On May 24, 10:03*pm, a wrote:
On May 24, 10:35*am, Dudley Henriques wrote: On May 23, 9:31*pm, a wrote: On May 22, 10:02*pm, brian whatcott wrote: On 5/22/2011 5:15 AM, Dave Doe wrote: Does anyone have any figures and references for about what ratio lift is produced by Newton's Laws and Bernoulli's Laws? I appreciate this is not a static figure - but say a yer average C-172, or perhaps a 737. I would hazard a semi-educated guess that lift is *primarily* produced by angle of attack (or deflection if you like) - Newton's Laws - and by a much lesser degree by Bernoulli's Law. *I would guess that Bernoulli's principle might create 20% of the lift a wing generates. *A friend believes it would be much lesser - about 5%. Think of it this way: Newton: force is proportional to the mass and its acceleration. In this context, the meaning is, to produce the aircraft's weight in lift i.e. upwards , an airmass has to move *with sufficent acceleration to provide that up force. Bernoulii: the mass of air flowing through a channel times its speed gives the same product even if the channel then narrows to a waist: the air mass has to flow faster, but its pressure drops.. In this context: air flowing in an airstream over a wing sees it bulging (or waisting) and so that it needs to speed up, and pressure drops over the upper wing. Arguments of this type can be used as evidence that 2/3 of the wing lift is produced at the upper surface, and 1/3 at the lower wing surface. The larger truth: air pressure drops over the upper surface of a wing, and increases over the lower surface of a wing, and the resultant downflow balances the lift on the wing. Brian W *theories anyone here really believe there is no change in air density as if flows at speeds of a hundred miles an hour past an airfoil? The equation works well for water flow in pipes and around boat hulls. It does not do such a good job of predicting pressures along an airfoil. Stick with Newtonian Physics and the gas laws. The ideal gas law still applies. Compressing airflow does indeed complicate Bernoulli as do the density changes involved but Bernoulli still holds up. Both theories remain correct even with compressible flow. But you are correct in that the Newton explanation is FAR easier of the two for people to deal with and understand. The only caveat I stress to instructors when getting into the lift issue is that they NEVER explain lift using ONLY one theory without mention of the other, as student pilots, once exposed to the lift question will invariably find through a credible source that BOTH Newton and Bernoulli are correct and that each can explain exactly the same thing to the 100% point. Lift can be explained to death. The deeper one goes into the explanation the more complicated it can get. Denigrating Bernoulli due to changing density and airflow speeds causing compression factors is NOT the way to present lift. Bernoulli stands. It's the math that gets harder when you compress the flow that's all. All this can be avoided by simply explaining to students that lift results when an airflow is TURNED, and BOTH Newton and Bernoulli can be shown to cause the airflow to turn as lift is being produced. Circulation, density, vortices..........all part of it, but it's the turning of that airflow that produces lift force and BOTH Bernoulli and Newton are working equally to produce that force, only doing it differently. Dudley Henriques Actually, a quick meander through the literature will not find Bernoulli mentioned: in 2 D airflow studies it's gas laws and Newtonian physics, with a heavy emphasis on experimental results. These days, numerical methods -- what we used to call difference equations -- seem to yield results that seem to come pretty close to predicting experimental results. Notice especially in experiments that chord sections have end plates so that flow really is confined to 2 D. What is really interesting is that high performance glider wings are long and slender: that's how they get the most efficient use of potential energy in the form of altitude and turn it into range. *I don't know of any 4 seat complex SEL that uses the same principle and am not sure why. *My Mooney gets 20 mpg or so, sure would enjoy seeing that change to 30! It's nice to see a real aviation topic here, isn't it? I don't know what "literature" you're referring to that doesn't mention Bernoulli when discussing lift, but I'd avoid that literature if I were you. It's incomplete! :-)) DH |
Three take offs = three landings at Newton MS and Madison MS - Video | [email protected] | Piloting | 39 | November 28th 09 01:22 AM |
How can the Magnus effect be explained with Bernoulli? | Mikki | Piloting | 4 | June 24th 09 05:51 AM |
Lift-to-Drag Ratio? | Toks Desalu | Home Built | 6 | November 23rd 03 10:53 PM |
The bernoulli theory of starting a long thread | David CL Francis | Piloting | 7 | October 26th 03 07:40 PM |
worked fairly well - the German 37mm and British 40mm, frank mitch newton on Stukas | fmn2 | Naval Aviation | 1 | August 10th 03 02:14 AM |
