In article Bruce Hoult writes:
On Mar 5, 8:44=A0am, John Smith wrote: If you ever want to climb above 15,000 ft in an airspace where a tansponder is mandatory (which I do regularly), then you are just plain illegal with the TT21. This may be "fairly meaningless" for you, it's not for me and should not be for any pilot. Saying something is "illegal" is a fairly useless statement. A lot of things are illegal, ranging from driving at 60 in a 55 zone and on up. I think you need to explain: - what is the likely safety implication of flying above 15000 with a TT21? I suspect the answer is "none whatsoever". Unless, of course, the encoder actually cannot encode significantly above that altitude. Or, if it encodes incorrect values, resulting in that airliner hitting you and going down with all aboard. That will look about as bad as not having had a transponder in the first place. - what is the penalty for being caught doing so? What is the chance of being caught? The first part probably depends on how you are caught. Alan |
On Mar 4, 9:52*pm, (Alan) wrote:
In article Bruce Hoult writes: On Mar 5, 8:44=A0am, John Smith wrote: If you ever want to climb above 15,000 ft in an airspace where a tansponder is mandatory (which I do regularly), then you are just plain illegal with the TT21. This may be "fairly meaningless" for you, it's not for me and should not be for any pilot. Saying something is "illegal" is a fairly useless statement. A lot of things are illegal, ranging from driving at 60 in a 55 zone and on up. I think you need to explain: - what is the likely safety implication of flying above 15000 with a TT21? I suspect the answer is "none whatsoever". * Unless, of course, the encoder actually cannot encode significantly above that altitude. * Or, if it encodes incorrect values, resulting in that airliner hitting you and going down with all aboard. *That will look about as bad as not having had a transponder in the first place. - what is the penalty for being caught doing so? What is the chance of being caught? * The first part probably depends on how you are caught. * * * * Alan Nice fear theories but there is no reality here. The encoders in the Trig transponders are not an issue. The TT21 and TT22 use the same control head and that is where the encoder is. Current Mode C/gray code (100' resolution) external encoders operate to a minimum of 30k feet. More expensive expensive encoders get you to higher altitudes. And to get into a Mode S/serial encoder (25' resolution) style encoder typically gets you higher than 30k feet as standard but most of the Mode S transponders we care about in gliders come with built in encoders. For all USA gliders after transponder installation a static system check (Part 43 Appendix E) is required to ensure both altimeter and encoder accuracy. Nothing in that static systems tests is specific to type 1 or 2 transponders--just ask the person doing the test if they can check to 18,000' or higher just to be sure. (and if a Trig encoder needs adjusting to meet altimeter accuracy the test operator has to drive it up to 20,000' anyhow to use the calibration adjustment). What is important is to get people installing and properly using transponders where we have high density airline and fast jet traffic. Not only did Trig (and maybe some other products in Europe who are not available in the USA) significantly lower the cost and power requirements of installing Mode S but they also significantly reduced the cost difference between the Class 2 and Class 1 versions of their transponders. Other vendors had been using that class 1 vs class 2 requirement to create high artificial price differences between their transponders (for what were basically the same electronics). Trig's price difference seems only around $200, so pretty marginal, so there is less reason to use the Class 2 TT21 if class 1 requirement worries you. The TT22 will use slightly more power than the TT21. Almost all glider installations of Trig transponders I am aware of are TT21 and seem to be doing very well. Darryl |
On 3/4/2011 9:52 PM, Alan wrote:
In Bruce writes: On Mar 5, 8:44=A0am, John wrote: If you ever want to climb above 15,000 ft in an airspace where a tansponder is mandatory (which I do regularly), then you are just plain illegal with the TT21. This may be "fairly meaningless" for you, it's not for me and should not be for any pilot. Saying something is "illegal" is a fairly useless statement. A lot of things are illegal, ranging from driving at 60 in a 55 zone and on up. I think you need to explain: - what is the likely safety implication of flying above 15000 with a TT21? I suspect the answer is "none whatsoever". Unless, of course, the encoder actually cannot encode significantly above that altitude. Or, if it encodes incorrect values, resulting in that airliner hitting you and going down with all aboard. That will look about as bad as not having had a transponder in the first place. We need to be sure we are talking about the same regions (country and altitude). For the USA, Class A airspace starts at 18,000', so for below that altitude, there is no effective difference between the two classes of transponders for pilots operating VFR. If you intend to operate in USA Class A airspace without waiver, then getting the higher altitude rated transponder makes sense. The extra cost of the unit is small compared to the ongoing testing requirements of your transponder, altimeter, and static system, so there is no point in taking a chance the encoder might not be accurate enough at the high end (30,000+?). I am still curious about the differences between the two models, beyond the obvious one of output power. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-launching Sailplane Operation Mar/2004" Much of what you need to know tinyurl.com/yfs7tnz |
On 3/5/2011 2:04 AM, Eric Greenwell wrote:
On 3/4/2011 9:52 PM, Alan wrote: In Bruce writes: On Mar 5, 8:44=A0am, John wrote: If you ever want to climb above 15,000 ft in an airspace where a tansponder is mandatory (which I do regularly), then you are just plain illegal with the TT21. This may be "fairly meaningless" for you, it's not for me and should not be for any pilot. Saying something is "illegal" is a fairly useless statement. A lot of things are illegal, ranging from driving at 60 in a 55 zone and on up. I think you need to explain: - what is the likely safety implication of flying above 15000 with a TT21? I suspect the answer is "none whatsoever". Unless, of course, the encoder actually cannot encode significantly above that altitude. Or, if it encodes incorrect values, resulting in that airliner hitting you and going down with all aboard. That will look about as bad as not having had a transponder in the first place. We need to be sure we are talking about the same regions (country and altitude). For the USA, Class A airspace starts at 18,000', so for below that altitude, there is no effective difference between the two classes of transponders for pilots operating VFR. If you intend to operate in USA Class A airspace without waiver, then getting the higher altitude rated transponder makes sense. The extra cost of the unit is small compared to the ongoing testing requirements of your transponder, altimeter, and static system, so there is no point in taking a chance the encoder might not be accurate enough at the high end (30,000+?). I am still curious about the differences between the two models, beyond the obvious one of output power. If you are flying above 18K in the US without a waiver, don't you need to be on an IFR flight plan, IFR qualified and current, and in an aircraft properly equipped and certified for IFR operation? If so, I suspect that almost all glider operations in the US above 18K require some form of waiver. -- Mike Schumann |
On 3/5/2011 1:21 PM, Mike Schumann wrote:
On 3/5/2011 2:04 AM, Eric Greenwell wrote: If you intend to operate in USA Class A airspace without a waiver, then getting the higher altitude rated transponder makes sense. The extra cost of the unit is small compared to the ongoing testing requirements of your transponder, altimeter, and static system, so there is no point in taking a chance the encoder might not be accurate enough at the high end (30,000+?). I am still curious about the differences between the two models, beyond the obvious one of output power. If you are flying above 18K in the US without a waiver, don't you need to be on an IFR flight plan, IFR qualified and current, and in an aircraft properly equipped and certified for IFR operation? I'm sure you do need to be operating IFR, and I believe that would include having the proper class of transponder (but I can't point to the regulation that says that). That's what I meant by "getting the higher altitude rated transponder"; i.e., not the up to 15,000' rated one. If so, I suspect that almost all glider operations in the US above 18K require some form of waiver. I believe that is true, and I also believe it's true you could use your 15,000' rated transponder without any safety impact when using a waiver to operate over 18,000'. HOWEVER, I don't know what the regulations require of your transponder installation when operating with a waiver in Class A. And, I am still curious about the differences between the two ratings (above/below 15,000), beyond the obvious one of output power. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) |
Here's my summary on the topic...let me know where I am wrong....
In USA you can fly to 17,999' WITHOUT any transponder at all (class E or G with some exceptions) If you have a transponder rated only to 15,000", you must have the transponder "on" and you can only fly to 15,000 (legally) If you have the "high Power" transponder you can fly up to 17,999 legally To fly a glider in class A you need "special permission" waiver etc or whatever. It is possible to get permission to above 18,000 without a transponder at all. Wave camps, wave windows, etc. It is probably more likely to get permission, with a transponder. Why not just tell the nice man your transponder is only good to 15,000 when you ask permission to go into class A? If you intend to fly above 15,000, why not just contact ATC and say "I'm looking to fly above 15,000 but only have the low power transponder? If you fly above 15,000 regularly why not just buy the higher power transponder in the first place? If you have the old, low power transponder, I am sure it would be easy to sell, or trade in for high power model! We installed the trig TT21 in our club glider. One of our airline pilot guys tried it out and contacted both NY approach, and Philadelphia approach....both said the signal was very strong. Probably with a proper install, and antenna the low watt transponder may actually put out more power into the air than a poorly installed high power transponder?? Also, we have an agreement to use 1201 code, so they know it's a glider. Only trouble is, we seldom get that high around here. State record is around 17,000......maybe somebody went higher but never claimed.. Cookie |
Transponder vs. Portable Transponder Detectors | John Murphy | Soaring | 16 | December 20th 08 07:25 AM |
helo 1182 small - 1182 small.JPG (1/1) | urbanwriter | Aviation Photos | 0 | April 15th 07 09:06 PM |
where to buy a small crank | Charles McLaurin | Soaring | 1 | May 12th 06 03:05 PM |
Small Typo | [email protected] | Soaring | 3 | December 2nd 05 03:29 AM |
Why are there no small turboprops? | Thomas J. Paladino Jr. | Piloting | 59 | June 8th 04 02:57 PM |
