Oudie vs Streak sunlight readability
Old July 5th 11, 05:50 PM posted to rec.aviation.soaring
Fred Blair[_3_]
Default Oudie vs Streak sunlight readability
On Jul 4, 8:51*pm, Mike wrote:
On Jul 4, 1:56*pm, T wrote:
On Jul 4, 12:01*pm, Max Kellermann wrote:
Had the chance to make a photo of Oudie and Dell Streak 5" in direct
sunlight:
*http://max.kellermann.name/download/...oudie_vs_strea...
Thanks I've been looking at the Oudie too, have not purchased yet.
Interesting from a side view, what about head on direct? It looked
like a plastic overlay on the Oudie, or standard view from the side of
old tv LCD screens.
The Dell is shiny glass, I have problems with that (reflections) and
direct sunlight on the iPad.
How do they both fare with sunglasses or polarized lenses?
T
T,
Can not compare the Streak to the Oudie, but...
I have a Streak and it is quite good with polarized lenses when used
in portrait mode. In landscape mode the screen is not very visable.
The reflection issue with the Gorilla Glass on the Streak is really
not much of a problem or issue, as the Streak is fairly bright. *A
slight angle change removes any reflection problem.
Another nice feature of the Streak is that it can be used for 5-6
hours without an external battery. Using XCSoar on the Streak is a
very good 'Tactical Soaring' program/device solution. And, if you
connect a Nano via Bluetooth, you have an excellent combination for
badges, contests and records, for a very reasonable price.
Good luck,
Mike
Mike
How do you get a secure igc out of the XcSoar?
Old July 5th 11, 05:56 PM posted to rec.aviation.soaring
Tony[_5_]
probably the same way you do out of the Oudie, i.e. you don't.
I haven't had an issue with sunlight readability on my Oudie this
season on several flights. I have non-polarized Ray Ban sunglasses
and fairly young eyes as far as glider pilots go.
Old July 5th 11, 06:00 PM posted to rec.aviation.soaring
Mike[_37_]
sunlight:
old tv LCD screens.
T
T,
Good luck,
Mike
Mike
How do you get a secure igc out of the XcSoar?- Hide quoted text -
- Show quoted text -
For badge flights I get a secure log from the Nano. If nothing has
changed recently, XCSoar is on the OLC approved software list.
Old July 6th 11, 03:02 AM
RAS56 RAS56 is offline
Member
First recorded activity by AviationBanter: Dec 2010
I ordered one of these:
http://www.amazon.com/GlareStomper-3...13450&sr =8-2
to put on my Oudie and test the next time I fly. Don't know if it will work or not, but it was relatively cheap (at least compared to most stuff construed as "aviation-related"!), easy to install, and will be easy to take off if it doesn't.
AND...it will work on the Garmin I have in the car if all else fails.
If the link doesn't work, just search for "Glare Stomper" on Amazon.
Rob S.
ZAP
Old July 6th 11, 04:59 AM posted to rec.aviation.soaring
Darryl Ramm
YMMV but those sorts of covers tend not to work great on the
transflective displays used typical consume PDAs/PNAs (e.g ones
without very bright backlights) which still need the gathered light to
work. I've tried similar hoods on several iPAQ PDAs and PNAs and gave
up.
Darryl
http://tinyurl.com/65x6hrk
Rob S.
ZAP
RAS56
Old July 6th 11, 07:22 AM posted to rec.aviation.soaring
Paul Remde
Hi Rob,
I look forward to hearing how it works for you.
Note that the Oudie has a 5" screen and the unit in the link is for a 4.3"
screen. But it looks like it simply Velcros around the unit and may work
fine.
Best Regards,
Paul Remde
"RAS56" wrote in message
Rob S.
ZAP
RAS56
Old July 6th 11, 09:21 PM
Member
Hi Paul,
Actually, what I ordered was the "316" version of the item, not the "320" which is for the 4.3" screens. The smaller 316's measurements looked to fit better with the setup I have with my nav system.
Since most Oudie's are oriented with the longest side "North-South" and most car GPS's are oriented "East-West", it took a little test-fitting to get it to what looks like it will work best.
The shade comes with a separate piece of velcro tape, which I cut in varying lengths and applied to the Oudie's exterior making sure not to block the indents where the panel mount fits. Installation was a piece of cake and putting the shade on only involves unfolding it and sticking it to the velcro on the Oudie.
So far, standing in the Texas sun here at the house, it appears like it might work...but how/if it works in the cockpit or if it turns out to be just a distraction or block my view while flying will be the test that tells the tale.
Take care,
Rob S.
ZAP
Old July 7th 11, 05:04 PM posted to rec.aviation.soaring
glider12321
On Jul 6, 1:21*pm, RAS56 wrote:
Hi Paul,
tells the tale.
Take care,
Rob S.
ZAP
RAS56
A business size envelope, bent, and a couple of pieces of scotch tape
works well too.
LCD Display Readability john smith[_2_] Piloting 4 May 29th 07 05:39 PM
Garmin iQue 3600a -- sunlight screen readability? Chuck Instrument Flight Rules 7 March 24th 05 11:00 PM
Garmin iQue 3600a -- sunlight screen readability? Chuck Piloting 17 March 24th 05 11:00 PM
Poor readability Kees Mies Owning 2 August 14th 04 05:22 AM
Streak Shadow david H Home Built 0 December 26th 03 11:22 PM
