The FAI set the rules for National Records and they are based on
Citizenship and can be set anywhere in the World. Of the British National Records only the Absolute Altitude and Gain of Height were set in the UK, the rest in more favoured climes. The BGA also administers a set of UK Local Records, these can be set by Citizens of any country on flights starting in the UK. As it happens I think they are all held by UK Citizens and, so far as I can recall, always have been ( though, I think there have been one or two cases of pilots with dual nationality holding one). The UK Local Records are not regulated by the FAI, they are purely a BGA thing. Nothing to stop the SSA doing the same thing in the USA, they already run a set of State Records after all. Not sure what the FAI rules are on records if there are pilots of two diffferent nationalities in a two seater, anyone know? At 13:26 11 March 2011, Tony wrote: On Mar 11, 3:15=A0am, ppp1 wrote: On 10 maalis, 22:54, Martin Gregorie wrote: On Thu, 10 Mar 2011 08:27:04 -0800, Tony wrote: On Mar 10, 10:15=A0am, Martin Gregorie wrote: On Thu, 10 Mar 2011 07:38:34 -0800, Tony wrote: I couldn't find much on a search but am really curious as to why apparently National records are based on citizenship and not on th= e location of the actual flight? =A0This leads to very misleading listings of National Records. =A0For example the World Altitude Re= cord of Fossett and Enevoldsen of 50,721 ft was flown in Argentina but shows up as a US Multiplace National Record when in fact no multiplace glider has ever flown that high in the US. =A0Similar w= ith the 1500 km that Fossett and Delore flew in Argentina. =A0What was= the FAI thinking when they decided to use citizenship instead of the country where you start your flight? Surely they had a reason. Isn't that a question for the US national aeroclub? Of course the FAI administers world records, but I think you'll find that US national records are the responsibility of your national aer= o club and that they set the rules about who can hold a national recor= d and where, geographically, it can be set. -- martin@ =A0 | Martin Gregorie gregorie. | Essex, UK org =A0 =A0 =A0 | OK then, why are US records based on citizenship instead of geographi= c location? =A0Although the one thread I did find here on the subject s= eemed to indicate that the US is not the only country with this situation. I never said or implied that the US is the only country to do that: jus= t that the rules for national records will be set by a national body, not the FAI. The UK has a very similar rule. National records must be set by UK citizens but can be set anywhere in the world. I know of at least one U= K record that was set in Patagonia. -- martin@ =A0 | Martin Gregorie gregorie. | Essex, UK org =A0 =A0 =A0 | If Quatemalan 100m sprinter runs under their national record in Japan, SURE it is Quatemalian record. Right? Same goes with gliding. Some countries has national records in two categories. Flown abroad and flown home. sure but you could run a 100 meter dash in any country in the world and expect basically the same performance of the same runner. Run a 100 km triangle in any country in the world with same pilot and same glider and you would expect a large difference in performance. |
On Mon, 11 Jul 2011 06:19:46 +0000, Chris Rollings
wrote: Not sure what the FAI rules are on records if there are pilots of two diffferent nationalities in a two seater, anyone know? IIRC, a World Record claim should be approved, first by the NAC competent for the country where the flight was made; second, by the NAC of the record claimer. If one of the two NACs refuses approval, the claim can't be approved by the FAI. Thus, it's up to the two NACs involved, and their rules, to allow for a mixed nationality crew to perform world record flights It seems for example that the German NAC has nothing against a mixed crew (see current WR list), while a few other nations require both crew members to be of the same nationality (AFAIK, France). Just read through the national rules, search for this item, and check that the wording is compatible with FAI rules. aldo cernezzi www.voloavela.it |
State and National records question | Gary Emerson | Soaring | 3 | January 22nd 07 11:14 PM |
STC records at FAA | [email protected] | Owning | 6 | April 2nd 05 04:01 PM |
TSA Alien training/citizenship validation rule | Chris | Piloting | 24 | December 31st 04 07:00 PM |
More Bush National Guard records emerge | Otis Willie | Military Aviation | 0 | September 9th 04 03:38 AM |
Military Records | Dale | Military Aviation | 5 | August 23rd 04 10:47 AM |
