![]() "Dan Marotta" wrote in message ... So... What would you have the tow pilot do, release the glider or, possibly, crash into the trees? Either way, the glider is down. Require radios and use them. Compared to gliders, they are dirt cheap. I've been away from soaring for 9 of the previous 10 years, but it's my recollection that the rudder wag was not an official signal - only a suggestion. Maybe it should be made an official signal and tested on BFRs and check rides. It's been a few years since I was an active CFIG, but we tested the rudder waggle on every flight review. I don't recall anyone failing to release when they got the waggle except for a few cases when they were briefed immediately before the flight.. As far as I can see, the signal is well intended, but a complete failure. Vaughn |
Rudder waggle | toad | Soaring | 33 | November 21st 07 05:44 AM |
DG Rudder AD - DONE! - Notes from my work | ContestID67 | Soaring | 0 | March 30th 06 07:36 PM |
CH Rudder pedals, why don't they work | wan2fly99 | Simulators | 2 | January 12th 06 12:30 PM |
signal splitter | Tri-Pacer | Home Built | 2 | November 5th 05 09:47 PM |
