If this problem is primarily affecting Cobra trailers with fiberglass
tops, rather than aluminum, I wonder if the difference in thermal coefficient of expansion between the two materials might be playing a roll? On early Stemme S10-VT motorgliders, the spoiler control rods were aluminum in an otherwise mostly carbon fiber wing. The spoiler over- center locks were at the fuselage end. As the temperature dropped with altitude, the spoilers would first start to come open and then sometimes even open all the way with no pilot input. Problem was solved by changing the control rods to carbon fiber. bumper zz Minden |
On May 21, 6:25*pm, bumper wrote:
If this problem is primarily affecting Cobra trailers with fiberglass tops, rather than aluminum, I wonder if the difference in thermal coefficient of expansion between the two materials might be playing a roll? On early Stemme S10-VT motorgliders, the spoiler control rods were aluminum in an otherwise mostly carbon fiber wing. The spoiler over- center locks were at the fuselage end. As the temperature dropped with altitude, the spoilers would first start to come open and then sometimes even open all the way with no pilot input. Problem was solved by changing the control rods to carbon fiber. bumper zz Minden Bumper might be on to something. Polyester reinforced with glass fiber has a linear coefficient of thermal expansion of 25 (10^-6 m/m K) while structural steel is just 13. Aluminum is 22.2 which is close enough to steel there may not be a problem. Ref: http://www.engineeringtoolbox.com/li...ents-d_95.html The fiberglass top is, of course, exposed to the direct sunlight while the steel trailer frame stays mostly in the shade. Bill D |
I have an older (early 1992) Cobra with a fiberglass top. I haven't
spent the past 19 years on the road but the trailer doesn't live in a hangar, either. I just checked visually and all four bolts are intact and tight, the hinge plate is tight up against the aluminum cross member, and there is no sign of movement or looseness or distortion anywhere. I'll remove the bolts one by one to inspect but I'm wondering, as at least one other person did, if the cause was simply a bad batch of bolts, or perhaps improper tightening at the time of manufacture. For sure, once there's looseness anywhere in the bolted system, the likelihood of failure rises significantly. Chip Bearden ASW 24 "JB" USA |
On May 21, 8:30*pm, bildan wrote:
On May 21, 6:25*pm, bumper wrote: If this problem is primarily affecting Cobra trailers with fiberglass tops, rather than aluminum, I wonder if the difference in thermal coefficient of expansion between the two materials might be playing a roll? On early Stemme S10-VT motorgliders, the spoiler control rods were aluminum in an otherwise mostly carbon fiber wing. The spoiler over- center locks were at the fuselage end. As the temperature dropped with altitude, the spoilers would first start to come open and then sometimes even open all the way with no pilot input. Problem was solved by changing the control rods to carbon fiber. bumper zz Minden Bumper might be on to something. Polyester reinforced with glass fiber has a linear coefficient of thermal expansion of 25 (10^-6 m/m K) while structural steel is just 13. *Aluminum is 22.2 which is close enough to steel there may not be a problem. Ref:http://www.engineeringtoolbox.com/li...fficients-d_95..... The fiberglass top is, of course, exposed to the direct sunlight while the steel trailer frame stays mostly in the shade. Bill D Steel trailer frame? Not on mine. I assume Bumper was talking about relative expansion of the bolts and the clamped parts. Andy |
On May 22, 7:56*am, Andy wrote:
On May 21, 8:30*pm, bildan wrote: On May 21, 6:25*pm, bumper wrote: If this problem is primarily affecting Cobra trailers with fiberglass tops, rather than aluminum, I wonder if the difference in thermal coefficient of expansion between the two materials might be playing a roll? On early Stemme S10-VT motorgliders, the spoiler control rods were aluminum in an otherwise mostly carbon fiber wing. The spoiler over- center locks were at the fuselage end. As the temperature dropped with altitude, the spoilers would first start to come open and then sometimes even open all the way with no pilot input. Problem was solved by changing the control rods to carbon fiber. bumper zz Minden Bumper might be on to something. Polyester reinforced with glass fiber has a linear coefficient of thermal expansion of 25 (10^-6 m/m K) while structural steel is just 13. *Aluminum is 22.2 which is close enough to steel there may not be a problem. Ref:http://www.engineeringtoolbox.com/li...fficients-d_95.... The fiberglass top is, of course, exposed to the direct sunlight while the steel trailer frame stays mostly in the shade. Bill D Steel trailer frame? *Not on mine. *I assume Bumper was talking about relative expansion of the bolts and the clamped parts. Andy I know later Cobra frames are aluminum which is why I listed its coefficient of expansion. However, I should have said "metal" frame. I think Bumper was thinking of the top and bottom being firmly attached to each other at the front and back of the trailer with each expanding at different rates producing a force on the hinge plates. Fiberglass tops expand at twice the rate of metal frames. Working the numbers, it's unlikely the difference could be more than a few mm. |
Cobra Trailer Spare Tire mount failure | Barny | Soaring | 29 | July 23rd 15 12:52 AM |
Cobra bottle jack failure | db_sonic | Soaring | 15 | October 30th 09 03:34 PM |
cobra trailer brake lever gas strut failure? | Frank[_1_] | Soaring | 11 | March 31st 09 08:59 PM |
Hanger Queen meets Cobra - Cobra Girl 07.jpg (1/1) | Alan Erskine[_3_] | Aviation Photos | 9 | September 20th 08 04:35 PM |
Hanger Queen meets Cobra - Cobra Girl 05.jpg (1/1) | Glenn[_2_] | Aviation Photos | 0 | September 19th 08 03:41 PM |
