On Mar 3, 1:42*pm, Tim Taylor wrote:
On Mar 3, 10:26*am, Frank Paynter wrote: I installed a TT21 transponder over the winter, and as per the installation instructions, tapped into my ship's static line for altitude reporting. *Yesterday I checked the transponder with Orlando ATC and they reported a good signal and proper altitude reporting. *So far, so good. Then I noticed my airspeed indicator seemed to be reading significantly higher than normal, and I confirmed this with a stall series. *My Ventus 2bx, which normally stalls in the 40-45kt range depending on bank angle, now is apparently stalling in the 50-55kt range. *The ship actually feels pretty much the same as before, although I haven't flown for 3 months so that's a bit hard to tell for sure. My dry flying weight is probably about 5-10lbs higher this year than last, as I added the TT21 itself, plus a 5-lb battery to support it. However, I'm pretty sure that by itself doesn't explain the significantly higher apparent stall speed. As a troubleshooting step, I removed and plugged the static line from the airspeed indicator, so now the ASI takes it's static input from cabin air, and everything else should be unchanged. *I haven't flown it yet to try it out, but I will today. *I also have a spare airspeed indicator that I can swap in if necessary. Anything else I should be considering? TIA, Frank As with all design work: 1. *Only make one change at a time. 2. If there is a problem, undo the change. 3. If the system returns to normal start testing other things. If you start chasing options without checking if the original system is still the same you may spend lots of time chasing the incorrect problem. I would put the system back to the pre trig state and leave the trig in cabin static for the first test. Are you sure you hooked it up to Static and not the TE probe? Mike |
Airspeed Indicator Strangeness | Frank[_1_] | Soaring | 6 | June 9th 08 01:24 PM |
Airspeed Indicator problems | [email protected] | Soaring | 6 | June 19th 07 02:33 AM |
verifying airspeed indicator | Heino & Deanne Weisberg | Home Built | 11 | October 22nd 05 07:36 PM |
Need glider airspeed indicator | [email protected] | Soaring | 1 | June 21st 05 09:57 PM |
Inaccurate airspeed indicator | Wyatt Emmerich | Instrument Flight Rules | 20 | April 20th 04 12:08 AM |
