OLC download limit
Old March 23rd 11, 12:03 PM posted to rec.aviation.soaring
jcarlyle
Default OLC download limit
Why would we care to protect someone stupid enough to upload their
flight which contains a violation? Darwin has a point, you know...
-John
On Mar 23, 6:34 am, Barny wrote:
Sounds like a good rule to prevent governments around the world from
wholesale downloading flights for review using s/w looking for
violations.
Old March 23rd 11, 02:28 PM posted to rec.aviation.soaring
Mike the Strike
-John
violations.
You can't deduce a violation of flight regulations just by looking at
an igc file. Many pilots, including me, have made flights into areas
that might be deemed illegal (for example above 18,000 feet or
normally closed military flight areas) quite legally with the express
permission of ATC. Even the "no flights after sunset" rule that we
argue about is a bit iffy. Sunset time is a variable that depends on
many factors that simple geometric formulae don't always correct for
and I know a couple of motorgliders and one self-launcher that are
equipped with lights and may fly after sunset quite legally. Some
pilots are now planning night wave flights.
The biggest violation that many of us make is proximity to clouds
(apart from those countries where cloud flying is legal). When the
position of clouds appears on igc files, I'll really start to worry!
Mike
Old March 23rd 11, 02:45 PM posted to rec.aviation.soaring
Max Kellermann
violations.
No, your idea is flawed. Everything you need for that is already
provided anonymously for OLC's JavaScript code.
The rule is purely egoistic. It shall preserve OLC's power and keep
others from doing independent flight analysis.
What we need is an open database for exchanging IGC files. That way,
anybody could do flight analysis (daily score, contests,
meteorological analysis, whatever).
Max
Old March 23rd 11, 03:39 PM posted to rec.aviation.soaring
jcarlyle
Mike, you left out one important thing: a PIC knows when there is
something that could be wrongly interpreted about his flight. One
knows if they did go (or could have gone) above 18,000 feet, or went
into a normally closed area, or landed legally after a strict
geometric calculation of sunset time, etc., etc. And if one knows,
they'll either (1) not post the flight onto a public forum like OLC,
or (2) they'll add comments to the OLC posting. If (1), no problem. If
(2), then if some bozo rips the file off OLC and doesn't take the
comments, the PIC is still covered (although I can see it might be a
hassle for a bit).
My comment was directed at the idiot who knows he violated airspace
and/or flight rules and posts his flight anyway. Sort of a "hold my
beer and look at this" attitude.
-John
Old March 23rd 11, 03:57 PM posted to rec.aviation.soaring
Andy[_1_]
violations.
No, your idea is flawed. *Everything you need for that is already
The rule is purely egoistic. *It shall preserve OLC's power and keep
What we need is an open database for exchanging IGC files. *That way,
Max
Regarless of the philosophy or justification for a download limit can
someone please see if they also see the problem I reported -
With Firefox, please select a flight, then select IGC download, then
save the file, then hit browser back button. I see the file
management screen again not the previous flight display page.
Attempting to get back past the file management screen uses up
downloads even though no file download was made.
Andy
Old March 23rd 11, 04:52 PM posted to rec.aviation.soaring
Andy[_1_]
violations.
Max
save the file, then hit browser back button. *I see the file
Andy- Hide quoted text -
- Show quoted text -
The problem is not seen with IE 6.
Andy
Old March 24th 11, 01:49 PM posted to rec.aviation.soaring
Andy[_1_]
violations.
Max
Andy
I think I found out why I see this problem and others say they don't.
It all works fine with Firefox if I log in before attempting to access
the first flight. If I don't log in, but wait until prompted to log in
when selecting IGC download, then the browser back function can't get
past the file management screen to select another flight.
Andy
DG-200 Life limit? Gregg Leslie[_2_] Soaring 6 September 15th 10 04:03 PM
PIK 20 and 3000 hrs limit poul g Soaring 1 August 11th 09 03:30 PM
limit of trim = limit of travel? Mxsmanic Piloting 251 May 11th 08 07:58 PM
The Sky is Their Limit [email protected] Soaring 7 November 13th 06 02:44 AM
Aft CG limit(s) Andy Durbin Soaring 13 November 26th 03 05:10 AM
