Eric Greenwell wrote:
On 7/2/2011 8:28 AM, Bill D wrote: On Jul 2, 7:56 am, Grider wrote: Automatic Position Reporting System (APRS) does this and more. .....When in range of a repeater. It's hard to find a place in the US where your NOT in range of a repeater. And, even if you do, repeaters are only ~$200 to set up. APRS is a good, solid and cheap solution with 1min fixes and all the additional data we'd like to see. APRS would really let the folks on the ground see the real-time "play-by-play" progress of the fleet out on a task. Is there a coverage map I can look at? Is there an "APRS in a Box" that one can buy and plunk into his sailplane in the morning then go flying with it in the afternoon, or how much more involved than that is it? In the U.S., APRS requires the user to hold at least a Technician class amateur radio license. So unless you already have an amateur radio license, you can't get up running with APRS that quickly. Since the Morse code requirement is history, all it takes to get a technician license is taking a 35 question multiple choice test. You need to answer 26 of those 35 correctly. The entire question bank is publicly available, as are the answers. (I bought a couple study books from ARRL that cover the technician and general class licenses and plan to take both tests in the next month. Seems pretty straight-forward.) This link appears to have further information, including links to various maps: http://www.aprs.org/ |
Spot deal, today only, buy service get a free Spot | Tim Taylor | Soaring | 3 | December 1st 08 10:30 PM |
SPOT | D.Rizzato | General Aviation | 0 | February 5th 08 01:04 AM |
SPOT | D.Rizzato | Restoration | 0 | February 5th 08 12:46 AM |
SPOT | D.Rizzato | Owning | 0 | February 5th 08 12:42 AM |
Jeremy-What is your definition of competitor? | Stewart Kissel | Soaring | 1 | March 28th 07 08:39 PM |
