Day 2 Central Calif. Soaring Club Spring Contest
Old May 14th 11, 03:01 AM posted to rec.aviation.soaring
Alex[_5_]
Default Day 2 Central Calif. Soaring Club Spring Contest
37th Annual Avenal Spring Contest
Avenal, CA
Cumulative Summary
Sports Class Class
May 15, 11 May 14, 11 May 13,
11 May 12, 11
Cumulative Score No Contest No Contest Mod
Assgn: 02:30 Turn Area: 02:30
Rank Points ID SSA# Name Glider Rank Points Rank
Points Rank Points Rank Points
1 1642 P7 822736 Ittner, Gary Discus 2A 0 0 1
868 3 774
2 1617 5H 849010 Hall, Morgan Duo Discus 0 0 2
823 1 794
3 1576 2T 860414 Deane, Peter LS-8-15 0 0 2
823 4 753
4 1338 BK 505932 Reid, Michael H-201 Std Libelle 0
0 9 563 2 775
5 1287 WX 627801 Rogers, Walt Discus 2A W 0 0 5
695 7 592
6 1257 C2 132403 Colacevich, Sergio Ventus 2C-18 0 0 6
664 6 593
7 1033 F8 0 Gawthrop, Bill ASH-26E 0 0 4
759 14 274
8 973 5K 904141 Alton, Jim LAK-17A-15 0 0 11
543 9 430
9 863 SD 732001 Indrebo, Rick ASW-27 0 0 7
642 15 221
10 792 YE 18157 Roberts, Larry ASG 29-18 0 0 13
141 5 651
11 743 JJ 680958 Sinclair, John Genesis II 0 0 8
582 17 161
12 701 GD 902147 Kunz, Karl ASW-20B-15 0 0 10
551 18 150
13 650 HU 912388 Tuohino, Larry PIK-20D-78 0 0 12
462 16 188
14 587 NF 673293 Smith, Steve LS-6C-15 0 0 14
90 8 497
15 415 96S 0 Patton, Bruce HP-18 0 0 15
0 10 415
16 385 E4 0 Hess, Ron DG-800B MW 0 0 15
0 11 385
17 373 YC 620 Anderson, Rick ASW-27 0 0 15
0 12 373
18 334 6X 42845 Leffler, Al Ventus 2c-15 0 0
15 0 13 334
19 0 RM 0 Holtz, Russel DG-1000 0 0 15
0 19 0
Created on Friday May 13, 2011 - 18:59 by Winscore Rev 5,
http://www.gfbyars.com/winscore
Old May 14th 11, 03:50 PM posted to rec.aviation.soaring
Morgan[_2_]
A quick recap of the day for those that couldn't make it.
Mother nature threw a curve ball with some high cirrus moving in from
the south. RASP predictions showed a strong convergence down the
temblor range. At 10:00 the task committee called a task down to
Panorama Pt. and then back up to New Idria for 220 nominal I think.
An alternate MAT task was called with a 1mi turn at Blackwell and then
have at it.
At 12:30 heavy cirrus had filled in from the south. CD Stephen Smith
called a quick consensus building meeting on the grid and we opted to
change the MAT to a first turnpoint at New Coalinga and delay launch
another 45 minutes or so.
Launches got rolling around 1:15 and 18 gliders took to darkening
skies from the southern cirrus. NW it was clear and there were cu
marking the convergence up towards Hernandez Reservoir and EL5 so the
RASP was calling the convergence correctly, but the cirrus was
shutting down the heating to the south just as weatherman Dan Gudgel
had predicted.
Most everyone struggled a little bit at first with only a couple of
thermals working. Those of us at the back of the line launched into
complete overcast conditions and really had to search to find
something worth a start.
New Coalinga ended up being in the center of a very dark area. To the
west the convergence was setting up well with clouds at about 8500.
Various tactics were chosen for getting the first turnpoint. 4 paid
the price of a direct route and ended up on the ground. Several of us
were able to get the first turn and dive into the foothills to get up
in choppy lift and then get us into the convergence. Once connected,
the convergence was working great and the New Idria and Panoche
turnpoints were the way to go as the line was perfectly marked all the
way to Panoche and could be done with few turns.
From Panoche, the top finishers all came back and tagged Old Coalinga
and then returned to New Idria before heading for home. I managed to
link up with Peter Deane and we raced for the last hour within sight
of each other. Great fun trying find some kind of advantage and
watching how our decisions compared.
We shall see what the weather holds for Day 3 and 4. Looking funky.
Morgan
Avenal, CA
Cumulative Summary
Sports Class Class
* * * * * * * * * * * * * * * * * * * * * * * * * * * * May 15, 11 * * * * * * *May 14, 11 * * * * * * *May 13,
11 * * * * * * *May 12, 11
Cumulative Score * * * * * * * * * * * * * * * * * * * *No Contest * * * * * * *No Contest * * * * * * *Mod
Assgn: 02:30 * * * * * *Turn Area: 02:30
*Rank * Points *ID * * *SSA# * *Name * * * * * * * * * *Glider * * * * *Rank * *Points *Rank
Points *Rank * *Points *Rank * *Points
* * 1 * * 1642 * P7 * * * 822736 * * * *Ittner, Gary * * * * * *Discus 2A * * * * * * * 0 * * * * * * * 0 * * * *1
868 * * *3 * * * *774
* * 2 * * 1617 * 5H * * * 849010 * * * *Hall, Morgan * * * * * *Duo Discus * * * * * * *0 * * * * * * * 0 * * * *2
823 * * *1 * * * *794
* * 3 * * 1576 * 2T * * * 860414 * * * *Deane, Peter * * * * * *LS-8-15 * * * * * * * * 0 * * * * * * * 0 * * * *2
823 * * *4 * * * *753
* * 4 * * 1338 * BK * * * 505932 * * * *Reid, Michael * * * * * H-201 Std Libelle * * * * * * * 0
0 * * * *9 * * * *563 * *2 * * * *775
* * 5 * * 1287 * WX * * * 627801 * * * *Rogers, Walt * * * * * *Discus 2A W * * * * * * 0 * * * * * * * 0 * * * *5
695 * * *7 * * * *592
* * 6 * * 1257 * C2 * * * 132403 * * * *Colacevich, Sergio * * *Ventus 2C-18 * * * * * *0 * * * * * * * 0 * * * *6
664 * * *6 * * * *593
* * 7 * * 1033 * F8 * * * * * *0 * * * *Gawthrop, Bill * * * * *ASH-26E * * * * * * * * 0 * * * * * * * 0 * * * *4
759 * * 14 * * * *274
* * 8 * * *973 * 5K * * * 904141 * * * *Alton, Jim * * * * * * *LAK-17A-15 * * * * * * *0 * * * * * * * 0 * * * 11
543 * * *9 * * * *430
* * 9 * * *863 * SD * * * 732001 * * * *Indrebo, Rick * * * * * ASW-27 * * * * * * * * *0 * * * * * * * 0 * * * *7
642 * * 15 * * * *221
* *10 * * *792 * YE * * * *18157 * * * *Roberts, Larry * * * * *ASG 29-18 * * * * * * * 0 * * * * * * * 0 * * * 13
141 * * *5 * * * *651
* *11 * * *743 * JJ * * * 680958 * * * *Sinclair, John * * * * *Genesis II * * * * * * *0 * * * * * * * 0 * * * *8
582 * * 17 * * * *161
* *12 * * *701 * GD * * * 902147 * * * *Kunz, Karl * * * * * * *ASW-20B-15 * * * * * * *0 * * * * * * * 0 * * * 10
551 * * 18 * * * *150
* *13 * * *650 * HU * * * 912388 * * * *Tuohino, Larry * * * * *PIK-20D-78 * * * * * * *0 * * * * * * * 0 * * * 12
462 * * 16 * * * *188
* *14 * * *587 * NF * * * 673293 * * * *Smith, Steve * * * * * *LS-6C-15 * * * * * * * *0 * * * * * * * 0 * * * 14
90 * * * 8 * * * *497
* *15 * * *415 *96S * * * * * *0 * * * *Patton, Bruce * * * * * HP-18 * * * * * * * * * 0 * * * * * * * 0 * * * 15
0 * * * 10 * * * *415
* *16 * * *385 * E4 * * * * * *0 * * * *Hess, Ron * * * * * * * DG-800B MW * * * * * * *0 * * * * * * * 0 * * * 15
0 * * * 11 * * * *385
* *17 * * *373 * YC * * * * *620 * * * *Anderson, Rick * * * * *ASW-27 * * * * * * * * *0 * * * * * * * 0 * * * 15
0 * * * 12 * * * *373
* *18 * * *334 * 6X * * * *42845 * * * *Leffler, Al * * * * * * Ventus 2c-15 * * * * * *0 * * * * * * * 0
15 * * * * *0 * 13 * * * *334
* *19 * * * *0 * RM * * * * * *0 * * * *Holtz, Russel * * * * * DG-1000 * * * * * * * * 0 * * * * * * * 0 * * * 15
0 * * * 19 * * * * *0
Created on Friday May 13, 2011 - 18:59 by Winscore *Rev 5,http://www.gfbyars.com/winscore
Day 1 Central Calif. Soaring Club Spring Contest Alex[_5_] Soaring 3 May 13th 11 08:38 PM
Central California Soaring Contest, Avenal Update Mario[_2_] Soaring 0 May 10th 10 05:02 PM
RESCO Spring Seminar March 24 '07, So Calif, USA CindyASK Soaring 1 March 16th 07 01:34 AM
RESCO Spring Seminar April 8, So Calif, USA CindyASK Piloting 1 April 2nd 06 07:59 PM
RESCO Spring Seminar April 8, So Calif, USA CindyASK Soaring 1 April 2nd 06 07:59 PM
