On 2011-05-29, James Robinson wrote:
No, the system switched to alternate law all by itself when the speed signals went screwy, and there was no need to shut off the automation. Indeed. On the surface, the pilot lost control of a perfectly flyable airplane, which was in stable flight before he took control. However, part of the investigation certainly has to be why the pilot flying didn't put the nose down as a reaction to repeated stall warnings. This is something any pilot learns when first starting to fly, and should be a natural reaction when hearing the alarm. Was he overwhelmed by all the alarms and missed the stall warning? Did he think he was correcting for wind shear or some other problem? Like any crash, there is a chain of events. There could be user interface issues (a famous example of this was the Three Mile Island incident, a famous aviation related incident of bad user interface being a contributory cause of a crash was the Boeing 737 that crashed near Kegworth in England after the crew shut down the wrong engine). There could be training issues. I'm certainly not going to condemn a crew even though on the obvious face of it, it may look like pilot error. There is likely to be plenty of contributory factors. The pilot of the Colgan Air flight approaching Buffalo did the same thing, and some studies suggest that when surprised, the majority of pilots will try to pull the nose up when they hear a stall warning, which is exactly the wrong thing to do. I think in the case of Colgan Air, the recent emphasis on icing related tailplane stalls (recovery procedure the opposite of main wing stall) may have been a contributory cause. Similarly, perhaps the high emphasis on windshear recovery (which when all the automation in a modern airliner be it Boeing or Airbus is to do a maximum performance climb, which may not work as expected if the automation is turned off and the crew are too busy to remember that stall protection has gone away). These aren't the first times either, long before automation was a factor a crew crashed a Hawker Siddeley Trident 3 (an airliner superficially similar to a Boeing 727, 3 engines and T-tail) near London by getting it into a deep stall. After inadvertently retracting the leading edge devices, the crew deliberately deactivated the stick shaker and pusher while pulling up, getting the aircraft into a deep stall from which it was impossible to recover. Why? There had been recent incidents of false stick shaker activations, the weather was not great, the captain had an undiagnosed heart condition which may have started to cause him some pain thus fogging his judgement, there were industrial relations problems (with the captain on one side of the argument and the rest of the crew on the other), and the first officer was timid about challenging the captain's decision to keep pulling back on the stick because he had recently been reprimanded for challenging a captain. So the captain assumed it was a false activation of the stick shaker and turned off the stick shaker and stick pusher, and stalled it. Is it just human nature to pull back on the controls, thinking you want to stay away from the ground, rather than point the aircraft at the ground to recover? And how often is stall avoidance/recovery trained for in an airline setting? |
On Jun 2, 10:46*am, Dylan Smith wrote:
And how often is stall avoidance/recovery trained for in an airline setting? Not nearly enough. Dudley Henriques |
On Jun 2, 12:38*pm, Dudley Henriques
wrote: On Jun 2, 10:46*am, Dylan Smith wrote: And how often is stall avoidance/recovery trained for in an airline setting? Not nearly enough. Dudley Henriques Unless the controls were jammed and the attitude indicator was busted, it is tough to blame any other instrument failure for this. Most likely pilot error due to complacency developed from thousands of hours of cruising at flight levels in a highly automated airplane. |
Pilot error, fog | Todd[_2_] | Piloting | 15 | April 20th 10 01:35 PM |
Comair Pilot Error | Andrew Sarangan | Piloting | 198 | September 6th 06 02:16 AM |
Gust? Pilot error? | Flyingmonk | Piloting | 13 | February 3rd 06 02:30 PM |
Co-pilot error caused AA 587 crash | Peter | Piloting | 209 | November 3rd 04 05:51 AM |
Pilot Error? Is it Mr. Damron? | Badwater Bill | Home Built | 3 | June 23rd 04 04:05 PM |
