waxing newly painted sailplane
Old June 22nd 11, 03:29 PM posted to rec.aviation.soaring
Brad[_2_]
Default waxing newly painted sailplane
I decided to paint my HP-24 myself. Overall it turned out nice and
saved me a whole bunch of money, while not "perfect" it will do just
fine. For a guy with a CostCo hoop house and a Harbor Freight
conversion gun I'm pleased!
My question is: how long should I wait to apply protective wax to the
airframe? And.................any suggestions which "wax" or product
to use?
I never did wax my Apis after we painted it, and later in life it
started developing moisture blisters, while not as heinous as the
blisters I've seen on other painted sailplanes at my field, they were
rather horrifying to see just the same. My hopes are that putting on a
good protective barrier should help with this.
Regards,
Brad
Old June 22nd 11, 11:01 PM posted to rec.aviation.soaring
JJ Sinclair[_2_]
to use?
Regards,
Brad
Most paint suppliers say to wait 30 days before waxing new paint
I use Mothers carnuba paste wax.
JJ
Old June 23rd 11, 07:43 AM posted to rec.aviation.soaring
Look at the tech sheet for the brand and specific product you used for
data on how long to wait before waxing. If no data, call the
technical help number. If it is catalyzed urethane or the like, there
are far better products on the market than Carnuba. Definitely wax
it.
Old June 23rd 11, 03:09 PM posted to rec.aviation.soaring
ContestID67[_2_]
*I use Mothers carnuba paste wax.
Be sure to use Mothers Step 3 which does not have any abrasives in
it.
http://www.mothers.com/02_products/05550-05750.html
Old June 24th 11, 08:36 PM posted to rec.aviation.soaring
Herbert kilian
it.
I'm using Mother's Little Helper, but only internally...
Old June 24th 11, 09:26 PM
Brad Alston Brad Alston is offline
Member
First recorded activity by AviationBanter: Jun 2011
it.
OK, here are a couple of naive questions. Why use an automotive waxing product (e.g. Mother's) rather than something marketed in the aviation waxing application market (e.g., Aero Cosmetics)? Are they the same thing is different packages?
Just joined the forum and probably have more questions than answers right now!
Old June 25th 11, 03:11 PM posted to rec.aviation.soaring
Dan[_6_]
to use?
Regards,
Brad
Hey Brad,
Bring the HP-24 to the ESA Workshop this Labor Day weekend at Mountain
Valley Airport, Tehachapi, CA and I'll help you wax it! Timing should
be about right.
Dan
WO
Old June 25th 11, 05:10 PM posted to rec.aviation.soaring
Brad[_2_]
to use?
Regards,
Brad
Hey Brad,
Valley Airport, Tehachapi, CA and I'll help you wax it! *Timing should
be about right.
Dan
WO
let's see if Bob can get me the rest of the parts in
time.....depending on our business schedule I might be able to come
down!
Brad
Old June 25th 11, 05:36 PM posted to rec.aviation.soaring
Darryl Ramm
On Jun 24, 1:26*pm, Brad Alston Brad.Alston.
'ContestID67[_2_ Wrote:
;775724']-
it.
right now!
Brad Alston
Does a painted surface (in this case its gelcoat anyhow) know its
flying or driving down the road? Since its gelcoat the place to look
might be boating industry. Many glider pilots I know are using
Meguiar’s Deep Crystal Carnauba wax since it goes on and buff's off so
easy. Thanks to Williams soaring for putting me and many others onto
this wax - it really is easier and quicker to buff off than other
Carnauba waxes. Although I've also used Mothers and Griot's Garage
Carnuba waxes on gliders and cars and think they are great as well.
But the Meguiar's is easier to use so means the glider is more likely
to get waxed and it seems to last as well as other waxes.
Were talking a wax here, Aero Cosmetics don't even seem to offer a
simple wax, only that spray and wash junk. Brad will be after a real
wipe on buff off type wax.
Darryl
Old June 25th 11, 09:47 PM posted to rec.aviation.soaring
Peter Scholz[_3_]
;775724']-
it.
right now!
I talked to one of the manufacturers that sell stuff for cars, boats and
planes here in Germany (Poly-Lack, www.carlack.de) and asked about the
difference, as we have used both the car and the plane variety in our
club. They look the same, but the plane stuff ist slightly more
expensive than the car variety.
The manufacturer (actually also a pilot) confirmed that it basically is
the same formula, with a little more polishing (= abrasive) component in
the car variant, and more UV-protection in the plane variant. Makes
sense to me.
Peter Scholz
ASW24 JE
Finishing products for a polyurethane painted sailplane John Scott[_2_] Soaring 0 January 27th 09 08:29 PM
Waxing Poetic On Flying Jay Beckman Piloting 4 October 30th 06 05:17 PM
Polishing & Waxing Go Soaring 8 March 24th 05 02:15 PM
Waxing your trailer(New Thread) Pete Reinhart Soaring 2 March 19th 04 01:14 AM
Wing Waxing Marske Flying Wings Soaring 2 September 10th 03 02:59 AM
