Quite interesting engine out landing video.
Old March 25th 11, 11:31 PM
POPS POPS is offline
Member
First recorded activity by AviationBanter: Dec 2010
Default Quite interesting engine out landing video.
To bad the choices led to a damaged aircraft.
http://www.youtube.com/watch?v=lZvSm...eature=related
Old March 26th 11, 08:45 AM posted to rec.aviation.soaring
Bruce Hoult
On Mar 26, 12:31*pm, POPS wrote:
To bad the choices led to a damaged aircraft.http://www.youtube.com/watch?v=lZvSm...eature=related
While he was cruising along, I decided I would take a particular field
as it looked longer than the rest. He then looked like he was setting
up a circuit into that same field, except far with the base leg far
too close in and he flew over it and seemed to barely make it over a
stone fence into the next one (maybe even touched it?).
Old March 26th 11, 03:49 PM posted to rec.aviation.soaring
glidergeek
POPS
If the propeller is connected to the crankshaft and the engine seized
why was it windmilling all the way to the ground?
Old March 26th 11, 04:10 PM posted to rec.aviation.soaring
Scott[_7_]
On 3-26-2011 15:49, glidergeek wrote:
POPS
Broken crank?
Old March 26th 11, 08:18 PM posted to rec.aviation.soaring
Paul Tribe
v=lZvSmsIE_Ls&feature=related
POPS
seized
Broken crank?
Can't quite see the relevance to "Bremont" watches:
Is it that you feel calmer in an emergency because you know that
you can look down at your wrist at the exact moment you plough
into a dry stone wall and be reassured that you know the correct
time it happened?
Old March 26th 11, 08:27 PM posted to rec.aviation.soaring
Paul Tribe
POPS
seized
Broken crank?
time it happened?
Old March 27th 11, 04:54 AM posted to rec.aviation.soaring
Jim Logajan
time it happened?
Doubt this was their intent, but this comes to mind:
"When asked what the first reaction to an emergency should be, an old
airline captain replied that he would reach up and wind the clock on the
instrument panel. There is a prevailing myth that says that pilots must
have ultra-fast reflexes to survive. The truth is that flying is much more
of a thinking game than a purely reactive one."
http://www.aopa.org/asf/asfarticles/sp9406.html
Old March 27th 11, 11:38 PM posted to rec.aviation.soaring
Gary Boggs
Why didn't he put the gear down? Base turn seemed way to low to me,
especially with no power.
Boggs
Old March 28th 11, 12:07 AM posted to rec.aviation.soaring
Gary Evans[_2_]
He may have hit the stone wall. It was very very close.
interesting video of a takeoff and landing John Piloting 7 November 13th 07 01:19 AM
Video clip of an "interesting" final approach & landing Elmo von Thud Aviation Photos 3 October 7th 07 12:54 AM
Interesting engine? dje Home Built 40 December 21st 05 03:33 PM
Interesting new engine and rotorcraft dje Home Built 0 April 23rd 05 01:39 AM
Interesting landing John Harlow Piloting 8 January 30th 04 09:28 PM
