a 300km flight is barely more than local soaring. A typical day at Bloem will be get the gliders out and watered before 10. Briefing at 10:00 sharp. Launch around an hour or two later when the conditions really start to pop. The cut-off at the end of the day can be quite sudden so a shorter, faster task is better than a long one. That said, many flights of over 1000km have been flown from Bloem. Accommodation is either camping on site or in one of the many local guest houses and bed and breakfasts which are all luxurious and excellent. The local restaurants are also very good indeed and will be well suited to the American palate. You will need to rent a car and for the yanks, may have difficulties with coping with driving on the left and with traffic circles etc. I'm British so it isn't a problem. Car hire is expensive although the cost of living otherwise is pretty reasonable. You only get one life and this is one of those things that definitely must be done before you pop your clogs. Go for it!! Hope this helps. Mike - What are the best months for flying? Thanks for sharing. |
Hi, I went there the first wek in Feb, last year. Only didn't fly one day.
but it was excellent! really good. i flew the LS4 98. got over 23hrs in the one week i was there. can't wait for next winter :-) I stayed in Kridge Lodge. very very nice and very resonable. excellent breakfast, pool everything you need. Great gliding Nick Barnes |
Soaring Video in South Africa | [email protected] | Soaring | 5 | March 23rd 07 12:09 PM |
Flying in South Africa | xyzzy | Piloting | 3 | November 9th 06 03:40 AM |
Hire & Fly in South Africa. | Bush Air | Piloting | 1 | May 25th 04 11:27 AM |
Hire & Fly in South Africa. | Bush Air | General Aviation | 0 | May 24th 04 05:53 AM |
Hire & Fly in South Africa. | Bush Air | General Aviation | 0 | May 24th 04 05:49 AM |
