RF interference issue again (esp. for E Drucker and Jim Weir and other RF wizards)
Old November 4th 03, 07:25 AM
Sydney,
What you have here is a pretty classic case of intermodulation interference.
Judging from he results of your investigation (good work on that, by the
way) I would say that the most likely cause is the frequency mixing
("heterodyning") of two very strong out-of-band signals in the "front end"
of whatever radio you are listening to. Yes, it is possible that the mixing
could be taking place in some corrosion of an antenna mounting or some such,
but that is, in my opinion, far less likely.
It's a good bet that at least one, and very likely both, of the very strong
out-of-band signals is in the commercial FM broadcast band. There may be
several such signals being broadcast at high power from the antenna farm.
At this point the question is whether the interference poses a threat to
safety or merely an annoyance. When the interference "breaks squelch while
you are tuned to the TRACON freq are you still able to hear the controller
when he/she transmits?
It may be a good idea for you to notify the FAA about the problem. Further
investigation may involve the use of a spectrum analyzer, not a tool you are
likely to have laying around in the garage. If the Feds determine that the
potential for intermodulation interference is a hazard they can take
corrective measures, such as reassigning the TRACON frequency in the area to
one that has a lower risk of interference from whatever signals are being
transmitted from the antenna farm.
-Elliott Drucker
Old November 4th 03, 02:01 PM
Snowbird
wrote in message .. .
interference.
Elliot, given what we did, is there a way to pinpoint what
signals might be the source of the problem?
Given the lat-long, is there a way to find out what antennas
are located there?
Is there something which might be a problem in our radios,
which could be fixed?
Well, one of the things which we did when the problem started
was take off all the easily-accessible antennae and clean the
connectors and check their ground. They all looked very good,
very well sealed and tight although the comm antennae didn't
have as strong ground as I'd like at first. The only antennae
we didn't check were the VOR/Glideslope because they're way
up at the top of the horizontal stab. and a b**ch to get at.
So unless it's the VOR antenna, I don't think corrosion in the
antenna mounting is likely, either.
On one installed radio and the handheld, yes. On the other installed
radio, the controller becomes very faint against a background of
continued noise.
OK, I was thinking about this. Can you suggest which person in the
FSDO I'd ask for?
Thanks,
Sydney
Old November 4th 03, 06:00 PM
Jay
How close are you flying to the antenna farm? The field strength
decays exponentially with radial distance. Put another way, as you
get close, you may be flying into a VERY strong field, outside the
design parameters of the radios your using.
The spectrum analyzer (if you can get one) will answer your inter mod
products question. You might make friends with your local HAM group.
Some of these guys may enjoy the hunt, an airplane ride, and have the
high dollar equipment to do it. But I'm betting that the cause
something simpler than that. The fact that you mentioned that they
were AM broadcasts reminds me of the times I used to get AM radio on
my telephone. In very high fields with amplitude modulation you can
get what's often called "detection by overload". Any non-linear
circuit element in your radio- front end through audio amp have all
kinds of semiconductors which can "detect" and demodulate the AM
broadcast if the signal is powerful enough. In the case of my
telephone, the bridge rectifier that protected the polarity of the
phone was the detector.
If this turns out indeed to be the case, and you need to fly your
plane into fields that are that strong, you might be able to get some
relief with improved grounding, sealing radio case gaps with copper
foil, a filter network right before the antenna enters the radio.
Old November 8th 03, 05:59 AM
Montblack
("Paul Sengupta" wrote)
Some people have reported picking up radio on their
fillings in their teeth.
http://www.tvtome.com/tvtome/servlet...d-599/season-2
Second season (In Color)
46. Hi-Fi Gilligan
Gilligan's mouth becomes a radio after he is accidentally hit on the head.
When their regular radio is broken, Gilligan becomes their sole source of
information on the approaching typhoon.
b: 25-Nov-1965 w: Mary C. McCall, Jr. d: Jack Arnold
Montblack
Old November 4th 03, 09:22 PM
Roger Halstead
On 4 Nov 2003 06:01:30 -0800, (Snowbird)
interference.
An example of how difficult IM can be to find:
Two years ago we received a report of interference from our repeater
(on 147 MHz) to one of the services in Lansing. (that's about 70
miles). The interference was intermittent.
It turned out that there were three stations involved and none were
within 30 miles of each other.
Out repeater signal and a pager in (I believe it was Chesasining MI)
was mixing in a commercial repeater (fire I believe) and being
retransmitted on the input frequency for a Police repeater in Lansing.
The resultant signal being well off the frequencies used in the other
repeaters was understandably weak, but strong enough to key the Police
repeater and be clearly understandable.
It took several weeks of dedicated hunting by a number of crews in an
area nearly a 100 miles by about 30 miles to finally locate the
offender.
snip
continued noise.
IF the signal bothers one receiver far more than the other then I
would think the problem is more likely on the plane. IF it is
external and close, both receivers on the same frequency should have
the same problem.
To me that says "bad connection" some where.
There are many other possibilities, but with that information I'd tend
to lean heavily toward "on board"
Roger Halstead (K8RI EN73 & ARRL Life Member)
www.rogerhalstead.com
N833R World's oldest Debonair? (S# CD-2)
FSDO I'd ask for?
Thanks,
Sydney
Old November 4th 03, 11:11 PM
That would be pretty difficult because of the huge number of different
combinations of out-of-band signals that could cause the intermodulation
interference.
are located there?
Generally, the locations of all commercial broadcast sites in the US are
public domain information available from the FCC. Some or all of this info
is probably available on-line. Unfortunately, I am not particularly
knowledgeable when it comes to tools that might be available for searching
the appropriate FCC data bases.
The fact that three different radios that you tested were similarly affected
suggests that the problem is not a specific malfunction. A "solution" would
most logically involve placing a bandpass filter between each of your com
antennas and the corresponding transceiver. I do not have knowledge of such
filters being commercially available, but others might know of such
products.
while
controller
continued noise.
In that case I certainly think that you should bring the problem to the
attention of the FAA.
FSDO I'd ask for?
I'm no expert about FSDO organization, but I would start with the office of
the Facilities Director.
-Elliott Drucker
Old November 5th 03, 06:44 AM
I would start by disconnecting the antennas from ALL of the receivers
or if the antenna does not have a separate connector then removing the
receivers and using the hand held to detect the offending signal. If
you inject a strong enough signal into the antenna input you force the
receiver's RF amp into overload and it generates the intermod products
and sends them back OUT the same antenna to be picked up by the other
antenna's
There is one brand of ELT that is infamous for this type of problem
but I can not remember the model and brand.
interference.
are located there?
continued noise.
FSDO I'd ask for?
Thanks,
Sydney
