But wouldn't a leak in the system cause the airspeed to read lower?
My guess is the new static line that you plumbed in for the transponder introduced a leak into the static system. *It should've been leak tested when the transponder check was completed. Do you know if that was done? |
On Mar 3, 8:07*am, GARY BOGGS wrote:
But wouldn't a leak in the system cause the airspeed to read lower? My guess is the new static line that you plumbed in for the transponder introduced a leak into the static system. *It should've been leak tested when the transponder check was completed. Do you know if that was done?- Hide quoted text - - Show quoted text - That depends on whether his cabin pressure is higher or lower than static. Easy to check with a manometer connected to static on one side and nothing (cabin) on the other. My fancy manometer is some acrylic tube in a 'U' shape, and some water. |
Perhaps the curse I put on CP for abandoning his Canadian club (not
the whiskey!) for warmer climes (and climbs!) has had a spill-over effect to Frank's ASI? I wouldn't have thought the sacrifice of a PW-5 could be so powerful. |
It also depends upon whether the ships static system shows true
static or not. If you read through Richard Johnson's tests you'll see that many gliders have static systems with significant errors built in to them. If there is more than one static source the manual will usually specify which one to connect to as that is the one which was used for certification testing and the placard speeds will take any error into account. I would reconnect everything the way it's supposed to be and then get the pitot-static system checked out with a test set. But wouldn't a leak in the system cause the airspeed to read lower? That depends on whether his cabin pressure is higher or lower than static. |
Airspeed Indicator Strangeness | Frank[_1_] | Soaring | 6 | June 9th 08 01:24 PM |
Airspeed Indicator problems | [email protected] | Soaring | 6 | June 19th 07 02:33 AM |
verifying airspeed indicator | Heino & Deanne Weisberg | Home Built | 11 | October 22nd 05 07:36 PM |
Need glider airspeed indicator | [email protected] | Soaring | 1 | June 21st 05 09:57 PM |
Inaccurate airspeed indicator | Wyatt Emmerich | Instrument Flight Rules | 20 | April 20th 04 12:08 AM |
