On 18 mai, 18:06, JJ Sinclair wrote:
On May 18, 2:31*pm, Randy wrote: I put a lot of miles on my Cobra trailer every year going to various soaring locations. The hole that the sliding latch uses to secure the lower tailgate, it getting larger with every mile on the road. I've thought about using a latch similar to the latches used on my tail dolly, but I want to see what other guys are doing. Your suggestions are very much appreciated. Randy Teel N304BU http://talihinasoaring.com/ Drill the proper sized hole in a replacement peace of aluminum (or steel) and then pop-rivet it over the big hole...............OR remove the latch and pop-rivet it in place an inch or two lower, then drill a new hole in the side member. JJ Hi I used the steel plate method describe by JJ. It work's S6 |
On May 18, 3:14*pm, "rec.aviation.soaring" wrote:
On 18 mai, 18:06, JJ Sinclair wrote: On May 18, 2:31*pm, Randy wrote: I put a lot of miles on my Cobra trailer every year going to various soaring locations. The hole that the sliding latch uses to secure the lower tailgate, it getting larger with every mile on the road. I've thought about using a latch similar to the latches used on my tail dolly, but I want to see what other guys are doing. Your suggestions are very much appreciated. Randy Teel N304BU http://talihinasoaring.com/ Drill the proper sized hole in a replacement peace of aluminum (or steel) and then pop-rivet it over the big hole...............OR remove the latch and pop-rivet it in place an inch or two lower, then drill a new hole in the side member. JJ Hi I *used the steel plate method describe by JJ. It work's S6 I used an aluminum plate over the hole and pop-riveted it into place. I also replaced the retaining bolt and added a sleeve over the threads where it goes into the hole. The threads make a very nice file as the ramp shifts fore and aft while in motion. that's why the hole gets bigger to begin with... Matt |
Hanger Queen meets Cobra - Cobra Girl 01.jpg | [email protected] | Aviation Photos | 0 | February 5th 09 12:05 PM |
Hanger Queen meets Cobra - Cobra Girl 07.jpg (1/1) | Alan Erskine[_3_] | Aviation Photos | 9 | September 20th 08 04:35 PM |
Hanger Queen meets Cobra - Cobra Girl 02.jpg (1/1) | Hans Holbein | Aviation Photos | 0 | September 19th 08 08:45 PM |
Hanger Queen meets Cobra - Cobra Girl 05.jpg (1/1) | Glenn[_2_] | Aviation Photos | 0 | September 19th 08 03:41 PM |
Latch repair on Cobra trailer | Tuno | Soaring | 2 | April 8th 08 01:21 AM |
