On Jul 13, 6:31*am, Andy wrote:
On Jul 12, 9:11*pm, Darryl Ramm wrote: So can we bury this one please? Darryl You may have to talk to someone at FAA. *The link provided by the OP includes this: "Aviator’s oxygen must meet certain standards to ensure that it is safe to be taken to altitude. Only aviator’s-grade breathing oxygen meets this specification. Neither medical grade nor industrial grade oxygen is safe to substitute because they do not meet the same stringent standards as ABO." Of course it's been said many times in many places that this just isn't true but FAA does seem to want to keep up the illusion. *Maybe their concern is that someone will top off with some other gas, such as nitrogen which is available at many FBOs, if they don't insist on ABO labeling. Andy No thanks I don't want to talk to anybody at the FAA about this. The claims are just not correct for all practical purposes. The comment may be referring to other manufacturing processes used sometimes for some low-purity industrial oxygen (which you could not buy if you tried). But the stuff that goes out into the supply chain for welding, medical, aviation etc. applications is all sourced from Linde processing and is highly pure. As Richard says it comes from the same big container - go talk with your gas supplier (but some naturally won't want to sell you welding O2 if you tell them its for aviation...). Mixup or contamination of any oxygen source is a potential risk. Since the same suppliers are handling the bottles I don't see one as as safer than the other. For whatever use the cylinders better be clearly labeled as O2. Maybe more useful discussions on saftey are not related to the O2 labeling but the handling of the cylinders, trans-filling procedures, maintenance and servicing etc. I've seen some pretty blase/scary handling of O2 by glider pilots, old steel bottles last inspected God knows when, etc... Darryl |
On Jul 13, 9:39*am, Darryl Ramm wrote:
On Jul 13, 6:31*am, Andy wrote: On Jul 12, 9:11*pm, Darryl Ramm wrote: So can we bury this one please? Darryl You may have to talk to someone at FAA. *The link provided by the OP includes this: "Aviator’s oxygen must meet certain standards to ensure that it is safe to be taken to altitude. Only aviator’s-grade breathing oxygen meets this specification. Neither medical grade nor industrial grade oxygen is safe to substitute because they do not meet the same stringent standards as ABO." Of course it's been said many times in many places that this just isn't true but FAA does seem to want to keep up the illusion. *Maybe their concern is that someone will top off with some other gas, such as nitrogen which is available at many FBOs, if they don't insist on ABO labeling. Andy No thanks I don't want to talk to anybody at the FAA about this. The claims are just not correct for all practical purposes. The comment may be referring to other manufacturing processes used sometimes for some low-purity industrial oxygen (which you could not buy if you tried). But the stuff that goes out into the supply chain for welding, medical, aviation etc. applications is all sourced from Linde processing and is highly pure. As Richard says it comes from the same big container - go talk with your gas supplier (but some naturally won't want to sell you welding O2 if you tell them its for aviation...). Mixup or contamination of any oxygen source is a potential risk. Since the same suppliers are handling the bottles I don't see one as as safer than the other. For whatever use the cylinders better be clearly labeled as O2. Maybe more useful discussions on saftey are not related to the O2 labeling but the handling of the cylinders, trans-filling procedures, maintenance and servicing etc. I've seen some pretty blase/scary handling of O2 by glider pilots, old steel bottles last inspected God knows when, etc... Darryl- Hide quoted text - - Show quoted text - www.c-f-c.com/supportdocs/abo1.htm Above link is very educational. |
On Jul 13, 12:39 pm, Darryl Ramm wrote:
Maybe more useful discussions on saftey are not related to the O2 labeling but the handling of the cylinders, trans-filling procedures, maintenance and servicing etc. I've seen some pretty blase/scary handling of O2 by glider pilots, old steel bottles last inspected God knows when, etc... I'd welcome some discussion on the topics you mention. That would fill a real need for pilots like myself who don't often use oxygen. One thing I'm curious about is the hydrotesting requirement. If one of the legendary arguments for using "aviation" oxygen is its low moisture content (debunked above), then: 1. how is water completely removed from a cylinder after hydrotesting, and 2. how can a user be assured that no corrosion will be created in his cylinder as a result of hydrotesting? -John |
On Jul 13, 11:51Â*am, jcarlyle wrote:
On Jul 13, 12:39 pm, Darryl Ramm wrote: Maybe more useful discussions on saftey are not related to the O2 labeling but the handling of the cylinders, trans-filling procedures, maintenance and servicing etc. I've seen some pretty blase/scary handling of O2 by glider pilots, old steel bottles last inspected God knows when, etc... I'd welcome some discussion on the topics you mention. That would fill a real need for pilots like myself who don't often use oxygen. One thing I'm curious about is the hydrotesting requirement. If one of the legendary arguments for using "aviation" oxygen is its low moisture content (debunked above), then: From talking with a hydrotesting shop owner as I waited for a bottle to be serviced. 1. Â*how is water completely removed from a cylinder after hydrotesting, andl They evacuate the bottle to a high vacuum while mildly heating it. 2. Â*how can a user be assured that no corrosion will be created in his cylinder as a result of hydrotesting? The bottle is borescoped after hydrotesting with the valve removed. BTW, I think Mythbusters had a program on what happens if you break the valve off a high pressure cylinder. IIRC, reality didn't quite live up to the urban myths. Here's a deeper explanation of stamp codes. Oxygen cylinders are marked to designate the type of cylinder, maximum fill pressure, hydrostatic test date, inspector, manufacturer, and serial number. The marking are normally stamped into the shoulder of the cylinder. The hydrostatic test date and inspector mark indicate when the cylinder was last tested and who tested the cylinder. Most oxygen cylinders are required to be tested every 5 years. This test ensures the cylinder can safety hold the maximum fill pressure. There are two other markings which are sometimes found on these cylinders. The plus (+) sign located after the test date designates that the cylinder can be filled to 10% above the pressure stamped on the cylinder. The five-pointed star in the same location designates that the hydrostatic test date has been extended an additional 5 years. A cylinder with a five-pointed star would need to be tested every 10 years. Vertical Alignment: DOT-3AA 2015 1234567 XY Corp 8 ® 08 + Ûž Horizontal Alignment: DOT-3AA 2015 1234567 XY Corp 8 ® 08 + Ûž DOT = Department of Transportation 3AA = Seamless alloy-steel cylinder 2015 = 2015 psig fill pressure 1234567 = Serial number of cylinder XY Corp = Manufacture of cylinder 8 ® 08 = Month and Year, in this example, August 2008, the symbol of the inspector is commonly placed between month and year (® used as example only) + = Cylinder maximum fill pressure can be 10% above 2015 psig or 2216.5 psig Ûž = Cylinder may be tested every 10 years versus the standard 5 years |
On Jul 13, 11:37*am, Bill D wrote:
On Jul 13, 11:51*am, jcarlyle wrote: On Jul 13, 12:39 pm, Darryl Ramm wrote: Maybe more useful discussions on saftey are not related to the O2 labeling but the handling of the cylinders, trans-filling procedures, maintenance and servicing etc. I've seen some pretty blase/scary handling of O2 by glider pilots, old steel bottles last inspected God knows when, etc... I'd welcome some discussion on the topics you mention. That would fill a real need for pilots like myself who don't often use oxygen. One thing I'm curious about is the hydrotesting requirement. If one of the legendary arguments for using "aviation" oxygen is its low moisture content (debunked above), then: From talking with a hydrotesting shop owner as I waited for a bottle to be serviced. 1. *how is water completely removed from a cylinder after hydrotesting, andl They evacuate the bottle to a high vacuum while mildly heating it. Yes pumping is another way, I am not sure I wonder if more places have drying blowers than vacuum pumps. BTW its just a vacuum--a high vacuum has as specific meaning (mean free path of the gas molecules approach the size of the object) and most places just would not have the fancy diffusion or other pumps or staff skills/training needed to pump down to a high-vacuum. Darryl |
Bill D wrote:
BTW, I think Mythbusters had a program on what happens if you break the valve off a high pressure cylinder. IIRC, reality didn't quite live up to the urban myths. Actually, it did: http://www.youtube.com/watch?v=ejEJGNLTo84 |
On Jul 15, 2:02*am, John Smith wrote:
Bill D wrote: BTW, I think Mythbusters had a program on what happens if you break the valve off a high pressure cylinder. *IIRC, reality didn't quite live up to the urban myths. Actually, it did:http://www.youtube.com/watch?v=ejEJGNLTo84 I've been eyewitness to a forklift knocking down a pallet of cardboard boxes containing 6 x 2l Coke bottles. Several of the bottles went more than 100m across the ground. (most just bounced harmlessly) |
On 15/07/2011 00:02, John Smith wrote:
Bill D wrote: BTW, I think Mythbusters had a program on what happens if you break the valve off a high pressure cylinder. IIRC, reality didn't quite live up to the urban myths. Actually, it did: http://www.youtube.com/watch?v=ejEJGNLTo84 ....and I know the fairing is composite but it also made a 5ft x 4ft hole in the 747's pressure hull after going through the main cabin floor twice. http://www.smh.com.au/travel/travel-...122-183aj.html GC |
On Jul 13, 10:51*am, jcarlyle wrote:
On Jul 13, 12:39 pm, Darryl Ramm wrote: Maybe more useful discussions on saftey are not related to the O2 labeling but the handling of the cylinders, trans-filling procedures, maintenance and servicing etc. I've seen some pretty blase/scary handling of O2 by glider pilots, old steel bottles last inspected God knows when, etc... I'd welcome some discussion on the topics you mention. That would fill a real need for pilots like myself who don't often use oxygen. One thing I'm curious about is the hydrotesting requirement. If one of the legendary arguments for using "aviation" oxygen is its low moisture content (debunked above), then: 1. *how is water completely removed from a cylinder after hydrotesting, and 2. *how can a user be assured that no corrosion will be created in his cylinder as a result of hydrotesting? -John The cylinders are typically dried by blowing air or heated air in them. Larger shops will have drying stations with a rows of hoses and/ or tubes that go down into the cylinders and dry them. Cylinder testing requirements by DOT regulations, e.g. see 49 CFR 180.205. At each pressure test they required to be also be visually inspected inside and out, for corrosion amongst other things. You cannot be assured of anything in life. Like packing a parachute, find somebody you really trust to inspect your cylinders. Darryl |
On Jul 13, 2:51 pm, Darryl Ramm wrote:
The cylinders are typically dried by blowing air or heated air in them. Larger shops will have drying stations with a rows of hoses and/ or tubes that go down into the cylinders and dry them. [ snip ] You cannot be assured of anything in life. Like packing a parachute, find somebody you really trust to inspect your cylinders. Darryl Thanks, Bill and Darryl. Heating would do the trick, given enough time. I ran across the following site: http://www.westernsalesandtesting.com/services.htm where they talk about cleaning the interior of the cylinder. Is cleaning done normally on aviation oxygen tanks? The chemical cleaning sounds thorough! Darryl, how would you recommend going about evaluating a cylinder inspection company before deciding to use them? -John |
Chicago Area Mini-Contest | Sean Fidler | Soaring | 0 | April 16th 11 10:45 PM |
Aircraft looking for help in the Chicago area | steveukman | Home Built | 1 | April 15th 07 11:53 PM |
Chicago area from the southwest - advice? | Chad Speer | Piloting | 39 | December 31st 06 08:17 PM |
Soaring in the Chicago area in November | Gordon Schubert | Soaring | 1 | October 15th 04 03:58 PM |
Chicago area soaring november ? | Marc Till | Soaring | 3 | October 12th 04 03:58 AM |
