V-8 powered Seabee
Old November 4th 03, 01:19 PM
clare @ snyder.on .ca
On Tue, 04 Nov 2003 06:56:07 GMT, Jerry Springer
Jim you don't find the 1500fpm number suspect? Once again lets see the
horsepower and weight and prop comparisons.
Jerry
FWIR, the prop is the same one used on the Franklin and Lycoming, but
I could be wrong.
Morgans wrote:
"Jerry Springer" wrote
I find the difference between 100 fpm and
1500 fpm pretty astonishing difference and really find it hard to believe.
Also
from 12 gph to 8.8 gph and 5 faster cruise is also pretty hard to believe.
I
think that if the auto engine proponents are going to convince the
unbelieving
they need to at least give honest and true numbers.
Jerry
So basicly, you are calling this lies?
Jim in NC
Old November 5th 03, 12:49 AM
Morgans
"Jerry Springer" wrote in message
ink.net...
Jerry
I really don't want to give the impression that I believe all of the numbers
are accurate. I imagine that a complete and scientific POH may be lacking,
but although the numbers may be "slightly enhanced", I believe the owner
believes them.
The 1500 FPM was probably on an optimum day, but it could also be because of
the PSRU, that the prop is bigger, and being turned with more torque,
allowing a bit more pitch.
It is also not too hard to believe that it has better efficiency than the
Lycosarus.
I agree. I would love to see a full accounting given. It sounds as though
the people have done some good work, and are more than some of BOb's wanna
bees.
A big V-8 can work. I site Orenda, or however it is spelled. After all, it
is just 2/3rds of a V-12, and we all know they can work.
Jim in NC
Old November 4th 03, 10:52 PM
Bob U.
Some folks wanna bee-lieve anything.
It would take a thermal to hoist this boat anchor at 1500 fpm.
Horsepower is horsepower is horsepower....
and so far, we don't have a clue what it is, do we?
Geejus H. Chryst, fella.
Lycosarus.
Ah ****, doofus.
Do some homework...
or are teachers exempt.
Wake up and smell...
the *FRANKLIN*.
Barnyard BOb -- if it sound to good to be true, it is.
Old November 5th 03, 02:48 AM
Lycosarus.
Ah ****, doofus.
Do some homework...
the *FRANKLIN*.
Read, SubUrban Bob
The plane in question has flown with both Lyco and Franklin power in
it's lifetime, from what has been stated here.
Now - as for efficiency. If the stock aircraft engine (any make) has
basically fixed timing (an impulse magneto to retard for starting) it
is optimized for only one combination of throttle position, mixture,
RPM, and load. That particular combination MAY never be realized.
The computer controlled system on even the lowliest of current
production automobiles optimizes the fuel mixture and ignition timing
for virtually all possible combinations of load, throttle opening,
RPM, as well as temperature and atmospheric conditions.
I know my 3.8 injected and electronically controlled 6 in my current
vehicle gives significantly better than a 30% improvement in mileage
over the 3.8 liter carbureted engine with mechanical timing advance on
my '75 Pacer did - and the van has a larger frontal area, weighs
several hundredweight more, and has air conditioning and an automatic
transmission. It is also capable of significantly higher cruising
speed, and accelerates MUCH more quickly - and the 232 inch AMC was
much more sophisticated in the control department than an old Franklin
or Lycosaur.
To go back just a bit farther, the 232 overhead valve engine in the
Pacer gave better mileage and performance than the low compression L
Head 231 in a '49 Dodge, of about the same weight.
Higher compression ratio, advanced combustion chamber design,
optimized fuel mixtures, and variable, closely controlled ignition
timing make a HUGE difference in engine efficiency and power output.
I know, Bob, you are going to say the optimized fuel mixtures and
closely controlled ignition timing are thrown out the window because
they are not running closed loop, having removed the O2 sensors.
Well, 14.7:1, or whatever the O2 sensor forces the engine to run at is
NOT the optimum for either power output or efficiency. It is simply
the mixture required for the catalytic converter to do it's job. By
removing the cat, and allowing the engine to run with a pre-plotted
mixture and timing map it can actually be MORE efficient, and more
powerful, than when constrained by the cat and O2 sensor.
The engine that was installed in the Republic SeaBee from the factory
was about equivalent, in technology and efficiency, with a 1932 Ford -
or even closer to a Model A.
The 60 hp Ford Flattie was about 209 cu inches displacement. It ran
6.6:1 compression ratio. That is basically a 3.5 liter engine.
In 1976, Ford's 200 cu inch six, with 8.7:1 compression put out 84
hp.
A 3 liter engine today can put out 200 HP - and at the same RPM as the
old Flattie still put out in excess of 160 ft lbs, at 3200 RPM,
roughly 100 HP.
The specific fuel consumption of the new engine is significantly lower
than the old engine,while producing almost double the horsepower.
In other words, SubUrban Bob, You are blowing smoke.
Old November 5th 03, 04:19 AM
Del Rawlins
On 04 Nov 2003 05:48 PM, clare @ snyder.on .ca posted the following:
or Lycosaur.
My 1973 Chevrolet pickup truck with a carbureted 350 V-8 and automatic
transmission gets between 10 and 11 mpg, city, highway, loaded, unloaded,
uphill, downhill, tailwind, headwind, whatever. A newer Chevrolet with
the same engine and fuel injection can be expected to get around 20 mpg
on the highway. Part of that is due to the better transmissions that
are used today, but mostly due to the efficiency of EFI. In addition,
modern fuel injection offers advantages in cold starting (my '94 S-10
would start instantly at 40 below zero with no preheat, though it was
normally kept plugged in when it was below zero), and operation at
extreme angles which would give a float carburetor fits (more of an
issue offroading in my Jeep). I LOVE fuel injection. But I am not
ready to fly behind an automotive based EFI system, not yet anyway.
A little over a year ago, my less than 2 year old Jeep (which uses a
descendant of your 232) coasted to a halt at mile 87 on the Parks
Highway between Fairbanks and Anchorage. The cause was a seizure of the
mechanical drive which operates the camshaft position sensor, a hall
effect module which supplies engine speed information to the computer
for the fuel injection. This single point failure instantly shut down
the fuel injection system and required around a 150 mile tow to
Anchorage, which luckily was covered under the vehicle's warranty (
particularly when you consider that I had been in the middle of Yukon,
Canada two days previously).
I would consider using an EFI with redundant sensors for required
computer inputs, but until such a beast is available, I'll have to pass.
Del Rawlins-
Remove _kills_spammers_ to reply via email.
Unofficial Bearhawk FAQ website:
http://www.rawlinsbrothers.org/bhfaq/
Old November 5th 03, 06:22 PM
Ken Bauman
Just thought I'd throw out a point for contention. (As if any more are
needed)
The O2 sensor as used in a NB Speed Density system is of little value at the
power levels used in aircraft. My understanding is that the NB O2 sensor is
mainly an emissions device. 14.7 AFR is neither best power nor is it best
economy. What it is is best emissions when combined with the proper cat. All
NB Speed Density systems that I am aware of ignore the O2 sensor at full
power.
Removing the NBO2 sensor from the engines made perfect sense when taking the
operating environment into account. In this situation (as in the car when at
full power) the computer uses preprogrammed lookup tables based on operating
and environmental considerations. A properly tuned engine can and will make
full power without an NB O2 sensor. Nothing whatsoever is given up except
emissions, but since no cat...
The NB O2 sensor has nothing to do with making max power. So why include it
on an aircraft?
The NB O2 sensor has nothing to do with max economy. So why include it on an
aircraft?
A WB O2 sensor is a different story. And there are other compromises at play
that have not been addressed here.
Regards
Ken Bauman
Old November 5th 03, 01:55 AM
Felger Carbon
"Morgans" wrote in message
Lycosarus.
Mak thet "Lycosaurus".
Its spelt "I cite Orenda". ;-)
Old November 4th 03, 03:35 AM
You know who
I well let Bob do the BObbed part but I do have a couple questions
about the above post by the guy that said he talked to someone that changed
engines. I find the numbers difference very hard to believe without knowing more
facts. And this may have all been explained somewhere and I can't find the info.
What are the power output comparisons? I find the difference between 100 fpm and
1500 fpm pretty astonishing difference and really find it hard to believe. Also
from 12 gph to 8.8 gph and 5 faster cruise is also pretty hard to believe. I
think that if the auto engine proponents are going to convince the unbelieving
Jerry
Jerry,
"Astonishing" is putting it mildly. g
Some of these auto conversion folks have got "religion".
They are 'true believers" and are as brainwashed as they come.
Nothing concerning the laws of physics need apply.
Fer instance.....
8.8 gph suggests 105 horsepower.
12 gph suggests 145 horsepower.
How does one go 5 mph faster on 40 less horsepower
and likely with a heavier engine? Dunno. but if you are
a 'TRUE BELIEVER', nothing is impossible.
If anything they said added up... someone, somewhere
would get one of these 'WONDER' conversions certified
and in the process make such folks very, very wealthy.
It's not even close to happening. The certification process
is something that keeps these black magic artists in the
shadows of reality... on web sites and newsgroups....
beckoning the next rube, guppy, wannabee or whatever.
No question, there is a sucker born every minute. Just
ain't ever gonna me.. or you, from what I have observed.
Barnyard BOb -- if it sounds too good to be true, it is.
Old November 4th 03, 11:25 PM
Russell Kent
BOb wrote:
Fer instance.....
I cannot speak for this *particular* case, but in general one "goes 5 mph faster on
40 less horsepower" by reducing the drag (parasitic and/or induced).
speculation mode=wild
Perhaps the water-cooled auto conversion has less parasitic cooling drag than the
original air-cooled engine.
/speculation
Russell Kent
Old November 5th 03, 05:48 AM
Bob U.
Fer instance.....
/speculation
Russell Kent
Perhaps....
Santa Claus will bring me a new Cessna Citation
fer Xmas and the funds to operate it, too. g
Barnyard BOb -- If it sounds to go to be true.....
human powered flight patrick timony Home Built 10 September 16th 03 03:38 AM
Illusive elastic powered Ornithopter Mike Hindle Home Built 6 September 15th 03 03:32 PM
Pre-Rotator Powered by Compressed Air? nuke Home Built 8 July 30th 03 12:36 PM
Powered Parachute Plans MJC Home Built 4 July 15th 03 07:29 PM
Powered Parachute Plans- correction Cy Galley Home Built 0 July 11th 03 03:43 AM
