XC Soar map help needed
Old June 8th 11, 08:52 PM posted to rec.aviation.soaring
Roger Burghall
Default XC Soar map help needed
In my experience Windows CE regularly "loses" the SD card and only
resetting (gently poke the stylus into the reset switch hole on the side
of the iPaq) allows it to find the card again. You can then copy files
from SD card to the main memory or "iPaq file store".
Then when the card is "lost" you are still in business.
Roger
At 16:50 08 June 2011, Max Kellermann wrote:
Ken Latam wrote:
I have a copy of the XC Soar files(XC Soar and the cabinet files,and
map)on
the SD card in the XC Soar Data directory as you sugested(waist of
time
as
the Ipaq can't see the SD card) and a copy of both file's on the
Ipaq
windows "start up directory" where I can at least see the program
and
work with it a little bit.
XCSoar doesn't look for data files in the "start up directory". And
of course it can't load data files from a SD card that doesn't work in
your iPaq.
If the XC Soar program must run from the SD card then I am at a dead
end
till a solution for the SD card issue is found.
No, you can choose whether to store the data files on the SD card (in
XCSoarData), or on the internal memory (usually "/My
Documents/XCSoarData"). When XCSoarData exists on any SD card, XCSoar
always uses this location. If not, then the one on "My Documents" is
used. The XCSoarData directory is created automatically by XCSoar on
the first start.
Both choices have downsides: old iPaqs are extremely slow at accessing
the SD card. Internal memory is lost after each reboot, and internal
memory decreases the amount of RAM available for XCSoar, and XCSoar
may run out of memory in the middle of a flight.
I like very much what I have seen of XC Soar, but WHY WHY would they
build
a device with an SD and CF slot that the device can't detect.
Just to be su did you insert a SDHC card? Old iPaqs can't read
SDHC. Which filesystem did you use on the card? iPaqs can only read
FAT/VFAT, but not NTFS, for example.
My personal recommendation is to throw away all the ancient kludgy and
buggy Windows CE crap and buy a modern Android device such as the Dell
Streak. It's down to 239 EUR over here in Germany.
Max
Old June 9th 11, 12:40 AM posted to rec.aviation.soaring
Ken Latam
Thanks Max. But still a no-go. XC Soar is located in "my documents/XC Soar
Data" folder. It still cannot find the map file's and I must redo all the
pilot details,Pilot name,aircraft,GPS com port, polar,units(I run the
Australian system),etc each time the program is started. Of course I could
always just leave it on and never shut it off. Maybe hard on the battery
tho.
You are right in it may be better to ditch the old system for new
equipment. Something to look at for winter.
Ken
Old June 9th 11, 01:37 AM posted to rec.aviation.soaring
Ken Latam
WOO HOO!! It works!!! Thank you all very much for your help. Rodger,we
need to go for a few pint's ON ME some day. By placing the map file's in
the "ipaq file store" and setting the start menue to open COM port 7
(GPS) I am now off and running.
Roger
Ken
Old June 9th 11, 09:05 PM posted to rec.aviation.soaring
Werner Schmidt
Hi folks,
some other questions regarding XCSoar. I'm just playing around with it
(maybe I then find it useful some time :-) ).
I run it on a windows mobile based device (HTC Blue Angel with WM 6.5 as
OS).
By now I have these questions:
#1: How do I manage XCSoar to show not only airspaces, but also
air*fields* in the map? Would find that helpful ...
#2: the map isn't very detailed. Where may I get more detailed maps?
#3: airfield- and airspace data I found is somewhat out-of-date. Is
there any source in the WWW for more up-to-date data?
Regards and thanks in advance
Werner
Old June 9th 11, 11:13 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
Airfields are simply the waypoints in either waypoints file that carry a
'landable' and/or 'airfield' attribute. Additional information about any
turnpoint (including airfields) can be added by including it in the
Waypoint Details file.
You can't. The maps are either pre-canned or generated by using the map
generator on the XCSoar website. Only details held in the digital mapping
database can appear in a generated map.
Airspace data is generally maintained by somebody in the country
containing it. Your national gliding association may hold it or a
reference to where it may be found. You should also check in the Soaring
Server's airspace pages. http://soaringweb.org/Airspace lists the
national airspace pages on this server.
Same goes for waypoint information.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old June 9th 11, 11:48 PM posted to rec.aviation.soaring
Ken Latam
For listing all the local (200km)airport's I used my latest VFR flight
map. Set each one as an Airport instead of a Turn Point. I will be
visiting as many of the local ranchers/farmers as many have their own
strip at home. Will need to include in the comments section, what the
surounding area is(pastulook for cattle,or crop: corn is nasty) .
Google Earth is good for this as well as it will aid in finding them.
Ken
Old June 12th 11, 09:30 PM posted to rec.aviation.soaring
Ken Latam
Now I just need to figure out how to keep all my waypoints from being
deleted eveytime I close the program. It's very time consuming to add
them each time
Other than that, this weekend was a good workout for XC Soar and it worked
flawlessly.
Ken
Old June 12th 11, 11:01 PM posted to rec.aviation.soaring
You should be ableto get national waypoints from the Soaring Server
http://soaringweb.org/TP/HomePage.html or your national soaring
association. Put it in the same place as airspace and maps.
If you meant tasks, remember to save a new task as soon as you've created
it. This way you can re-use it in future.
BTW, you are backing up your XCSoar set-up to your PC, I assume? Do it
every time you change the set-up / add a new data file / define a new
task and you'll be streets ahead when your iPaq and/or SD card fails or
gets lost.
org |
Old June 14th 11, 07:46 PM posted to rec.aviation.soaring
Werner Schmidt
Hello Martin Gregorie, you wrote at 06.10.2011 00:13
thank you; I now chose "AirfieldDetails-Germany.txt" as "Waypoint
details" and it works.
Obviuously. I hoped there could be another database (with more detailed
maps) somewhere in the www ...
THX again; I'll have a look at this [... seconds later ...] found an
updated airspace file :-)
Another question: is it possible to set the default starting point for
SIM mode?
Regards
Werner
Old June 15th 11, 01:25 PM posted to rec.aviation.soaring
SIM mode?
Yes, with an entry in the Waypoint details file. This does two things:
- in sim mode it sets the starting point for the program
- it gets added to your target list, so it can be selected easily if
you want to abandon the task and go home, even if there is no
current task or your home base isn't included in your task.
To use it, you need a defined turnpoint on your home field. Add an entry
for this turnpoint to the 'turnpoint details' file with '=HOME' in the
header for the entry. Here's my minimum home entry:
======================airfields.txt=============== ========
[GRL GrnsdnLd=HOME]
Gransden Lodge
where the lines of hyphens mark the start and end of the file and
'GRL GrnsdnLd' the the turnpoint name exactly as it appears in the
turnpoint file. You can add anything you like to the entry, such as land-
out phone numbers, provided that fits in the display area used for a
turnpoint description.
org |
Fat boy wants to soar... toggles mcfarley Soaring 24 March 23rd 10 06:51 PM
XC-Soar [email protected] Soaring 4 January 26th 09 04:06 PM
Get out of the Cold and SOAR! Mike Schumann Soaring 4 January 22nd 09 06:03 AM
Instructor needed at Soar Minden [email protected] Soaring 2 May 21st 07 02:13 AM
why do you soar? Mark James Boyd Soaring 27 October 21st 03 07:48 PM
