On Jul 24, 5:07*am, 150flivver wrote:
I disagree. *There should be an urgent, serious emergency type signal-- the wing rock, and a not-so-serious, advisory type signal such as the rudder waggle. *If you can't keep the two separated, then perhaps you need to take up a different hobby where you're actions don't impact on the lives of the tow pilot or yourself. *I don't have the luxury of getting the glider up to 1000 feet if I throw a valve at 200. It's much more common for the glider to survive a release at 200 feet, than a tow plane having a serious problem down there and having a good outcome. I'd be interested in hearing from tow pilots that had a real in flight emergency and used the wave off signal. It's always seemed to me to be a bit like the "too slow" winch signal i.e. if you need to give it then you're not in a situation to do so. If there's time to negotiate I'll use the radio, if not I think I'll be pulling the release. Andy |
On Jul 24, 6:04*am, Andy wrote:
On Jul 24, 5:07*am, 150flivver wrote: I disagree. *There should be an urgent, serious emergency type signal-- the wing rock, and a not-so-serious, advisory type signal such as the rudder waggle. *If you can't keep the two separated, then perhaps you need to take up a different hobby where you're actions don't impact on the lives of the tow pilot or yourself. *I don't have the luxury of getting the glider up to 1000 feet if I throw a valve at 200. It's much more common for the glider to survive a release at 200 feet, than a tow plane having a serious problem down there and having a good outcome. I'd be interested in hearing from tow pilots that had a real in flight emergency and used the wave off signal. *It's always seemed to me to be a bit like the "too slow" winch signal i.e. if you need to give it then you're not in a situation to do so. If there's time to negotiate I'll use the radio, if not I think I'll be pulling the release. Andy I've never been much in favor of the wing rock with a tow emergency, but I teach it, we demonstrate it and we encourage proper training so glider pilots don't release on a rudder wag. I've had one real tow problem and witnessed others. I had engine vibration from a stuck valve at about 100ft, got the solo student in the 2-33 to above 200ft and called over the radio for a release. Which he did and we both returned safely. We teach 200ft rope break returns to the airport. If the radio was jammed with other chatter, the wing rock was next. Other tow problems I have witnessed include a blown cylinder, the glider pilot saw the puff of smoke from the tow plane, and almost as instantly the tow pilot dropped his end of the rope, no radio call, no wave off. Both returned safely. Not on tow, but a broken aileron cable on the tow ship after release. It would have been difficult to do the wave off. The pilot landed safely in the desert with only a few punctured tires. As a tow pilot and CFIG, I feel that if I have a true emergency, the glider pilot will get one radio call, maybe, and then see the rope dropped from the tow end. I have used the wing rock to signal a release when the radio was blocked by other chatter. When we tow a 1-26, we get at least 1000fpm, so the 1-26 pilot cannot determine if we are in good lift because his vario is always pegged. Other than what he feels in the seat of his pants from the climb rate increase. So, with precoordinatio, "Hey tow, tell me when to get off", I'll rock the wings above 2000ft AGL when the climb-o-meter shows 1500fpm and increasing. T Tow Pilot CFIG |
On Sun, 24 Jul 2011 06:04:28 -0700, Andy wrote:
I'd be interested in hearing from tow pilots that had a real in flight emergency and used the wave off signal. It's always seemed to me to be a bit like the "too slow" winch signal i.e. if you need to give it then you're not in a situation to do so. Slightly OTT, but.... In the UK the 'too slow' winch signal is simply the glider lowering its nose. Some years ago it was wing rocking, but that was changed once it was realised that this can cause tip stalls which are the the last thing we want on the cable. Lowering the nose is perfect because its dual- purpose, being both a pre-emptive corrective action *and* suggesting to the winch driver that more power would be nice. We still use the fish-tailing 'too fast' signal, though its really only useful for a fairly mild, slowly increasing overspeed. If its more than mild I want to be off quicker than most winches can slow down. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
On Jul 24, 9:04*am, Andy wrote:
On Jul 24, 5:07*am, 150flivver wrote: I disagree. *There should be an urgent, serious emergency type signal-- the wing rock, and a not-so-serious, advisory type signal such as the rudder waggle. *If you can't keep the two separated, then perhaps you need to take up a different hobby where you're actions don't impact on the lives of the tow pilot or yourself. *I don't have the luxury of getting the glider up to 1000 feet if I throw a valve at 200. It's much more common for the glider to survive a release at 200 feet, than a tow plane having a serious problem down there and having a good outcome. I'd be interested in hearing from tow pilots that had a real in flight emergency and used the wave off signal. *It's always seemed to me to be a bit like the "too slow" winch signal i.e. if you need to give it then you're not in a situation to do so. If there's time to negotiate I'll use the radio, if not I think I'll be pulling the release. Andy I have had 3 real ones, all engine related. In all cases the glider responded promptly and correctly. I have done 2 rudder wags for spoilers out. One responded correctly and fixed the problem. The second released. Our club includes these signals in our Spring check. Given all this, I will not do rudder wag until I have placed the glider pilot in a position where misinterpretation will not be a cause of an accident. If I really need him off, it's wing wag and every man for himself. UH |
"Given all this, I will not do rudder wag until I have placed the
glider pilot in a position where misinterpretation will not be a cause of an accident." Now that is a good idea. If you are climbing at all don't wag until well over 200' AGL. If the climb is that slow the glider pilot should realize it and be checking his spoilers. Mike |
On Jul 25, 6:35*am, Mike wrote:
"Given all this, I will not do rudder wag until I have placed the glider pilot in a position where misinterpretation will not be a cause of an accident." Now that is a good idea. If you are climbing at all don't wag until well over 200' AGL. If the climb is that slow the glider pilot should realize it and be checking his spoilers. Mike That is SOP at many places, why it is not followed/emphasized to all tow pilots I don't know. Darryl |
![]() "Andy" wrote in message ... On Jul 24, 5:07 am, 150flivver wrote: I disagree. There should be an urgent, serious emergency type signal-- the wing rock, and a not-so-serious, advisory type signal such as the rudder waggle. If you can't keep the two separated, then perhaps you need to take up a different hobby where you're actions don't impact on the lives of the tow pilot or yourself. I don't have the luxury of getting the glider up to 1000 feet if I throw a valve at 200. It's much more common for the glider to survive a release at 200 feet, than a tow plane having a serious problem down there and having a good outcome. I'd be interested in hearing from tow pilots that had a real in flight emergency and used the wave off signal. It's always seemed to me to be a bit like the "too slow" winch signal i.e. if you need to give it then you're not in a situation to do so. If there's time to negotiate I'll use the radio, if not I think I'll be pulling the release. Andy I've only *had* to wave off one glider - when the front seal on the engine failed, coating the windscreen with oil and filling the cockpit (Pawnee) with smoke. I gave the wing rock and started a spiral down to the field. Talking with the instructor after the fact and thanking him for the quick release, he laughed and said he saw wingtips rocking in a cloud of smoke. He released at the initial puff of smoke. Dan |
Last year, I wrote articles regarding this and other topics which are
widely distributed through the SSA's Soaring Magazine: "Preventing Launching Accidents" and "Preventing Landing Accidents." Further, I presented the same topics at the FAA Safety Facility at Lakeland Florida. These presentations (and others) are available on DVDs and printed booklets from our web site, WWW.EGLIDER.ORG Both the DVDs and the printed booklets are inexpensive and make excellent source material for club safety meetings. These two issues dominate glider accident statistics. The real problem is getting people to take the few minutes to become educated and to adopt the simple, life-saving practices that will save their lives. The well-known 5 hazardous thoughts, Anti Authority, Impulsivity, Invulnerability, Macho and Resignation dominate glider accident causes. I will be conducting several FAA approved, Flight Instructor Revalidation courses begining in November. (First in Minden, Nevada, Nov 12/13.) Any pilot interested in learning about safety issues and standardized procedures can attend. Tom Knauff |
On Jul 26, 8:14*am, Tom wrote:
Last *year, I wrote articles regarding this and other topics which are widely distributed through the SSA's Soaring Magazine: "Preventing Launching Accidents" and "Preventing Landing Accidents." Further, I presented the same topics at the FAA Safety Facility at Lakeland Florida. These presentations (and others) are available on DVDs and printed booklets from our web site, WWW.EGLIDER.ORG Both the DVDs and the printed booklets are inexpensive and make excellent source material for club safety meetings. These two issues dominate glider accident statistics. The real problem is getting people to take the few minutes to become educated and to adopt the simple, life-saving practices that will save their lives. The well-known 5 hazardous thoughts, Anti Authority, Impulsivity, Invulnerability, Macho and Resignation dominate glider accident causes. I will be conducting several FAA approved, Flight Instructor Revalidation courses begining in November. (First in Minden, Nevada, Nov 12/13.) Any pilot interested in learning about safety issues and standardized procedures can attend. Tom Knauff Some thoughts for Tom Knauff and others... Why do we have a wing-rock signal? The tow pilot could just release. There are two possible answers I can think of. First, it's a courtesy "heads-up" signal to the glider pilot to start thinking about a premature termination of the tow since it's going to happen soon no matter who releases. Second, it's a request for the glider pilot to release so the tow rope returns to the airport with the tug and can be used again. Neither of these reasons are critical enough to require an instant, thoughtless reaction from the glider pilot. If it's really time-critical, the tow pilot will release without a warning. Given there's a few seconds to think after a wing-rock, why not use one of those seconds to check for open spoilers? If you've mis- identified a rudder waggle, a spoiler check saves the day. If it's really a wing-rock, you don't want the spoilers open anyway. Since on most gliders the release is near the spoiler handle, your hand will be near the release after checking the spoilers. Spoilers open on tow is always a real life threatening situation. Some spoilers-open aerotow experiments with Condor flight simulator shows a 200' release with an attempted return to the runway almost never works - it's the equivalent of an engine failure turnback with an airplane. Even waiting until the tug turns back over the airport at pattern altitude makes for a problematic landing. If the glider pilot doesn't know the spoilers are open, it's unlikely a close & high pattern will be flown. At the risk of inciting the anti-technology crowd, I think there's a good case to be made for an LED annunciator panel. Today's gliders have enough electronics no one is likely to initiate a flight without a fully charged battery. A simple spoilers open switch and light circuit may well save a life or two. While thinking about an annunciator panel, lights for unlatched canopy and tail dolly are also possible. (The tail dolly switch would be a magnetic reed switch inside the tail boom and a magnet on the tail dolly.) |
Bill raises some good issues and, while I'm one of the "anti technology"
crowd, I'd install such simple circuits. I just never thought of such things (slapping forehead). He also mentions that a high and close pattern is unlikely with spoilers untentionally open. I've always wondered why everyone does not always fly a high and close pattern and use the spoilers to come down. This way the pilot is much less likely to be caught by wind shears, sink, etc. When I'm towing I fly my pattern high and close enough that I can pull it to idle and not touch the power again until I need it to taxi to the ramp (or if I'm caught by an unexpected gust). I often wonder where those who fly a B-52 pattern will land if they have a power failure (power plane) or unexpected sink (glider). My Mosquito has superb dive brakes so I can land from any altitude. I can also bring the tow plane down if I'm dumb enough not to lock them for takeoff. "Bill D" wrote in message ... On Jul 26, 8:14 am, Tom wrote: Last year, I wrote articles regarding this and other topics which are widely distributed through the SSA's Soaring Magazine: "Preventing Launching Accidents" and "Preventing Landing Accidents." Further, I presented the same topics at the FAA Safety Facility at Lakeland Florida. These presentations (and others) are available on DVDs and printed booklets from our web site, WWW.EGLIDER.ORG Both the DVDs and the printed booklets are inexpensive and make excellent source material for club safety meetings. These two issues dominate glider accident statistics. The real problem is getting people to take the few minutes to become educated and to adopt the simple, life-saving practices that will save their lives. The well-known 5 hazardous thoughts, Anti Authority, Impulsivity, Invulnerability, Macho and Resignation dominate glider accident causes. I will be conducting several FAA approved, Flight Instructor Revalidation courses begining in November. (First in Minden, Nevada, Nov 12/13.) Any pilot interested in learning about safety issues and standardized procedures can attend. Tom Knauff Some thoughts for Tom Knauff and others... Why do we have a wing-rock signal? The tow pilot could just release. There are two possible answers I can think of. First, it's a courtesy "heads-up" signal to the glider pilot to start thinking about a premature termination of the tow since it's going to happen soon no matter who releases. Second, it's a request for the glider pilot to release so the tow rope returns to the airport with the tug and can be used again. Neither of these reasons are critical enough to require an instant, thoughtless reaction from the glider pilot. If it's really time-critical, the tow pilot will release without a warning. Given there's a few seconds to think after a wing-rock, why not use one of those seconds to check for open spoilers? If you've mis- identified a rudder waggle, a spoiler check saves the day. If it's really a wing-rock, you don't want the spoilers open anyway. Since on most gliders the release is near the spoiler handle, your hand will be near the release after checking the spoilers. Spoilers open on tow is always a real life threatening situation. Some spoilers-open aerotow experiments with Condor flight simulator shows a 200' release with an attempted return to the runway almost never works - it's the equivalent of an engine failure turnback with an airplane. Even waiting until the tug turns back over the airport at pattern altitude makes for a problematic landing. If the glider pilot doesn't know the spoilers are open, it's unlikely a close & high pattern will be flown. At the risk of inciting the anti-technology crowd, I think there's a good case to be made for an LED annunciator panel. Today's gliders have enough electronics no one is likely to initiate a flight without a fully charged battery. A simple spoilers open switch and light circuit may well save a life or two. While thinking about an annunciator panel, lights for unlatched canopy and tail dolly are also possible. (The tail dolly switch would be a magnetic reed switch inside the tail boom and a magnet on the tail dolly.) |
using less spoiler just before the flare??? | Gary Emerson | Soaring | 16 | October 29th 07 01:08 PM |
Landing with one spoiler | [email protected] | Soaring | 82 | October 7th 05 12:58 AM |
Nimbus 3 25.5 tip spoiler cable replacement | tango4 | Soaring | 0 | May 3rd 04 09:05 PM |
Spoiler placement and design. | B2431 | Home Built | 9 | November 11th 03 04:02 PM |
