On Mon, 03 Nov 2003 21:35:45 -0600, You know who
wrote: I well let Bob do the BObbed part but I do have a couple questions about the above post by the guy that said he talked to someone that changed engines. I find the numbers difference very hard to believe without knowing more facts. And this may have all been explained somewhere and I can't find the info. What are the power output comparisons? I find the difference between 100 fpm and 1500 fpm pretty astonishing difference and really find it hard to believe. Also from 12 gph to 8.8 gph and 5 faster cruise is also pretty hard to believe. I think that if the auto engine proponents are going to convince the unbelieving they need to at least give honest and true numbers. Jerry +++++++++++++++++++++++++++++++++++++++++++++++ + Jerry, "Astonishing" is putting it mildly. g Some of these auto conversion folks have got "religion". They are 'true believers" and are as brainwashed as they come. Nothing concerning the laws of physics need apply. Fer instance..... 8.8 gph suggests 105 horsepower. 12 gph suggests 145 horsepower. How does one go 5 mph faster on 40 less horsepower and likely with a heavier engine? Dunno. but if you are a 'TRUE BELIEVER', nothing is impossible. If anything they said added up... someone, somewhere would get one of these 'WONDER' conversions certified and in the process make such folks very, very wealthy. It's not even close to happening. The certification process is something that keeps these black magic artists in the shadows of reality... on web sites and newsgroups.... beckoning the next rube, guppy, wannabee or whatever. No question, there is a sucker born every minute. Just ain't ever gonna me.. or you, from what I have observed. Barnyard BOb -- if it sounds too good to be true, it is. Are you assuming that a carburated, air cooled engine with a fixed advance magneto ignition has the same fuel efficiancy as a water cooled engine with electronic fuel injection and ignition? It's quite possible that the doctor was talking in imperial gallons as thats what we used to use in Canada before being saved by the metric system. I don't think there's a big enough market for engines to justify the expense of certification. I believe Toyota certified an auto engine conversion and then shelved the project because of the small numbers of engines they could hope to sell. Thielert has a certified Mercedes deisel auto conversion that they're selling now. Drew |
On Wed, 05 Nov 2003 01:39:14 +0000, Drew Dalgleish wrote:
of engines they could hope to sell. Thielert has a certified Mercedes deisel auto conversion that they're selling now. Not to us though. For Diesel the best shot may be the DeltaHawk: http://www.deltahawkengines.com/ - Holger |
: Are you assuming that a carburated, air cooled engine with a fixed : advance magneto ignition has the same fuel efficiancy as a water : cooled engine with electronic fuel injection and ignition? Actually, for an airplane application, even a carb'd gasoline engine can obtain very good fuel economy, since it can be manually leaned for its constant operation. The benefits of a more modern engine you describe a 1. Fuel-injected: Aside from poorer fuel/air distribution in a carb'd engine, fuel injection doesn't buy you much in an airplane. Even with computer-controlled injection, all that'll give you is better transient performance. At cruise (where most fuel is burned), computer-control doesn't buy you anything more than the red knob does. 2. Water-cooling: This is a double-edged issue that's a bit loaded. Everything else being equal, a water-cooled engine doesn't give you anymore power than an air-cooled engine. What it does buy you is the ability to run higher compression ratios and/or lower octane fuel (much lower CHTs). A higher CR will give you more thermodynamic efficiency. Also, a water-cooled engine allows for more flexible (read: efficient) cooling, but then again that's not a BSFC engine argument so much as an airframe issue. 3. Timing: Having adaptive timing doesn't buy you much in cruise, since that's where the fixed-timing is set to be optimal. It will allow you to possibly run lower octane fuel, but again that doesn't directly affect BSFC. While I agree with the idea that having liquid-cooled, fuel-injected (*perhaps* digitally controlled) high-compression gasoline engines are good from an aircraft *system* performance, they do not inherently increase an airplane engine's already excellent cruise fuel economy. I routinely get 0.42 lbs/hp*hr from my carb'd Lycoming O-360. -Cory -- ************************************************** *********************** * The prime directive of Linux: * * - learn what you don't know, * * - teach what you do. * * (Just my 20 USm$) * ************************************************** *********************** |
![]() : Are you assuming that a carburated, air cooled engine with a fixed : advance magneto ignition has the same fuel efficiancy as a water : cooled engine with electronic fuel injection and ignition? Actually, for an airplane application, even a carb'd gasoline engine can obtain very good fuel economy, since it can be manually leaned for its constant operation. The benefits of a more modern engine you describe a 1. Fuel-injected: Aside from poorer fuel/air distribution in a carb'd engine, fuel injection doesn't buy you much in an airplane. Even with computer-controlled injection, all that'll give you is better transient performance. At cruise (where most fuel is burned), computer-control doesn't buy you anything more than the red knob does. 2. Water-cooling: This is a double-edged issue that's a bit loaded. Everything else being equal, a water-cooled engine doesn't give you anymore power than an air-cooled engine. What it does buy you is the ability to run higher compression ratios and/or lower octane fuel (much lower CHTs). A higher CR will give you more thermodynamic efficiency. Also, a water-cooled engine allows for more flexible (read: efficient) cooling, but then again that's not a BSFC engine argument so much as an airframe issue. 3. Timing: Having adaptive timing doesn't buy you much in cruise, since that's where the fixed-timing is set to be optimal. It will allow you to possibly run lower octane fuel, but again that doesn't directly affect BSFC. While I agree with the idea that having liquid-cooled, fuel-injected (*perhaps* digitally controlled) high-compression gasoline engines are good from an aircraft *system* performance, they do not inherently increase an airplane engine's already excellent cruise fuel economy. I routinely get 0.42 lbs/hp*hr from my carb'd Lycoming O-360. -Cory ++++++++++++++++++++++++++++++++++++++++++++++++++ BINGO. Thanx, Cory Barnyard BOb -- over 50 years of successful flight |
On Tue, 04 Nov 2003 02:30:54 GMT, Jerry Springer
wrote: Corky Scott wrote: On Sat, 01 Nov 2003 02:51:50 GMT, (Drew Dalgleish) wrote: Well I had my medical with the doctor that owns one of the subject planes today. In our short conversation I asked what specific problems he'd had with the conversion. He says the only problem has been with the computer setting the fuel mixture too rich. They had a lot of trouble sorting that out and are now running without using the O2 sensors. He and his father have owned this plane for many years origionally with the franklin engine and later with a lycoming. He was ready to sell the plane due to poor performance off the water and slow climb rates but since doing the conversion he is very happy with the performance now. His takeoff distances are greatly reduced, cruise has increased by 5mph, climb rates are as high as 1500fpm. ( instead of 100fpm with the franklin on a hot day ) and his fuel burn has dropped from 12 to 8.8gph. on autofeul. Drew Dalgleish Drew Drew Drew, how dare you suggest that the V-8 powered Seabees actually perform better than their Franklin or Lycoming powered predecessors. Prepare to be "BObbed"! Corky Scott I well let Bob do the BObbed part but I do have a couple questions about the above post by the guy that said he talked to someone that changed engines. I find the numbers difference very hard to believe without knowing more facts. And this may have all been explained somewhere and I can't find the info. What are the power output comparisons? I find the difference between 100 fpm and 1500 fpm pretty astonishing difference and really find it hard to believe. Also from 12 gph to 8.8 gph and 5 faster cruise is also pretty hard to believe. I think that if the auto engine proponents are going to convince the unbelieving they need to at least give honest and true numbers. Jerry I lurk here pretty much daily and was following this thread. So when I had my medical I asked the doctor about his plane and reported what he told me. I don't have any reason to believe he would lie about his numbers. He's not the one selling the engines he's just one outwardly very satisfied customer. I'm sure the 100fpm climb was fully loaded on the hottest day of the year and 1500fpm came when it was a little cooler and lighter. Drew |
On Wed, 05 Nov 2003 01:15:21 GMT, (Drew
Dalgleish) wrote: On Tue, 04 Nov 2003 02:30:54 GMT, Jerry Springer wrote: Corky Scott wrote: On Sat, 01 Nov 2003 02:51:50 GMT, (Drew Dalgleish) wrote: Well I had my medical with the doctor that owns one of the subject planes today. In our short conversation I asked what specific problems he'd had with the conversion. He says the only problem has been with the computer setting the fuel mixture too rich. They had a lot of trouble sorting that out and are now running without using the O2 sensors. He and his father have owned this plane for many years origionally with the franklin engine and later with a lycoming. He was ready to sell the plane due to poor performance off the water and slow climb rates but since doing the conversion he is very happy with the performance now. His takeoff distances are greatly reduced, cruise has increased by 5mph, climb rates are as high as 1500fpm. ( instead of 100fpm with the franklin on a hot day ) and his fuel burn has dropped from 12 to 8.8gph. on autofeul. Drew Dalgleish Drew Drew Drew, how dare you suggest that the V-8 powered Seabees actually perform better than their Franklin or Lycoming powered predecessors. Prepare to be "BObbed"! Corky Scott I well let Bob do the BObbed part but I do have a couple questions about the above post by the guy that said he talked to someone that changed engines. I find the numbers difference very hard to believe without knowing more facts. And this may have all been explained somewhere and I can't find the info. What are the power output comparisons? I find the difference between 100 fpm and 1500 fpm pretty astonishing difference and really find it hard to believe. Also from 12 gph to 8.8 gph and 5 faster cruise is also pretty hard to believe. I think that if the auto engine proponents are going to convince the unbelieving they need to at least give honest and true numbers. Jerry I lurk here pretty much daily and was following this thread. So when I had my medical I asked the doctor about his plane and reported what he told me. I don't have any reason to believe he would lie about his numbers. He's not the one selling the engines he's just one outwardly very satisfied customer. I'm sure the 100fpm climb was fully loaded on the hottest day of the year and 1500fpm came when it was a little cooler and lighter. Drew I'm not so sure it isn't head to head - same conditions, knowing the condition the old Franklin was in!!! It was a case of get a REAL engine in the bird, or park it. I know the climb and cruise were down a bit from original spec, and the margin for error on the old Republic was pretty fine to start with. Like the BumbleBee, it really should not fly. Like an old friend of mine used to say, they were so ugly the earth repelled them, or they'd never get off the ground. But beauty is in the eye of the beholder, and the old Bee kind a grows on ya - But then I owned a Terraplane and a Pacer and liked the looks of both, so wat do I know. |
human powered flight | patrick timony | Home Built | 10 | September 16th 03 03:38 AM |
Illusive elastic powered Ornithopter | Mike Hindle | Home Built | 6 | September 15th 03 03:32 PM |
Pre-Rotator Powered by Compressed Air? | nuke | Home Built | 8 | July 30th 03 12:36 PM |
Powered Parachute Plans | MJC | Home Built | 4 | July 15th 03 07:29 PM |
Powered Parachute Plans- correction | Cy Galley | Home Built | 0 | July 11th 03 03:43 AM |
