I have just checked my UK based 15M 1999 Cobra trailer (glass sandwich
top). This has only been towed on reasonably smooth roads (excluding the odd field) and only very occasionally opened in strong winds . There is some slight compression to the glass shell at the outer mounting holes on each handle. When checking the bolt tightness I noticed that the nuts on the outside mounting bolts (inside the trailer on the hinge plate) are both not square to the hinge plate as though they were fitted at a slight angle. (approx 1mm gap is at the top of the bolt ) . I have vague recollections they had always been like this and assumed at the time that this was because it was not possible to square everything up when mounting the bolts at the factory. However, I now wonder if the lid has moved up slightly inclining the outer bolts. I “gently” tightened all the bolts a couple of turns (using a small 6” spanner to limit torque) so it would appear that they were working loose. I was in a hurry when I did this and seem to remember the extra torque reduced the gap at the top of the inclined bolts. Few of questions - Has anyone else noticed if any of their hinge mounting bolts were at a slight angle when delivered ? - Does anyone have a “method” of judging how tight to do these bolts should be. I am loath to snap them or do more compression damage before I get round to re-enforcing the handle area and fitting stronger bolts. - Regarding clamping the hinge to the aluminium cross member. When the bolts are removed what stops the aluminium cross member from ripping out of the top shell. I assume it is glued in ? |
On May 23, 7:48*am, Ian Reekie wrote:
When the bolts are removed what stops the aluminium cross member from ripping out of the top shell. I assume it is glued in ? It is riveted to the top side rails. However one US owner has found all rivets sheared. All mine seem ok. In any event you should only change one bolt at a time! Andy |
Interesting, I took a couple of pictures of the hinge and they seem to show
no structural connection from the side rails to my cross member ? I am flying tomorrow so I will examine this further, but I wonder if they varied the construction. Many of my aluminium support brackets are glued to the shell with what looks like a black polyurethane glue, similar to that used in the car industry to glue panels. I assumed this was the case for this cross member. I agree that It would be ideal to change one bolt at a time, but I was thinking of implement Steve Koerners mod which I believe would require you to remove both bolts to get the 1/4" spacer under the handle ? It is riveted to the top side rails. However one US owner has found all rivets sheared. All mine seem ok. In any event you should only change one bolt at a time! Andy |
On May 23, 10:39*am, Ian Reekie wrote:
Interesting, I took a couple of pictures of the hinge and they seem to show no structural connection from the side rails to my cross member ? I am flying tomorrow so I will examine this further, but I wonder if they varied the construction. *Many of my aluminium support brackets are glued to the shell with what looks like a black polyurethane glue, similar to that used in the car industry to glue panels. *I assumed this was the case for this cross member. I agree that It would be ideal to change one bolt at a time, but I was thinking of implement Steve Koerners mod which I believe would require you to remove both bolts to get the 1/4" spacer under the handle ? It is riveted to the top side rails. However one US owner has found all rivets sheared. All mine seem ok. In any event you should only change one bolt at a time! Andy- Hide quoted text - - Show quoted text - Mine also has the black glue. Email me and I'll send you a photo that shows the rivet locations. It should be easy to change one bolt at a time even when introducing the new plate. Just leave the first new bolt slightly loose so the plate can be rotated into alignment after the second bolt is removed. Even if you decide to remove the handle to work on it you can still put bolts in place to maintain the alignment. Having dealt with this issue once I would go to great length to ensure that both bolts were never removed at the same time. If you want all the bolts out then raising the top, disconnecting the gas struts, and then doing all the hinge work with the top closed may be the way to go. You'll need several strong friends or an overhead hoist though. Andy |
Cobra Trailer Spare Tire mount failure | Barny | Soaring | 29 | July 23rd 15 12:52 AM |
Cobra bottle jack failure | db_sonic | Soaring | 15 | October 30th 09 03:34 PM |
cobra trailer brake lever gas strut failure? | Frank[_1_] | Soaring | 11 | March 31st 09 08:59 PM |
Hanger Queen meets Cobra - Cobra Girl 07.jpg (1/1) | Alan Erskine[_3_] | Aviation Photos | 9 | September 20th 08 04:35 PM |
Hanger Queen meets Cobra - Cobra Girl 05.jpg (1/1) | Glenn[_2_] | Aviation Photos | 0 | September 19th 08 03:41 PM |
