On Sun, 15 Feb 2004 18:45:06 -0500, Kevin Brooks wrote:
Firstly, I think you are exaggerating the F-35 situation a bit--the total US buy is a bit over two thousand over the lifetime of the rpogram, IIRC Yes, that's "several thousand". Well, I call that a couple, not "several"; Websters defines several as being "greater than 2 or 3". I meant it as greater than 2. China and Russia are both keen to develop more modern aircraft. But, any future aircraft will be developed in a timescale where the F-35 will already be in service. So a potential enemy will have to deal with that too. The sort of hypothetical force we're talking about, then, would consist of large numbers (1000+) of Typhoon-class aircraft. The only people who could field such as force are Europe, Japan, and China. Europe and Japan aren't going to fight the USA unless the USA starts behaving like Nazi Germany or the USSR. Nobody (no one nation) is going to field that many advanced fighters of the Typhoon classs. And you are right in that the nations that *could* pose a quality threat are not the ones that are in our "likely foe" category (China excepted, and I doubt, based upon the J-10 experience, they can manage it in the forseeable future). You're probably right there, in the short and medium term. In the long term, China is very interested in modern technologies, and has a largish and rapidly growing economy, so they are bound to catch up in aeronautical engineering. China is unlikely to seek confrontation with the USA, but a war between the two could break out by accident (as happened the last time those countries fought each other), and in any case the USA has an economy 10 times bigger so would always be able to afford more planes (and other military cabability). And fixed wing land fighter aircraft would be the least usable platforms against the PRC threat; lack of basing being a biggie. If China attacked one of its neighbours, that country would very likely allow the USAF to base there. The F-35 is a cheaper plane than the F-22, and having just one fighter would provide savings on training, spare parts, etc, so it's likely that for every F-22 not built the USA could afford 3 or so F-35s. Which would also require three more pilots (an increasingly stretched commodity), and leave us without that "silver bullet" as insurance. That's true -- over its lifetime, the F-35 may not be that much cheaper than the F-22. (Having said that, I expect simulators could make it cheaper to train good pilots). Now, it's certainly true that the F-22 is a omre capably fighter than the F-35: it has a better power-to-weight ratio and lower wing loadinmg, which means it will be more manouvrable. It's also got room for more missiles. (It's proasbly less stealthy, since it's alrager aircraft, thus probably has larhger radar and IR signatures). Is one F-22 better than the 2-3 F-35s one could buy in its place? I don't know. You are missing the avionics advantage; F-22 was optimized as an anti-air platform, so it will indeed be much more capable than the F-35, which is optimized in the strike role, in that air dominance role. So in the air-to-air role, how many F-35s is one F-22 worth, IYO? -- "It's easier to find people online who openly support the KKK than people who openly support the RIAA" -- comment on Wikipedia (Email: zen19725 at zen dot co dot uk) |
![]() "phil hunt" wrote in message .. . On Sun, 15 Feb 2004 18:45:06 -0500, Kevin Brooks wrote: snip Nobody (no one nation) is going to field that many advanced fighters of the Typhoon classs. And you are right in that the nations that *could* pose a quality threat are not the ones that are in our "likely foe" category (China excepted, and I doubt, based upon the J-10 experience, they can manage it in the forseeable future). You're probably right there, in the short and medium term. In the long term, China is very interested in modern technologies, and has a largish and rapidly growing economy, so they are bound to catch up in aeronautical engineering. But it appears likely that the cost of "catching up" may well be their continued embracing of capitalism, and with it the usual attendant move towards democracy--so by the time they get there, move them out of the threat category. China is unlikely to seek confrontation with the USA, but a war between the two could break out by accident (as happened the last time those countries fought each other), and in any case the USA has an economy 10 times bigger so would always be able to afford more planes (and other military cabability). And fixed wing land fighter aircraft would be the least usable platforms against the PRC threat; lack of basing being a biggie. If China attacked one of its neighbours, that country would very likely allow the USAF to base there. If the PRC attacked one of its neighbors, none of which have exactly a lot of geographic space to trade for the time to get US landbased tactical airpower into the fray, so I'd be surprised to see US ground based aircraft move into the nation in question. The only way the landbased tactical airpower comes into play is from the periphery (i.e., Okinawa and ROK), and then it is going to be limited mostly to the coastal region. In the end you are going to confront a basing problem, so a six or seven squadron force of F-22's would likely be capable of supporting the deployment of the two to four squadrons you'd be squeezing into the available bases as your silver bullet force. The F-35 is a cheaper plane than the F-22, and having just one fighter would provide savings on training, spare parts, etc, so it's likely that for every F-22 not built the USA could afford 3 or so F-35s. Which would also require three more pilots (an increasingly stretched commodity), and leave us without that "silver bullet" as insurance. That's true -- over its lifetime, the F-35 may not be that much cheaper than the F-22. (Having said that, I expect simulators could make it cheaper to train good pilots). Simulators will indoubtedly continue to help in such training, and grow in terms of that capability. But you are still postulating a three-for-one increase in pilots just to replace the "missing" F-22's. If you assume that the F-22 is three times as good as the F-35 in the air-to-air role, you now need another 600 F-35's *and* pilots, and you have to keep them proficient, which means 150-200 hours of airtime per year per pilot, more O&M costs, etc. So the replacement of those 200 F-22's would likely not be the massive savings you might originally think it to be. Now, it's certainly true that the F-22 is a omre capably fighter than the F-35: it has a better power-to-weight ratio and lower wing loadinmg, which means it will be more manouvrable. It's also got room for more missiles. (It's proasbly less stealthy, since it's alrager aircraft, thus probably has larhger radar and IR signatures). Is one F-22 better than the 2-3 F-35s one could buy in its place? I don't know. You are missing the avionics advantage; F-22 was optimized as an anti-air platform, so it will indeed be much more capable than the F-35, which is optimized in the strike role, in that air dominance role. So in the air-to-air role, how many F-35s is one F-22 worth, IYO? I can't say, and I doubt anyone else could definitively answer that question. But the key to the problem is this--if you are fielding the reduced-force of F-22's as an insurance policy against the likelihood of any potential threat fielding an aircraft that could defeat our capability of acheiving air dominance over a chosen piece of real estate, and you instead decided to merely field *more* less capable F-35's, you are still left with the problem of not being able to acheive that air dominance, especially since the USAF is NOT going to assume an attritionary stance and try to win it at the cost of the hundreds of F-35 airframes (and pilots) that it might take to win by numbers advantage alone. I personally like the idea of reducing the F-22 force to that 200 ballpark. It gives us that silver bullet capability and frees up some funding for other vital requirements (i.e., tankers, ISR platforms, improved precision strike capabilites, airlift, UCAV's, etc.). Military planners are used to having to deal with two threat scenario categories--the most likely enemy course of action, and the most dangerous enemy course of action. Minimizing the F-22 buy makes more funds available to take care of the kind of contingencies that fall into the former category, while still maintaining a force of them large enough to handle forseeable threats that require the use of the 24-karet solution means you have also addressed the latter categry. Brooks -- "It's easier to find people online who openly support the KKK than people who openly support the RIAA" -- comment on Wikipedia (Email: zen19725 at zen dot co dot uk) |
On Tue, 17 Feb 2004 20:26:09 -0500, Kevin Brooks wrote:
If China attacked one of its neighbours, that country would very likely allow the USAF to base there. If the PRC attacked one of its neighbors, none of which have exactly a lot of geographic space to trade for the time None? Not even Russia, India or Kazakhstan? Come to think of it, a Chinese invasion of Vietnam, Laos or Burma would have to cross some rough terrain. And then we get to those of China's near enghbours separated by water... -- "It's easier to find people online who openly support the KKK than people who openly support the RIAA" -- comment on Wikipedia (Email: zen19725 at zen dot co dot uk) |
Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 40 | October 3rd 08 03:13 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 1st 04 02:31 PM |
Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 0 | September 2nd 04 05:15 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 1 | January 2nd 04 09:02 PM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
