Aerodynamics of aero towing
Old March 7th 11, 10:15 AM posted to rec.aviation.soaring
Martin Gregorie[_5_]
Default Aerodynamics of aero towing
This is a quick observation report. Its really a follow up to a sub-topic
on the "Poor lateral control on a slow tow" thread.
Last Friday I was sitting outside the CGC clubhouse, which was at the
upwind end of the active runway, when our Pawnee went past at about 200
ft with a Ventus on the line. As it went away I had a clear rear quarter
view which made the attitudes if the two aircraft really easy to see. The
Ventus looked to be at the same height as the Pawnee, but was clearly
flying much more nose-up. I'd estimate that it was at around 4 degrees
nose-up relative to the Pawnee.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old March 7th 11, 02:43 PM posted to rec.aviation.soaring
Karen
On Mar 7, 2:15*am, Martin Gregorie
AIRSPEED! AIRSPEED!
It is way more disconcerting when you see the tops of the wings of a
Pawnee from the grounf just before the DG300 behind him stalls,
releases and and spins in from 100 ft.
martin@ * | Martin Gregorie
org * * * |
Old March 7th 11, 03:24 PM posted to rec.aviation.soaring
Mike the Strike
wrote: This is a quick observation report. Its really a follow up to a sub-topic
AIRSPEED! AIRSPEED!
org * * * |
We have discussed this many times before. The nose-up attitude of the
glider results in extra forces that have to be overcome by the wings
and tail surfaces. In particular, modern standard-class ships with a
low angle of incidence of the wing have a pronounced nose-up attitude
that results in loss of control at speeds well above free-flight stall
speed.
I find my Discus 2 won't high-tow very well below 60 knots, even
though its stall speed is nearer 40 or 45. One strategy I use if the
tow plane won't or can't speed up is to descend into low tow, which
buys an extra 5 knots or so.
Extra speed is great, but not under control of the glider pilot!
Mike
Old March 7th 11, 09:14 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
speed.
I'm having trouble picturing the influence of a low angle of incidence
of the wing (I assume that's compared to the fuselage) on loss of
control. Why would the wing be affected by the fuselage attitude being a
few degrees higher, relative to the air, than on an older glider?
email me)
Old March 7th 11, 10:08 PM posted to rec.aviation.soaring
speed.
I should add that there was plenty of speed - the Pawnee had its tail
well up. From where I was sitting its fuselage looked to be pretty much
horizontal. The Ventus looked to be well under control - it was flying
very steadily. I ascribed most of the glider's nose-high attitude to the
fact that it was flying in the downwash field behind the tug.
Don't forget that the downwash behind a lift generating wing is roughly
1/3 of the wing's AOA, so this was actually a great visualisation of the
downwash.
org |
Old March 7th 11, 10:47 PM posted to rec.aviation.soaring
Mike the Strike
We have discussed this many times before. *The nose-up attitude of the
and tail surfaces. *In particular, modern standard-class ships with a
speed.
email me)
The angle of incidence of the wing (relative to the fuselage) is a lot
lower on modern standard class ships. The result is that they have a
pronounced nose-up attitude when flying slowly - you can see this both
on tow and when thermalling. On aero-tow, a nose-mounted tow hook
will result in a downward force on the nose that has to be compensated
by an upward force from the tailplane and extra lift from the wings.
The point at which you lose control under these dynamics is at a lot
higher speed than the free-flight stall speed. The effect doesn't
seem to be as strong with older gliders or flapped ships, but
definitely is a lot less in low tow.
Mike
Old March 7th 11, 11:03 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
speed.
email me)
The incidence difference is less that 5 degrees, isn't it? That would
mean the nose hook was only about 6" higher than otherwise. I just can't
see how moving the rope up 6" is going to change the forces
significantly. There is a bigger difference between a CG hook and nose
hook vertical separation, and nobody comments on how they lose control
sooner with the nose hook. I sure didn't notice any difference on my
previous glider, an ASW 20 B, where I used neutral flap to tow.
Maybe the difference between older and newer gliders is wing loading?
email me)
Old March 7th 11, 11:46 PM posted to rec.aviation.soaring
Bruce Hoult
though its stall speed is nearer 40 or 45. *One strategy I use if the
I suspect you're flying the tow too high behind a powerful tug that is
climbing at a steep angle e.g. flying with the tug on the horizon
rather than just above its slipstream.
The rope can't possibly make enough of a difference to the lift needed
from the wings to make a difference of 5 knots, but it can make you
run out of elevator power.
If low tow is ok then a high tow just above the slipstream will be
too.
Old March 8th 11, 02:42 AM posted to rec.aviation.soaring
speed.
email me)
lower on modern standard class ships. *The result is that they have a
on tow and when thermalling. *On aero-tow, a nose-mounted tow hook
higher speed than the free-flight stall speed. *The effect doesn't
Mike- Hide quoted text -
- Show quoted text -
I suspect you intended to say the tail was generating more down force
to over come the down vector on the nose.
Simple math based on a guess at tow rope tension of, say 50 lb or so
( 1000 lb glider/40 to 1 and double for sake of discussion), would
lead me to guess the down force on the nose to be not more than a few
lb.(maybe 10?). Assume a tail moment arm of 3 times the nose arm and
the extra lift the wing needs to generate is maybe 15 lb. at the most.
Your observation that the glider flies better in low tow makes sense
in that you are in cleaner air.
FWIW on a rainy winter night.
UH
Old March 8th 11, 03:17 AM posted to rec.aviation.soaring
CindyB[_2_]
Wow.
and all these years I was thinking that the center of gravity was
ahead of the center of lift; that there was a downward force
'forward' of the wing by the limits on CG location; and that the
horizontal tail
had to make a downward force to counteract the nose dropping tendency.
I think they called this Trim Drag, but I could be confused. I am
blond.
I better watch out for those nose-hook mounted gliders and
their scary tendencies. Maybe that's why the folks at EASU changed
the design requirements from aerotowing on CG towhooks to
requiring them to be aerotowed on 'forward' hooks. And that forward
hook placement was under the knees ......(even lower on the
ariframe than those dastardly true nosehooks. How does that fit into
the discussion?)
But hey, all that trim drag from different hook locations, gee, must
change the wing loading and subsequent stall speed by what......
a knot? Geesh.
Spend a few bucks on a few extra Spring tows,
and get past your winter nerves. Or break open a chapter of
Langewische. Or travel to a site that's still flying all winter
long and don't let the rust accumulate.
Think : First flight with a CFI-G for 2011. Promote annual
refresher training.... and less accidents.
Chuckling,
Cindy B
www.caracole-soaring.com
