On Mar 27, 12:50*pm, "kirk.stant" wrote:
On Mar 27, 12:31*pm, "Matt Herron Jr." wrote: On Mar 26, 10:09*am, Andy wrote: However I have never used a written checklist, or action list, for takeoff or landing in a glider. *The check list goes away before I get in and does not come out again until I'm back at the trailer. No doubt people miss required actions when under pressure, but does a checklist help in single pilot operations? *Crews of military aircraft and of large civil transport aircraft are required to memorize the required response for all situations requiring immediate action. *Only after the sequence has been executed is it confirmed by use of a checklist. *Even routine tasks such as cockpit preparation are performed without a check list, typically using a "flow" technique. Only when it is all done is the the checklist used for confirmation. I'm still capable of remembering a mnemonic action list long enough to cover a glider pre-takeoff or landing check. *When I can't remember the list I'll probably be too old, fatigued, dehydrated, or scared to remember to get the checklist out. Andy Checklists save lives in where complex, life threatening tasks are involved such as flying, surgery, etc. *Its a proven fact. *I probably don't need a checklist either when everything is going great. But when my assembly is interrupted, or I have to get out of the cockpit on the flight line for some reason, or I am landing in a field, or a whole string of seemingly small things stack up to a situation, I want my lists. *You are a very lucky man to have never forgotten to do anything important in your flying career. *I wish I could say the same. For those interested, check out "The Checklist Manifesto" by Atul Gawande Matt Jr. That's all great, but there aren't a lot of life threatening tasks when landing a glider. *Heck, in a 1-26, the only one is checking the direction of the wind prior to entering the pattern - and even that could be considered airmanship, not a task. *In more complex gliders, if you forget to dump your ballast you could fly the pattern too slow, or if you leave the gear up it could get expensive fast, but what else is life threatening - that isn't really just flying the glider? I'm all for assembly checklists, and leave the house checklists, and before leaving the glider field checklists - but gliders are simply not complex enough to need lengthy inflight checklists. *If they make you feel better, fine, but the downside is that while you are reading an going through a list of items, you are not flying the glider and looking out very much - which is A LOT MORE IMPORTANT in the landing pattern. The example with doctors is misleading. *I seriously doubt the surgeon goes through a checklist before every action during an operation. What he does is go through a pre-surgery checklist (like our assembly check) and a post-surgery checklist (make sure nothing is left in the patient), but he doesn't need a 1. grasp scalpel with right hand 2. place scalpel tip on patients skin 3. push until it bleeds checklist! In the complicated jets I used to fly in, our checklists were to make sure all the required switches and checks were accomplished when needed. *And they were mainly done as "after the fact" challenge response to verify completion - not by reading and doing one step at a time. In a rush, the checks were done quickly and confirmed when convenient. Anyway, do whatever floats your boat, but don't read a checklist in the pattern, please! Kirk 66 Kirk, Did you read: http://www.newyorker.com/reporting/2...a_fact_gawande Here is a quote- "Line infections are so common that they are considered a routine complication. I.C.U.s put five million lines into patients each year, and national statistics show that, after ten days, four per cent of those lines become infected. Line infections occur in eighty thousand people a year in the United States, and are fatal between five and twenty-eight per cent of the time, depending on how sick one is at the start." OK, now here are the steps- (1) wash hands with soap, (2) clean the patient’s skin with chlorhexidine antiseptic, (3) put sterile drapes over the entire patient, (4) wear a sterile mask, hat, gown, and gloves, and (5) put a sterile dressing over the catheter site once the line is in. Clearly these are simple, easy to remember things that don't need a checklist. But they started using a checklist anyway- "the ten-day line-infection rate went from eleven per cent to zero. So they followed patients for fifteen more months. Only two line infections occurred during the entire period. They calculated that, in this one hospital, the checklist had prevented forty-three infections and eight deaths, and saved two million dollars in costs." Agree with most of your comments, BTW, but checklists are sometimes useful for even the simple things. Brian |
Kirk,
Did you read:http://www.newyorker.com/reporting/2...a_fact_gawande Here is a quote- "Line infections are so common that they are considered a routine complication. I.C.U.s put five million lines into patients each year, and national statistics show that, after ten days, four per cent of those lines become infected. Line infections occur in eighty thousand people a year in the United States, and are fatal between five and twenty-eight per cent of the time, depending on how sick one is at the start." OK, now here are the steps- (1) wash hands with soap, (2) clean the patient’s skin with chlorhexidine antiseptic, (3) put sterile drapes over the entire patient, (4) wear a sterile mask, hat, gown, and gloves, and (5) put a sterile dressing over the catheter site once the line is in. Clearly these are simple, easy to remember things that don't need a checklist. But they started using a checklist anyway- "the ten-day line-infection rate went from eleven per cent to zero. So they followed patients for fifteen more months. Only two line infections occurred during the entire period. They calculated that, in this one hospital, the checklist had prevented forty-three infections and eight deaths, and saved two million dollars in costs." Agree with most of your comments, BTW, but checklists are sometimes useful for even the simple things. Brian Sorry, that's not a checklist, that a procedure. And reading some of the "checklists" I see on RAS, they are also more "procedures" instead of checklists. WUFSTALL is getting awfully close to a procedure for me. Kirk 66 |
On Mar 28, 12:17*am, "kirk.stant" wrote:
Kirk, Did you read:http://www.newyorker.com/reporting/2...a_fact_gawande Here is a quote- "Line infections are so common that they are considered a routine complication. I.C.U.s put five million lines into patients each year, and national statistics show that, after ten days, four per cent of those lines become infected. Line infections occur in eighty thousand people a year in the United States, and are fatal between five and twenty-eight per cent of the time, depending on how sick one is at the start." OK, now here are the steps- (1) wash hands with soap, (2) clean the patient’s skin with chlorhexidine antiseptic, (3) put sterile drapes over the entire patient, (4) wear a sterile mask, hat, gown, and gloves, and (5) put a sterile dressing over the catheter site once the line is in. Clearly these are simple, easy to remember things that don't need a checklist. But they started using a checklist anyway- "the ten-day line-infection rate went from eleven per cent to zero. So they followed patients for fifteen more months. Only two line infections occurred during the entire period. They calculated that, in this one hospital, the checklist had prevented forty-three infections and eight deaths, and saved two million dollars in costs." Agree with most of your comments, BTW, but checklists are sometimes useful for even the simple things. Brian Sorry, that's not a checklist, that a procedure. And reading some of the "checklists" I see on RAS, they are also more "procedures" instead of checklists. WUFSTALL is getting awfully close to a procedure for me. Kirk 66 Oh, good grief! It's a simple glider, not an airliner. If you can't tell that you have a load of water on board, maybe you shouldn't be flying with water (or at all!). The control feel is entirely different. Same for flaps. Test the spoilers? Why? You'll know as soon as you try to open them and can alter your pattern then. If that's too complex, maybe you shouldn't be flying. Check the wind? You mean that you aren't constantly aware of the wind direction and speed? Drift, crab? Should you really be up there alone? Check trim? Have you been holding constant pressure on the stick? Can't you land with trim locked at either extreme? Should you be flying? I could go on and on, but to what end? When I flew at Bond Springs, NT, Australia, their before takeoff checklist mnemonic was: CHAOTIC. What the heck did that mean? I couldn't remember during the time I was flying there, much less now! In my AF days before takeoff we said: "All shiny switches - Outboard" and before landing it was: "Muff 91, gear check, full stop." I haven't damaged an aircraft in 38 years of flying. I know, some day... (Flame suit on) |
I tend to agree with the idea that checklist should be short and apply
to only critical or commonly forgotten items. When you add too many item and it becomes a procedure then you are likely to miss or skip critical items on the list. Or it becomes so long that you eventally just don't do it at all. W ater U ndercarriage F laps S peed T rim A irbrakes R adio Intentions E nter Pattern could easily be shorted to WU, Water because it can be easy to forget and Undercarriage because it is critical and easy to forget. My Take off critical check list is: Canopy closed (Critical) Controls Checked (Critical) Flight Recorder on (easily forgotton) It is just a sticker on instrument panel. My assembly critical assembly check list is a sticker on the access cover. I don't install the access cover until the check list complete. Brian |
Oh, good grief! *It's a simple glider, not an airliner.
If you can't tell that you have a load of water on board, maybe you shouldn't be flying with water (or at all!). *The control feel is entirely different. Same for flaps. Test the spoilers? *Why? *You'll know as soon as you try to open them and can alter your pattern then. *If that's too complex, maybe you shouldn't be flying. Check the wind? *You mean that you aren't constantly aware of the wind direction and speed? *Drift, crab? *Should you really be up there alone? Check trim? *Have you been holding constant pressure on the stick? Can't you land with trim locked at either extreme? *Should you be flying? I could go on and on, but to what end? When I flew at Bond Springs, NT, Australia, their before takeoff checklist mnemonic was: *CHAOTIC. *What the heck did that mean? *I couldn't remember during the time I was flying there, much less now! In my AF days before takeoff we said: *"All shiny switches - Outboard" and before landing it was: *"Muff 91, gear check, full stop." I haven't damaged an aircraft in 38 years of flying. *I know, some day... (Flame suit on)- Hide quoted text - Kick the tires, light the fires, brief on Guard, first one airborne is lead.... We agree. Kirk 66 |
On Mar 28, 11:56*am, "kirk.stant" wrote:
Oh, good grief! *It's a simple glider, not an airliner. If you can't tell that you have a load of water on board, maybe you shouldn't be flying with water (or at all!). *The control feel is entirely different. Same for flaps. Test the spoilers? *Why? *You'll know as soon as you try to open them and can alter your pattern then. *If that's too complex, maybe you shouldn't be flying. Check the wind? *You mean that you aren't constantly aware of the wind direction and speed? *Drift, crab? *Should you really be up there alone? Check trim? *Have you been holding constant pressure on the stick? Can't you land with trim locked at either extreme? *Should you be flying? I could go on and on, but to what end? When I flew at Bond Springs, NT, Australia, their before takeoff checklist mnemonic was: *CHAOTIC. *What the heck did that mean? *I couldn't remember during the time I was flying there, much less now! In my AF days before takeoff we said: *"All shiny switches - Outboard" and before landing it was: *"Muff 91, gear check, full stop." I haven't damaged an aircraft in 38 years of flying. *I know, some day... (Flame suit on)- Hide quoted text - Kick the tires, light the fires, brief on Guard, first one airborne is lead.... We agree. Kirk 66 Damn, Kirk! Did we fly together? I holler over the side to my crew chief, "I got EGT, you got noise?" Seems to me that, in a glider, the only necessary checklist is "Gear - DOWN". I suppose some have attempted takeoff with the canopy open but Darwin is lurking just around the corner and a checklist won't protect you from him... |
OK, hotshots,
Go read Kern's Airmanship Redefined. We aren't all up here because we have testosterone poisoning. Whether it is a checklist or a procedure, these are good devices for students, low-time pilots, and us old guys who need check lists to help us keep flying. Medical advice for older guys (from MD glider pilots) is to fly more often and use checklists. We aren't all flying international contests and it isn't the Indy 500. DON'T TELL US TO GET OUT OF THE SKY! At 18:37 28 March 2011, Dan Marotta wrote: On Mar 28, 11:56=A0am, "kirk.stant" wrote: Oh, good grief! =A0It's a simple glider, not an airliner. If you can't tell that you have a load of water on board, maybe you shouldn't be flying with water (or at all!). =A0The control feel is entirely different. Same for flaps. Test the spoilers? =A0Why? =A0You'll know as soon as you try to open th= em and can alter your pattern then. =A0If that's too complex, maybe you shouldn't be flying. Check the wind? =A0You mean that you aren't constantly aware of the win= d direction and speed? =A0Drift, crab? =A0Should you really be up there alone? Check trim? =A0Have you been holding constant pressure on the stick? Can't you land with trim locked at either extreme? =A0Should you be flying? I could go on and on, but to what end? When I flew at Bond Springs, NT, Australia, their before takeoff checklist mnemonic was: =A0CHAOTIC. =A0What the heck did that mean? =A0= I couldn't remember during the time I was flying there, much less now! In my AF days before takeoff we said: =A0"All shiny switches - Outboard= " and before landing it was: =A0"Muff 91, gear check, full stop." I haven't damaged an aircraft in 38 years of flying. =A0I know, some day... (Flame suit on)- Hide quoted text - Kick the tires, light the fires, brief on Guard, first one airborne is lead.... We agree. Kirk 66 Damn, Kirk! Did we fly together? I holler over the side to my crew chief, "I got EGT, you got noise?" Seems to me that, in a glider, the only necessary checklist is "Gear - DOWN". I suppose some have attempted takeoff with the canopy open but Darwin is lurking just around the corner and a checklist won't protect you from him... |
On Mar 28, 2:00*pm, Nyal Williams wrote:
OK, hotshots, Go read Kern's Airmanship Redefined. We aren't all up here because we have testosterone poisoning. Whether it is a checklist or a procedure, these are good devices for students, low-time pilots, and us old guys who need check lists to help us keep flying. *Medical advice for older guys (from MD glider pilots) is to fly more often and use checklists. We aren't all flying international contests and it isn't the Indy 500. DON'T TELL US TO GET OUT OF THE SKY! At 18:37 28 March 2011, Dan Marotta wrote: On Mar 28, 11:56=A0am, "kirk.stant" *wrote: Oh, good grief! =A0It's a simple glider, not an airliner. If you can't tell that you have a load of water on board, maybe you shouldn't be flying with water (or at all!). =A0The control feel is entirely different. Same for flaps. Test the spoilers? =A0Why? =A0You'll know as soon as you try to open th= em and can alter your pattern then. =A0If that's too complex, maybe you shouldn't be flying. Check the wind? =A0You mean that you aren't constantly aware of the win= d direction and speed? =A0Drift, crab? =A0Should you really be up there alone? Check trim? =A0Have you been holding constant pressure on the stick? Can't you land with trim locked at either extreme? =A0Should you be flying? I could go on and on, but to what end? When I flew at Bond Springs, NT, Australia, their before takeoff checklist mnemonic was: =A0CHAOTIC. =A0What the heck did that mean? =A0= I couldn't remember during the time I was flying there, much less now! In my AF days before takeoff we said: =A0"All shiny switches - Outboard= " and before landing it was: =A0"Muff 91, gear check, full stop." I haven't damaged an aircraft in 38 years of flying. =A0I know, some day... (Flame suit on)- Hide quoted text - Kick the tires, light the fires, brief on Guard, first one airborne is lead.... We agree. Kirk 66 Damn, Kirk! *Did we fly together? *I holler over the side to my crew chief, "I got EGT, you got noise?" Seems to me that, in a glider, the only necessary checklist is "Gear - DOWN". I suppose some have attempted takeoff with the canopy open but Darwin is lurking just around the corner and a checklist won't protect you from him...- Hide quoted text - - Show quoted text - I think we now have the complete range of opinions, even better I have the exact information I was looking for in the original post thank you again Matt and Eric. I promise everyone I will have the correct number of items on my checklist. In case I didn't understand quite what those were, could everyone please post their opinion again? Wouldn't want to miss that. Brian |
On Mar 28, 3:00*pm, Nyal Williams wrote:
OK, hotshots, Go read Kern's Airmanship Redefined. We aren't all up here because we have testosterone poisoning. Whether it is a checklist or a procedure, these are good devices for students, low-time pilots, and us old guys who need check lists to help us keep flying. *Medical advice for older guys (from MD glider pilots) is to fly more often and use checklists. We aren't all flying international contests and it isn't the Indy 500. DON'T TELL US TO GET OUT OF THE SKY! At 18:37 28 March 2011, Dan Marotta wrote: On Mar 28, 11:56=A0am, "kirk.stant" *wrote: Oh, good grief! =A0It's a simple glider, not an airliner. If you can't tell that you have a load of water on board, maybe you shouldn't be flying with water (or at all!). =A0The control feel is entirely different. Same for flaps. Test the spoilers? =A0Why? =A0You'll know as soon as you try to open th= em and can alter your pattern then. =A0If that's too complex, maybe you shouldn't be flying. Check the wind? =A0You mean that you aren't constantly aware of the win= d direction and speed? =A0Drift, crab? =A0Should you really be up there alone? Check trim? =A0Have you been holding constant pressure on the stick? Can't you land with trim locked at either extreme? =A0Should you be flying? I could go on and on, but to what end? When I flew at Bond Springs, NT, Australia, their before takeoff checklist mnemonic was: =A0CHAOTIC. =A0What the heck did that mean? =A0= I couldn't remember during the time I was flying there, much less now! In my AF days before takeoff we said: =A0"All shiny switches - Outboard= " and before landing it was: =A0"Muff 91, gear check, full stop." I haven't damaged an aircraft in 38 years of flying. =A0I know, some day... (Flame suit on)- Hide quoted text - Kick the tires, light the fires, brief on Guard, first one airborne is lead.... We agree. Kirk 66 Damn, Kirk! *Did we fly together? *I holler over the side to my crew chief, "I got EGT, you got noise?" Seems to me that, in a glider, the only necessary checklist is "Gear - DOWN". I suppose some have attempted takeoff with the canopy open but Darwin is lurking just around the corner and a checklist won't protect you from him... Now, now... Nobody's telling anybody to get out of the sky. I'm only objecting to the mind-set that you MUST use a checklist. In the traffic pattern is no place to be reading a book on how to fly your glider. You should know what to do, when to do it, and you should know your glider well enough to feel when things aren't right, i.e., wings still full, dive brakes not open, glider not yet on the ground. If you need a mnemonic to remember these things, fine, but please don't be flipping charts on the top of the panel while sharing the pattern with me. |
On 3/28/2011 8:21 AM, Dan Marotta wrote:
Maybe you need to meet some real glider pilots; you know, the kind that have made mistakes. There are a lot of us - not hard to find! Oh, good grief! It's a simple glider, not an airliner. If you can't tell that you have a load of water on board, maybe you shouldn't be flying with water (or at all!). The control feel is entirely different. Yikes! After flying a ballasted glider for 4 or 5 hours, it _feels_ normal (at least for the four gliders I've owned that used water), and if I'm concentrating on a low save or other intense things, I can forget it. After the first time, I added it to my checklist (meaning - started using one); so far, no repeat incidents. Same for flaps. Read the above, starting with the Yikes!, but thinking flaps instead of ballast. I didn't think it was possible to forget setting the flaps, but it was and still is. Test the spoilers? Why? You'll know as soon as you try to open them and can alter your pattern then. If that's too complex, maybe you shouldn't be flying. If you try them early in the pattern, that can be the test. If you sometimes wait until you are on final, that might be too late to deal with the the problem. I've only had one spoiler incident - frozen closed - but I've read of others having problems, including stuck open and only one deploying. The other reason is to activate the gear warning, in case you forgot that. I've been saved from a gear up landing at least three times by a spoiler activated gear warning, and I'd rather have the warning early in the pattern instead of on final. Check the wind? You mean that you aren't constantly aware of the wind direction and speed? Drift, crab? Should you really be up there alone? I've never had these on my checklist, but I have learned to check the wind several times during a pattern, after being fooled a couple times. Check trim? Have you been holding constant pressure on the stick? Can't you land with trim locked at either extreme? Should you be flying? I don't have this one on my checklist, but I'd say the danger is relaxing and letting the airspeed decrease/increase unintentionally, most likely while you are distracted by other aircraft in the pattern, the radio, people wandering around near the runway, etc. I could go on and on, but to what end? (snip) I haven't damaged an aircraft in 38 years of flying. I know, some day... OK, you don't need a checklist, but I think I see why you can't imagine that some of us find them helpful: you don't make mistakes and you don't get distracted. I make mistakes and I do get distracted. In 36 years of glider flying, I've managed to avoid big mistakes so a dinged wing tip on a landing light is the extent of my damage. It's taken plenty of care, some checklists, revision of procedures, study, and some luck to do it. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) |
Checklist | Larry D. Cosby | Piloting | 148 | March 29th 08 04:10 AM |
SSA convention schedule in electronic formats | Darryl Ramm | Soaring | 0 | February 12th 08 05:49 PM |
GPS Visualizer update: calculators, new maps & file formats | Adam Schneider | Soaring | 0 | May 6th 05 08:51 AM |
747-100 Checklist | Bartscher | General Aviation | 0 | December 18th 04 07:20 PM |
C-180 100 hr checklist | ConchyJoe | Owning | 1 | May 3rd 04 11:53 PM |
