On 3/1/2011 11:36 AM, MBDiagMan wrote:
Background: I am about a 60 hour, non current pilot who hasn't flown in about 13 years. I have a pipeline coming through my place that has produced funds and this Summer will take out a clump of trees that will free up a place for about an 1,100 feet grass strip in the direction of the prevailing wind. I solo'd in an Aeronca Champ and then did most of my flying in a 150. I flew once in a Hershey Bar Cherokee 140 and liked it, although it felt quite different than the other planes I had flown. Question: I would like to get something for under $20K that I can use for recreational flying and on a nice day, take my wife to visit her twin sister about 200 miles away. I don't need a fancy panel, just the basics. I don't need a real fresh engine because I won't by piling on hours at a rapid pace. I will need a plane for the relatively short grass strip I described for daylight take off and landing. My idea is a 150 or a Cheorkee 140. I would love an old tail dragger like a Champ or a Cub, but they seem quite pricey and probably not well suited for a 200 mile flight with my wife. I plan on using the plane for the instruction flying that I will need to get current again and will have an instructor work with me to get comfortable with my grass strip. Any comments, advice and/or plane recommendations are appreciated. Doc The C-150 would work for you, except that annuals are getting pricey, and parts are going up. My last annual came in at 2 grand, and the plane was in quite respectable shape before hand. It would be better to buy a new plane, but that's not gonna happen on your budget. Perhaps if you could find a sympathetic A&P thereabouts, you could make it work out... Brian W |
brian whatcott writes:
The C-150 would work for you, except that annuals are getting pricey, and parts are going up. My last annual came in at 2 grand, and the plane was in quite respectable shape before hand. It would be better to buy a new plane, but that's not gonna happen on your budget. Perhaps if you could find a sympathetic A&P thereabouts, you could make it work out... Annual inspection prices are a factor but they are highly variable and rather controllable. First, one can buy a decent used aircraft that doesn't need a lot of repairs. Second, one can do a lot of work under the supervision of the IA and that saves a lot of money. It's OK if you're not a wrench-head, but you must be willing to learn and find an IA who is willing to work with you. Given it's a short grass strip, my first choice would not be a tricycle gear. What's on either end of the strip: empty fields? Crops? 150' oak trees? Any obstacles to overcome will be an important factor in the choice of aircraft. You may need something with a good climb rate and the C-150 doesn't leap to mind with that consideration. Maybe a Texas Taildragger (a C-150 converted to taildragger, often with a more powerful engine). Don't know what the prices are. Another idea is to continue renting and buy a simple kit-build (e.g. Kitfox) and start on that. In 1 to 3 years you could have a new, much better performing plane for about the price of a used, 50-year-old certificated plane. And you can then legally do all your own maintenance, adding non-certificated gadgets like autopilots, glass panels, etc. are up to 1/4 the price of the certificated equivalents. -- Almost all absurdity of conduct arises from the imitation of those whom we cannot resemble. ~ Samuel Johnson |
First of all, thanks for the replies.
As further information on my proposed field. It would have two strips, one about 15/33, 1,200 feet or a little more with short fences at either end. The other would be about a 3/21, same length with 100' tall trees on the South end. The prevailing winds would make the 21 the most common, meaning taking off over the trees. I am currently looking at a C140A with 100HP and a climb prop. It is for sale near by and I should get a demo flight as soon as the weather cooperates. Thanks for any further comments and advice. |
MBDiagMan writes:
I am currently looking at a C140A with 100HP and a climb prop. Excellent. That should do the job on takeoff and climb out. I forget, does that have flaps? Is some small amount of flaps recommended for soft-field takeoff? Check its ability to slip (for landing), as well as any restrictions on slipping with flaps. -- What is either a picture or a novel that is not character? - Henry James |
![]() Quote:
Thanks Bug, that is some great information to have and good questions about the plane. I do know that the C120's had no flaps while the C140 and C140A did. I have read that the 140 flaps are only marginally effective and the 140A flaps are only slightly more effective than that. Investigating it's slipping capabilities is something I had not thought about, so thanks for pointing this out. I will also investigate flap usage for soft field take off. I will be able to go fly it next week if we get the weather for it. Thanks again, |
OKaaaaaaaaaaaaaaay.....
Check out the Cherokees... Parts cheaper than Cessnas, and slipping with full flaps (no restrictions) will bring it down like a cinder block safely. Find one with Art Mattisons gap seals and VG's and the short runway would be no issue.. (or add them later... easy.....) We have these mods on our Warrior, and the low speed, takeoff/landing performance is stunning.... ![]() Plus, two more seats and FAR more comfortable (and suitable) for cross country flights.. Late 60's and early 70's 140's with a mid time engine/ light panels should be on $$$ reach.. Good Luck! Dave On Thu, 10 Mar 2011 12:19:42 +0000, MBDiagMan wrote: Bug Dout;765065 Wrote: MBDiagMan writes: - I am currently looking at a C140A with 100HP and a climb prop.- Excellent. That should do the job on takeoff and climb out. I forget, does that have flaps? Is some small amount of flaps recommended for soft-field takeoff? Check its ability to slip (for landing), as well as any restrictions on slipping with flaps. -- What is either a picture or a novel that is not character? - Henry James Thanks Bug, that is some great information to have and good questions about the plane. I do know that the C120's had no flaps while the C140 and C140A did. I have read that the 140 flaps are only marginally effective and the 140A flaps are only slightly more effective than that. Investigating it's slipping capabilities is something I had not thought about, so thanks for pointing this out. I will also investigate flap usage for soft field take off. I will be able to go fly it next week if we get the weather for it. Thanks again, |
On Mar 10, 10:27*am, Dave wrote:
OKaaaaaaaaaaaaaaay..... Check out the Cherokees... Parts cheaper than Cessnas, and slipping with full flaps (no restrictions) *will bring it down like a cinder block safely. Find one with *Art Mattisons gap seals and VG's and the short runway would be no issue.. *(or add them later... *easy.....) We have these mods on our Warrior, and the low speed, takeoff/landing performance is stunning.... * ![]() Plus, two more seats and FAR more comfortable (and suitable) for cross country flights.. Late 60's and early 70's *140's with a mid time engine/ light panels should be on $$$ reach.. Good Luck! Dave *On Thu, 10 Mar 2011 12:19:42 +0000, MBDiagMan wrote: Bug Dout;765065 Wrote: MBDiagMan writes: - I am currently looking at a C140A with 100HP and a climb prop.- Excellent. That should do the job on takeoff and climb out. I forget, does that have flaps? Is some small amount of flaps recommended for soft-field takeoff? Check its ability to slip (for landing), as well as any restrictions on slipping with flaps. -- What is either a picture or a novel that is not character? - Henry James Thanks Bug, that is some great information to have and good questions about the plane. I do know that the C120's had no flaps while the C140 and C140A did. *I have read that the 140 flaps are only marginally effective and the 140A flaps are only slightly more effective than that. Investigating it's slipping capabilities is something I had not thought about, so thanks for pointing this out. *I will also investigate flap usage for soft field take off. I will be able to go fly it next week if we get the weather for it. Thanks again, Neither the Cessna 150 or the Cherokee 140 are known for their short- field performance. We used to run a couple of 150s in the school, and on warm days the 3000' paved runway, at 3000' altitude, was getting marginal. Grass would be way worse; the drag of grass or stubble mustn't be underestimated. I've seen the Cherokees eat a lot of runway, too. The best bet for a cheaper airplane for this field would be a Champ 7EC. We had a 7EC that had been converted from the 90 hp to 100, and it outran those Cessna 150s every which way. The later American Champion airplanes are much heavier and have less useful load and use a LOT more runway than the old Champs. Shoot, even an Ercoupe can make a 150 look sick. I flew a 90-hp Alon Aircoupe, the last iteration of the Ercoupe series, and it took off shorter, climbed faster, and cruised faster than the 150s. I have no idea what the 150 is doing with its 100 hp. Dan |
On 3/9/2011 8:03 AM, MBDiagMan wrote:
First of all, thanks for the replies. As further information on my proposed field. It would have two strips, one about 15/33, 1,200 feet or a little more with short fences at either end. The other would be about a 3/21, same length with 100' tall trees on the South end. The prevailing winds would make the 21 the most common, meaning taking off over the trees. I am currently looking at a C140A with 100HP and a climb prop. It is for sale near by and I should get a demo flight as soon as the weather cooperates. Thanks for any further comments and advice. C-150 rated climb at gross is 1385 ft to a 50 foot obstacle still air. That makes your rwy 21 iffy, though the C140 has better performance. Brian W |
Historic Bombers B-25 Mitchell Bomber Taking off from Grass Field.jpg (1/1) | J.F. | Aviation Photos | 0 | October 26th 07 01:17 AM |
A warm evening, a grass strip, and thou.... | Jay Honeck | Piloting | 29 | August 27th 07 11:14 PM |
Looking for cheap power 4 short strip. | On-Condition | Home Built | 7 | September 11th 05 08:18 AM |
What is a "short field" for a PA28-181 | Roy Page | Owning | 79 | November 24th 04 12:11 PM |
Now THIS is a short field landing | John Harlow | Piloting | 8 | March 16th 04 10:42 PM |
