V-8 powered Seabee
Old November 4th 03, 02:30 AM
Jerry Springer
Corky Scott wrote:
On Sat, 01 Nov 2003 02:51:50 GMT, (Drew
Dalgleish) wrote:
Well I had my medical with the doctor that owns one of the subject
planes today. In our short conversation I asked what specific problems
he'd had with the conversion. He says the only problem has been with
the computer setting the fuel mixture too rich. They had a lot of
trouble sorting that out and are now running without using the O2
sensors. He and his father have owned this plane for many years
origionally with the franklin engine and later with a lycoming. He was
ready to sell the plane due to poor performance off the water and slow
climb rates but since doing the conversion he is very happy with the
performance now. His takeoff distances are greatly reduced, cruise has
increased by 5mph, climb rates are as high as 1500fpm. ( instead of
100fpm with the franklin on a hot day ) and his fuel burn has dropped
from 12 to 8.8gph. on autofeul.
Drew Dalgleish
Drew Drew Drew, how dare you suggest that the V-8 powered Seabees
actually perform better than their Franklin or Lycoming powered
predecessors. Prepare to be "BObbed"!
Corky Scott
I well let Bob do the BObbed part but I do have a couple questions
about the above post by the guy that said he talked to someone that changed
engines. I find the numbers difference very hard to believe without knowing more
facts. And this may have all been explained somewhere and I can't find the info.
What are the power output comparisons? I find the difference between 100 fpm and
1500 fpm pretty astonishing difference and really find it hard to believe. Also
from 12 gph to 8.8 gph and 5 faster cruise is also pretty hard to believe. I
think that if the auto engine proponents are going to convince the unbelieving
they need to at least give honest and true numbers.
Jerry
Old November 4th 03, 05:49 AM
Morgans
Also
I
unbelieving
Jerry
So basicly, you are calling this lies?
Jim in NC
Old November 4th 03, 03:03 AM
Larry Smith
"Morgans" wrote in message
believe.
Also
believe.
I
unbelieving
Jerry
Jim in NC
No, he's not; he's questioning the numbers which seem to be a little
suspect. Manufacturers of certified aircraft puff their numbers. Didn't
you know that, Morgue?
Old November 4th 03, 03:34 AM
clare @ snyder.on .ca
On Mon, 3 Nov 2003 22:03:55 -0500, "Larry Smith"
believe.
Also
believe.
I
unbelieving
Jerry
Jim in NC
The numbers are from the owner of the plane - NOT ther manufacturer.
The owner has the history through 3 engine types, over several decadrs
IIRC.
Old November 4th 03, 03:47 AM
Larry Smith
clare @ snyder.on .ca wrote in message
believe.
Also
believe.
I
unbelieving
Jerry
Jim in NC
Didn't
IIRC.
Well, I wouldn't impugn the owner or suggest he's telling one. I was just
suggesting that even the certified aircraft manufacturers puff their
numbers, and the owners do too. Human nature.
I'm on the side and in the cheering section of the auto engine conversion,
but skeptical too.
You get more accurate results by testing from 3rd parties, like at
well-monitored races and CAFE events.
Old November 4th 03, 07:02 AM
Jerry Springer
believe.
Also
believe.
I
unbelieving
Jerry
Jim in NC
Larry you and I on the same side of the fence for a change, now that is
astonishing. :-)
Old November 4th 03, 11:42 AM
Bob U.
On Tue, 04 Nov 2003 07:02:27 GMT, Jerry Springer
Jim in NC
astonishing. :-)
Less astonishing...
I'll take a bit of a different slant. g
The "numbers" published for certified aircraft are legitimate.
They can be duplicated.... *IF* one duplicates the specific
conditions that were used to generate them in the first place.
This could include a number of conditions and parameters
that are impractical for us to duplicate/measure accurately
from under our cozy shade tree.
CAVEAT
IMO, any numbers published by manufacturers, while
accurate, may not be particularly useful and possibly
misleading to the mere mortals that dare apply them in
the real world.
The irony here is....
We have some dumb bunnies that will unduly question
"numbers" from legitimate sources with everything to lose,
but will bend over backwards to accommodate any struggling
backyard operation without qualification. Go figure!!!
Perhaps this goofy behavior needs be labeled...
*UNDERDAWG SYNDROME*
Barnyard BOb -- if it sounds to be too good to be true, it is.
Old November 4th 03, 03:58 AM
You know who
On Mon, 3 Nov 2003 21:49:58 -0800, "Morgans"
Also
I
unbelieving
Jerry
Sheesh!!!
It's not about lies.
It's all about verifying what is truly factual.
Everything is suspect until proven otherwise.
It's in the nature of the real world.
Should I begin to wonder if you live in La-La Land?
Would you really bet the farm on uncorroborated
numbers from a sole source that has everything
to gain and nothing to lose by publishing such?
DIdn't your mother teach you better?
Does PT Barnum come to mind?
Barnyard BOb -- if it sounds to good to be true, it is.
Old November 4th 03, 05:14 AM
Bob U.
Also
I
unbelieving
Jerry
Pssst....
Your computer clock is lying, AGAIN.
BTW...
What do you have for horsepower numbers
as produced in these converted Seabees?
Please don't quote GM factory numbers.
They are useless for this question.
FWIW...
Fuel consumption indirectly is quite
telling of what is going on with HP.
Old November 4th 03, 06:56 AM
Jerry Springer
Jim you don't find the 1500fpm number suspect? Once again lets see the
horsepower and weight and prop comparisons.
Jerry
Also
I
unbelieving
Jerry
Jim in NC
human powered flight patrick timony Home Built 10 September 16th 03 03:38 AM
Illusive elastic powered Ornithopter Mike Hindle Home Built 6 September 15th 03 03:32 PM
Pre-Rotator Powered by Compressed Air? nuke Home Built 8 July 30th 03 12:36 PM
Powered Parachute Plans MJC Home Built 4 July 15th 03 07:29 PM
Powered Parachute Plans- correction Cy Galley Home Built 0 July 11th 03 03:43 AM
