Lift - Newton/Bernoulli ratio...
Old May 24th 11, 09:42 AM
SophiaEnman SophiaEnman is offline
Banned
First recorded activity by AviationBanter: Apr 2011
Send a message via ICQ to SophiaEnman
Prodam credit card database - 130 000 lines in it, - put together countries - CA,US,DE,DENMARK,IT,UK,EST,LH,CZ, and other EU,+ TW,Thailand and other. Valid -5-30%.
Can plain you wholly Team Viewer, can wor through Garant (escrow). Lowest decree 5000 lines - fee - 0,07$ per line. if scale more than 10k lines then 0,05$ per line.
All derive 130000 cc - 10000$ . Contacts email: skype:ccseller icq:603948540
Prodam credit card database - 130 000 lines in it, - mix countries - CA,US,DE,DENMARK,IT,UK,EST,LH,CZ, and other EU,+ TW,Thailand and other. Valid -5-30%.
Can show you through Team Viewer, can wor through Garant (escrow). Minimum order 5000 lines - price - 0,07$ per line. if order more than 10k lines then 0,05$ per line.
All base 130000 cc - 10000$ . Contacts email -
Old May 24th 11, 09:44 AM
Banned
Prodam confidence pasteboard database - 130 000 lines in it, - puzzle countries - CA,US,DE,DENMARK,IT,UK,EST,LH,CZ, and other EU,+ TW,Thailand and other. Valid -5-30%.
Can exhibit you to Side Viewer, can wor auspices of Garant (escrow). Least status 5000 lines - cost - 0,07$ per line. if structure more than 10k lines then 0,05$ per line.
All base 130000 cc - 10000$ . Contacts email: skype:ccseller icq:603948540
Old May 24th 11, 09:48 AM
Banned
Prodam credit be forthright database - 130 000 lines in it, - put together countries - CA,US,DE,DENMARK,IT,UK,EST,LH,CZ, and other EU,+ TW,Thailand and other. Valid -5-30%.
Can demonstrate you to Side Viewer, can wor including Garant (escrow). Least status 5000 lines - fee - 0,07$ per line. if order more than 10k lines then 0,05$ per line.
Old May 24th 11, 09:51 AM
Banned
Prodam credit pasteboard database - 130 000 lines in it, - puzzle countries - CA,US,DE,DENMARK,IT,UK,EST,LH,CZ, and other EU,+ TW,Thailand and other. Valid -5-30%.
Can exhibit you through Side Viewer, can wor by Garant (escrow). Least order 5000 lines - sacrifice - 0,07$ per line. if structure more than 10k lines then 0,05$ per line.
All post 130000 cc - 10000$ . Contacts email: skype:ccseller icq:603948540
Old May 24th 11, 09:53 AM posted to rec.aviation.piloting
Dylan Smith[_2_]
Default Lift - Newton/Bernoulli ratio...
On 2011-05-23, Dave Doe wrote:
Thanks for the reply - looking for numbers, not the physics behind it.
IE looking for the percentage of lift obtained by each - and as I said,
although this is variable dependent no doubt on the plane and the
airspeed - just trying to get a rough idea (hence, say a C-172 or a
737).
100% is produced by Newton's laws.
100% is produced by Bernoulli's principles.
The laws of physics are not additive with "x% produced by Newton and y%
by Bernouilli", they are complementary. They are merely looking at
the same phenomenon - lift - from different perspectives.
Also, note that if you hear "the air travels faster over the curved
surface of the top of the wing so it meets the air going underneath
at the same time", this is wrong. The transit times are not equal,
air going over the top of the wing gets accelerated and arrives
at the trailing edge _before_ the air that goes underneath.
Old May 24th 11, 09:55 AM
Banned
Prodam confidence be forthright database - 130 000 lines in it, - put together countries - CA,US,DE,DENMARK,IT,UK,EST,LH,CZ, and other EU,+ TW,Thailand and other. Valid -5-30%.
Can exhibit you through Side Viewer, can wor including Garant (escrow). Least order 5000 lines - fee - 0,07$ per line. if order more than 10k lines then 0,05$ per line.
Old May 24th 11, 09:57 AM
Banned
Prodam assign be forthright database - 130 000 lines in it, - hobnob countries - CA,US,DE,DENMARK,IT,UK,EST,LH,CZ, and other EU,+ TW,Thailand and other. Valid -5-30%.
Can show you through Side Viewer, can wor through Garant (escrow). Minimum order 5000 lines - sacrifice - 0,07$ per line. if order more than 10k lines then 0,05$ per line.
  #28
Old May 24th 11, 09:58 AM posted to rec.aviation.piloting
Dylan Smith[_2_]
I'll rephrase it a second time. What percentage of extra lift is gained
a) a plank of wood (can only produce lift via angle of attack)
vs
100% Newton
100% Bernouilli
b) a plank of wood that is an airfoil - and is getting lift from both
angle of attack and the Bernoulli effect.
100% Newton
100% Bernouilli
  #29
Old May 24th 11, 10:01 AM
Banned
Prodam confidence car-card database - 130 000 lines in it, - puzzle countries - CA,US,DE,DENMARK,IT,UK,EST,LH,CZ, and other EU,+ TW,Thailand and other. Valid -5-30%.
Can demonstrate you as a consequence Yoke Viewer, can wor auspices of Garant (escrow). Lowest status 5000 lines - price - 0,07$ per line. if order more than 10k lines then 0,05$ per line.
  #30
Old May 24th 11, 02:21 PM posted to rec.aviation.piloting
Dave Doe
In article 1454525a-4a26-432c-a550-42e437fb2070
@f11g2000vbx.googlegroups.com, , Dudley
Henriques says...
On May 23, 4:40*am, Dave Doe wrote:
In article , , Private
says...
"Dave Doe" wrote in message
, Mxsmanic says...
Dave Doe writes:
So a wing generates as much lift upside down? *
Absolutely..........without question! The EXACT same explanation of
lift creation is in play on an inverted wing as on the upright wing.
Applies to barn doors as well.
Newton= 100% Bernoulli= 100%.
Dudley Henriques
We're talking lift here mate - that's in the upwards direction!
If you are right, I'd expect to see planes with the airfoil upsidedown
(with the increased camber on the bottom), but that's not the case (and
I'm talking about the *wings* here, not the horizontal stabiliser
However, I'm getting what you're saying - and will now argue with my
mate that an airfoil is simply a more *efficient* device (vs. a barn
door).
He has not disagreed that:
* All wings (barn door or airfoil) create lift by deflecting
(accelerating) air (which has mass), down. Simple. F=ma.
* An airfoil produces lift by Newtonian mechanics in the same way as a
barn door (angle of attack), *but* ...
* An airfoil has increased camber over the top surface - and the air
flowing around that is pulling air down - a low pressure area is created
(and the air is accelerated over the wing (lets not go into the air
particles meet up, same as the bottom fallacy - and nor are either of us
arguing over that)).
I think you have explained though, that the Bernoulli effect occurs with
a barn door too at an angle of attack - however it is a lot less
*efficient* without that camber (which will continue to 'suck' air down
- as the camber continues to change direction - and therefore drag the
viscous air around it with it). I hope you'll agree with that.
In my reading up of the Bernoulli principle on various pages, it seems
to me that one of it's most important uses is that is often used as an
accurate *means* by which lift is calculated.
It should be an interesting argument - and many thanks for your replies.
I won't reply to your other responses - don't think it's necessary.
Duncan.
Three take offs = three landings at Newton MS and Madison MS - Video [email protected] Piloting 39 November 28th 09 01:22 AM
How can the Magnus effect be explained with Bernoulli? Mikki Piloting 4 June 24th 09 05:51 AM
Lift-to-Drag Ratio? Toks Desalu Home Built 6 November 23rd 03 10:53 PM
The bernoulli theory of starting a long thread David CL Francis Piloting 7 October 26th 03 07:40 PM
worked fairly well - the German 37mm and British 40mm, frank mitch newton on Stukas fmn2 Naval Aviation 1 August 10th 03 02:14 AM
