"Keith Willshaw" writes: "Stephen Harding" wrote in message ... Keith Willshaw wrote: Tail warning radars were extensively fitted in late ww2 The AN/APS-13 was made for fighters. This was a low-power pulse radar set, operating that flashed a red light and rang a bell when an enemy aircraft was approaching from the rear. They were fitted to later model P-51D's , P-38L's, P-47D's and P-61's Never heard of this for all these aircraft. Never even heard of it for aircraft during the Korean War. Did it actually work? Apparently it did. A bit too well, in fact. The radar didn't scan or sweep - it just tansmitted and received a fan-shaped beam behind the airplane. It rang its alarm whenever _anything_ entered that fan. The ground, birds, you own wingman... people were going nuts reacting to the high rate of false alarms, so most systems were deactivated or removed. -- Pete Stickney A strong conviction that something must be done is the parent of many bad measures. -- Daniel Webster |
![]() "Peter Stickney" wrote in message news ![]() In article , A bit too well, in fact. The radar didn't scan or sweep - it just tansmitted and received a fan-shaped beam behind the airplane. It rang its alarm whenever _anything_ entered that fan. The ground, birds, you own wingman... people were going nuts reacting to the high rate of false alarms, so most systems were deactivated or removed. It was rather more useful on night fighters and bombers I imagine since they typically operated alone, although the Germans did manufacture a passive receiver to home in on RAF tail warning radars IRC Keith |
"Peter Stickney" wrote in message news ![]() In article , A bit too well, in fact. The radar didn't scan or sweep - it just tansmitted and received a fan-shaped beam behind the airplane. It rang its alarm whenever _anything_ entered that fan. The ground, birds, you own wingman... people were going nuts reacting to the high rate of false alarms, so most systems were deactivated or removed. It was rather more useful on night fighters and bombers I imagine since they typically operated alone, although the Germans did manufacture a passive receiver to home in on RAF tail warning radars IRC "Flensburg." In addition to the beaconing problem, ISTR that RAF bomber pilots disliked Monica just as much as the U.S. fighter pilots disliked APS-13, and for the same reason, constant false alarms. Aftert all, there you are cruising along in the bomber stream with the damned thing going off every few minutes, if not constantly. Guy |
![]() "Keith Willshaw" wrote in message ... "Peter Stickney" wrote in message news ![]() In article , A bit too well, in fact. The radar didn't scan or sweep - it just tansmitted and received a fan-shaped beam behind the airplane. It rang its alarm whenever _anything_ entered that fan. The ground, birds, you own wingman... people were going nuts reacting to the high rate of false alarms, so most systems were deactivated or removed. It was rather more useful on night fighters and bombers I imagine since they typically operated alone, although the Germans did manufacture a passive receiver to home in on RAF tail warning radars IRC Tail warning radars substantialy reduced the looses of German night fighter crews though only the elite crews were given it. The German Radars with an "R" designation had tail warning radar extensions of the main radar. Thus the FuG 218 SN-2R had one as well as slightly broader frequencies to improve jame resistance marginally and also the Naxos ZR or FuG 217 which was liked by the crewas becuase it was quite resistent to jaming and windows. Often the best warning of an Mosquito was a clicking in the FuG 16 radio, presumably due to the radar pulses of the powefull magnetron. Keith |
Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 0 | September 2nd 04 05:15 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | April 5th 04 03:04 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 2nd 03 03:07 AM |
Long-range Spitfires and daylight Bomber Command raids (was: #1 Jet of World War II) | The Revolution Will Not Be Televised | Military Aviation | 20 | August 27th 03 09:14 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 4 | August 7th 03 05:12 AM |
