Handling differences between the 15m vs 16.6 ASW-20CL?
Old June 16th 11, 04:07 PM posted to rec.aviation.soaring
Gary[_5_]
Default Handling differences between the 15m vs 16.6 ASW-20CL?
This past week I purchased an ASW-20CL. Wondered if anyone has any
thoughts on the handling qualities of the 2 configurations. The 15m
version is equiped with Nixon winglets. The previous owner never flew
with the extended tips so could not offer opinion or advice.
Thanks, Gary Adams
Old June 16th 11, 04:18 PM posted to rec.aviation.soaring
Dan[_6_]
Thanks, Gary Adams
Gary,
Try the ASW-20 Newsgroup.
http://groups.yahoo.com/group/ASW20owners/
enjoy the new glider....best glider ever built!
Dan
ASW-20
WO
Old June 16th 11, 04:39 PM posted to rec.aviation.soaring
Gary[_5_]
Thanks, Gary Adams
Gary,
Try the ASW-20 Newsgroup.http://groups.yahoo.com/group/ASW20owners/
Dan
ASW-20
WO
Hi Dan! I think I heard those same words from you earlier in the week,
didn't I? I am sure I'll have fun in it. My second 20, seperated by 25
years....glad to own one again. The first was an early model 20 003
from Rudy Moser in '78.
Gary
GA2
Old June 18th 11, 01:13 AM posted to rec.aviation.soaring
Andreas Maurer
On Thu, 16 Jun 2011 08:07:09 -0700 (PDT), Gary
Thanks, Gary Adams
Sell the 16.6m extensions - the 20 is too light with them.
If I remember correctly, the 15m version has a better L/D from 65 kts
upwards - you hardly fly slower. A climb rate advantage of the 16.6
meters version is only noticeably in very, very weak thermals.
Andreas
Old June 18th 11, 02:14 AM posted to rec.aviation.soaring
Gary[_5_]
Thanks, Gary Adams
upwards - you hardly fly slower. A climb rate advantage of *the 16.6
Andreas
Thanks, Andreas.....I'm starting to get that from everybody. Can't
find any advantage to using anything but the 15m winglets.
Gary GA2
Old June 18th 11, 05:15 AM posted to rec.aviation.soaring
Tim Taylor
Thanks, Gary Adams
Andreas
Gary GA2
Gary,
I had a Ventus b with 15 and 16.6 tips. I loved the 16.6's in the
spring and fall. Mine had winglets added on the 16.6 and they handled
as well as the 15m tips with winglets. I felt I had better glide up to
about 80 knots and very noticeable better ability to climb in light
conditions. With about a 9 pound wingloading it was one of my favorite
configurations to fly the Ventus.
Tim
Old June 18th 11, 03:23 PM posted to rec.aviation.soaring
JJ Sinclair[_2_]
Thanks, Gary Adams
I have flown the 20b and the LS-3a with the 16.6 wing tip extensions
and IMHO neither did much to improve the glide and just made the roll
rate noticably slower. They may have just extended an airfoil that was
optimized for the 15 meter span which had been chosen to give a gentle
stall and didn't increase the performance when extended. I believe
only SH got it right when extending the wings with their Ventus and
Numbus. Schleicher figured it out and changed the last 10' in order to
get the desired results in both the 15 meter and 18 meter
configurations on the 29.
Just my observations & opinions,
JJ
Old June 19th 11, 10:07 PM posted to rec.aviation.soaring
Gary[_5_]
On Jun 19, 2:33*pm, BruceGreeff wrote:
Indeed, the only extended 20 that I know of that really has a
performance increase is experimental. Owner / engineer took a big saw to
the wing and increased the span, while changing the airfoil and planform
and introducing polyhedral. Resulting weight distribution and control
responsiveness in 18m is conducive to performance that can / does match
things like JS1 in the hands of suitably skilled pilot. (Not over entire
flight envelope - which is where pilot skill counts)
Having less area outboard moved the wing centre of pressure inboard ,
substantially reducing the bending moment on the root - so it is
possible to increase the wingloading back to something sensible. Hence
it performs. Just increasing the span of the wrong airfoil by another
60cm or so is not going to improve anything.
This is particularly true with the ASW20 - because the wing is flexible,
and inclined to torsion. This results in the characteristic big vertical
tip displacement - not something you want to aggravate.
So - if yours is experimental, and you are brave, great things are
possible. Otherwise the standard 15m is a fine ship.
Bruce
Thanks, Gary Adams
Just my observations& *opinions,
JJ
Bruce Greeff
T59D #1771 & Std Cirrus #57- Hide quoted text -
- Show quoted text -
Thanks JJ and Bruce,
The answer is "yes" it is experimental.....and "no", I'm not brave,
the 15m tips will do just fine with it's Nixon winglets!
Thanks,
Gary Adams
ASW-20CL #20791 GA2
Old July 2nd 14, 06:28 PM posted to rec.aviation.soaring
That's funny. I bought my first ASW 20 in 1981, then moved to a 20B in 1989, then sold that and got an ASW 24 in 2003, then sold that and bought a share in my original ASW 20 in 2010, then sold that and bought another ASW 20 with much fewer hours in 2012.
Ulli Werneburg
Thanks, Gary Adams
Gary,
Dan
ASW-20
WO
Gary
GA2
Ventus bt handling Jorge Antonio Blanco Montagut Soaring 9 May 27th 11 10:48 PM
Camphill 2 - Schleicher ASW.20CL G-EHTT Andrew B Aviation Photos 0 July 16th 08 08:54 PM
Camphill 1 - Schleicher ASW.20CL G-EHTT Andrew B Aviation Photos 0 July 16th 08 08:54 PM
Rep vs. Dem Differences Jim Weir Piloting 212 September 8th 04 04:02 PM
ASW 20, ASW 20B, ASW 20C DIFFERENCES Ventus B Soaring 8 July 18th 04 10:28 AM
