#11
Have you ever considered a steeply banked side slipping turn ? You may have a high rate of descent, but the radius of turn is so small that the duration is very short, making the height loss small, and you do not need to increase airspeed to do it. Gilbert Slipping turn on low rope break???? (We are talking "just a bit above 200' rope break" right?) No, I have never considered this........I see no benefit and some serious problems....... Steep turn (about 45 degrees bank)...yes......if you consider the two major factors in the 180 turn, time and sink ......you come out with around 45 degree bank as the optimum combination.....It will yield the least loss of altitude......remember that you need to "roll up" to 45 degrees and "roll out" to level....so its steep only in the middle portion of the turn. Airspeed should be approx the same as a "normal" pattern.....but no time to be looking at the indicator, (has too much delay anyway) so simply establish the "normal" nose slightly down attitude....and coordinated turn... But a slipping turn???? I don't want to loose excess altitude in the turn......I want to complete the turn with the least possible loss of altitude......once I "know I can make it" I reach for spoilers... (like 3/4 the way thru the 180) then, on (downwind) final, use spoiler as nesessary, and add slip if necessary....but no slip in the turn! Cookie |
| Thread Tools | |
| Display Modes | |
| tow rope | tazman | Soaring | 9 | August 25th 10 03:30 AM |
| Mig-29 Crash during practice - topi.wmv (0/1) | Immaterial | Aviation Photos | 0 | January 20th 07 08:11 PM |
| 11 on a Rope | Peter Seddon | Rotorcraft | 0 | May 27th 04 12:33 PM |
| Donuts on a rope | Big John | Piloting | 4 | May 2nd 04 05:53 AM |
| Tow Rope Take-Up Reels | Nyal Williams | Soaring | 1 | September 17th 03 05:11 PM |
