The rudder waggle signal does not work
Old July 22nd 11, 10:53 PM posted to rec.aviation.soaring
Darryl Ramm
Default The rudder waggle signal does not work
On Jul 22, 2:46*pm, "vaughn" wrote:
"Dan Marotta" wrote in message
So... *What would you have the tow pilot do, release the glider or, possibly,
crash into the trees? *Either way, the glider is down.
Require radios and use them. *Compared to gliders, they are dirt cheap.
I've been away from soaring for 9 of the previous 10 years, but it's my
recollection that the rudder wag was not an official signal - only a
suggestion. *Maybe it should be made an official signal and tested on BFRs and
check rides.
It's been a few years since I was an active CFIG, but we tested the rudder
waggle on every flight review. *I don't recall anyone failing to release when
they got the waggle except for a few cases when they were briefed immediately
before the flight.. *As far as I can see, the signal is well intended, but a
complete failure.
Vaughn
Uh I assume that was an unintended typo and you meant failing to
release when they got the rock-off signal?
Darryl
Old July 22nd 11, 11:37 PM posted to rec.aviation.soaring
Ramy
check rides.
complete failure.
Vaughn
Darryl- Hide quoted text -
- Show quoted text -
No I believe he meant that everyone released by mistake...
And this was not even under real emergency pressure.
Exactly my point.
Ramy
Old July 22nd 11, 11:49 PM posted to rec.aviation.soaring
Isn't everyone missing the cause of this accident and ones like it?
Written, Pre-take-off checklist is all that is needed to prevent this
accident from ever happening. It is the most basic of pilot
duties........
The pilot made at least 5 obvious (easily preventable) errors leading
up to the accident.
1. preflight inspection (usually states spoilers/flaps to take off
position)
2. pre take off check list..."spoilers closed and locked"
3. During tow, Left hand should be on, near, behind, spoiler handle to
sense unwanted spoiler opening
4. Situational awareness of poor climb should result in immediate
spoiler check
5. Pilot should be familiar with signals
Pilot should also include "enmergency plan" in take off check
list ....planning for emergencies such as rope break, tow plane wave
off signal, canopy opening, tow plane loss of power, and spoilers
opening (and signal form tow plane)....none of these should cause any
major concern if they happen...If the pilot is properly prepared..
Cookie
Old July 23rd 11, 12:39 AM posted to rec.aviation.soaring
Darryl Ramm
On Jul 22, 3:49*pm, "
accident from ever happening. *It is the most basic of pilot
duties........
up to the accident.
position)
spoiler check
Cookie
I appreciate the comment, but broadening the discussion is more a
distraction to this than a help. One way of making sure something
really broken is not fixed is to keep making the problem bigger. Bad
things happen and when they do there needs to be a mechanism,
hopefully a practiced plan of action, to handle them. The causes of
these fatalities is really releasing low/in an a bad position. Fix
that problem and people won't get killed. In may cases (with powerful
enough tow planes) they might just be embarrassed and the glider pilot
ends up having to buy the tow pilot a beer that night because the tow
plane had to struggle to tow them for a while.
We all need the radio and signal procedure chain to work as
effectively as it can possibly do. That includes getting radios
properly installed in gliders and tow planes and properly using them,
tow pilots being trained to think when to most safely to use a radio
and signal followup if needed, and us community of glider pilots to
get our heads out of our collective asses on the broad lack of
proficiency with in-flight signals.
Darryl
Old July 23rd 11, 10:21 AM posted to rec.aviation.soaring
duties........
up to the accident.
position)
spoiler check
Cookie
You guys are simply amazing....
So far you have "blamed" the accident on
lack of radio
the rudder signal
The lack of good instruction
the topilots' use of the signal
everything to divert responsibility away from the glider pilot and on
to something/someone else
Cookie
Old July 23rd 11, 10:23 AM posted to rec.aviation.soaring
On Jul 23, 5:21*am, "
duties........
up to the accident.
position)
spoiler check
Cookie
*lack of radio
the rudder signal
Cookie- Hide quoted text -
Just re read.......not powerful enough tow plane is also a problem..
Old July 23rd 11, 10:33 AM posted to rec.aviation.soaring
There are only two possible in-flight signals initiated by the tow
pilot.....wing rock, rudder waggle...that's it.
I learned these in about lesson two of my training and have remembered
them ever since . I teach these to my students and they seem to have
no trouble remembering. It's not hard.
To me, a visual signal is a far better form of communication than a
radio braodcast.
The visual signal is quick, simple, to the point, obvious, etc....
Somebody already stated the possible "possible problems with relying
on radio"...there are many....
The low tech solution wins out by far!
Cookie
Old July 24th 11, 12:08 AM
Walt Connelly Walt Connelly is offline
Senior Member
First recorded activity by AviationBanter: Aug 2010
lack of radio
the rudder signal
Cookie[/quote]
Well, at least no one has blamed George Bush for this yet.
Walt
Old July 24th 11, 04:00 PM posted to rec.aviation.soaring
Pat Russell[_2_]
lack of radio
the rudder signal
By this logic, there's no such thing as a bad training program.
Assigning blame is off-topic.
It's not a question of blame. No one denies that the pilot is
responsible for all of his actions.
The issue is whether our national training program (as promoted by
SSF) contains an unforeseen flaw that is contributing to the accident
rate.
Old July 23rd 11, 06:50 AM
Ventus_a Ventus_a is offline
Senior Member
First recorded activity by AviationBanter: May 2010
duties........
up to the accident.
position)
spoiler check
Cookie
Well said
It takes discipline to do all that and some people just don't do discipline well. It won't catch every problem or save everyone but it's better than not following a rigorous and proven procedure.
Airline flying for example is one of the safest forms of transport going and it is highly procedural.
I come from a place where we do CBSIFTCB as checks and the best thing that happened while I spent some years away from soaring was the additiion of E for Eventualities to the end of the checks to review briefly before the launch the 'what ifs'
Colin
Rudder waggle toad Soaring 33 November 21st 07 05:44 AM
DG Rudder AD - DONE! - Notes from my work ContestID67 Soaring 0 March 30th 06 07:36 PM
CH Rudder pedals, why don't they work wan2fly99 Simulators 2 January 12th 06 12:30 PM
signal splitter Tri-Pacer Home Built 2 November 5th 05 09:47 PM
